Você vai migrar para um ZEN
  • Total de votos
    989
manotroll
11,341
3,912
teresopolis
não pegue o 2200g,vai de r5 1600,é desperdício vc colocar esse processador nessa placa ai,tem lugares que a diferença de preço é de 50 reais...
tem que ver se ele tem vga senão tem que ser o G mesmo
1 - Comunicado oficial da Biostar:
"May 14, 2019, Taipei, Taiwan – BIOSTAR,a leading manufacturer of motherboards, graphics cards, and storage devices offers piece of mind for its customers, announcing the BIOSTAR AMD AM4 300-series and 400-series motherboardswill be compatible with upcoming 3rd Gen AMD RYZEN™ CPUs. BIOSTAR’s engineering team have been working relentlessly prior to the availability of the upcoming CPUs to ensure BIOSTAR products keep their promise of ensuring customers get the best value without worrying about future upgrades."
https://www.biostar.com.tw/app/en/news/news.php?S_ID=366
Lista (planejada) com suporte para o Ryzen 3000 inclue modelos X470, X370, B450, B350 e A320:
2- Samsung vai parar de produzir E-die DDR4:
https://www.anandtech.com/show/14327/samsung-to-end-b-die-ddr4-memory
C-die e D-die 10nm continuarão sendo produzidos, porém o E-die (preferido para overclock) será descontinuado no Q2/2019.
3 - AMD confirma que seus processadores não são afetados pela vulnerabilidades RIDL/Fallout:
"AMD Confirms its Processors are Unaffected by RIDL and Fallout Vulnerabilities"
https://www.techpowerup.com/255537/...naffected-by-ridl-and-fallout-vulnerabilities
"RIDL vulnerability hits Intel - new Side Channel Attack potentially is worse than Spectre and Meltdown"
https://www.guru3d.com/news-story/n...-hyper-threading-below-8th9th-gen-cpus,3.html
https://mdsattacks.com/
https://www.tomshardware.com/news/intel-disable-hyper-threading-spectre-attack,39333.html
https://www.techspot.com/news/80081...xecution-exploit-affects-intel-core-cpus.html
https://www.techpowerup.com/255508/...abling-hyper-threading-below-8th-9th-gen-cpus
cada vez a intel mostra como se faz desempenho cagando pra segurança agora la se vai mais 20% de rendimento e o 2700x chega no 9900k em single core
caveragra
583
Itu-São Paulo
ELE TEM UMA RX 580,POR ISSO RECOMENDO UM R51600 NO LUGAR DO 2200G
Reações: lyraal
manotroll
11,341
3,912
teresopolis
então vai de R5 mais núcleos
Outra motherboard baseada no chipset AMD X570 para os CPUs AMD Ryzen 3000 retratados, o CVN X570 Gaming Pro com 10 fases VRM
https://wccftech.com/amd-ryzen-3000-series-x570-gaming-motherboard-pictured/
Movendo-se para o outro lado do soquete, podemos identificar quatro slots DDR4 DIMM que suportam até 64 GB de capacidade de memória com velocidades de até 3466 MHz OC +. A placa-mãe tem como objetivo ser um design mais mainstream afinado para que possamos esperar que as placas-mãe topo de linha da DIMMs de memória de velocidade ainda mais alta suportem o Colorful. As opções de armazenamento incluem seis portas SATA III.
Quando se trata de slots de expansão, a placa-mãe contará com três slots PCI-e Gen 4 x16, sendo dois blindados por contraventamento metálico (x16 + x4 ou x8 + x8). Há também três slots PCIe Gen 4.0 x1 e dois slots M.2 na placa-mãe, que são cobertos por dissipadores de calor metálicos com heat pads. A característica mais interessante desta placa-mãe é o uso de um cooler de ventilador ativo sobre o dissipador de calor PCH, que é vermelho. Isso seria configurável usando o software incluído, de modo que cabe ao usuário se ele deseja que o ventilador gire para um desempenho de resfriamento extra ao custo de uma saída de ruído mais alta ou vice-versa.
No que diz respeito à I / O, a placa utiliza o sistema de áudio Voice Gamer (ALC 1150 Codec), porta HDMI, DP, LAN + WiFi (RTL8118AS-CG Gigabit), 2 USB 3.1 Gen 2, 5 USB 3.0 e 6 USB. Portas 2.0. O preço não foi confirmado, mas espera-se que seja anunciado na Computex 2019 juntamente com os próprios processadores da série AMD Ryzen 3000.
[email protected] e que tem mais pci-e ae ai ao usar os m2 acaba desabilitando algo
outra não da pra usar os m2 em pe ?
sacanagem fica tirando pci-e pra colocar eles
a bateria esta em um péssimo lugar pra dar o reset a não ser que o pino esteja bem posicionado
Keiji Kawamori
I'm Batman!!
5,030
2,935
O SMT ativo traz mais benefícios (performance multicore e baixo consumo atribuído a este) do que malefícios, então não vejo o porquê de desabilitar por pequeno incremento em singlecore...
Vem 07/07 ;)
Infelizmente, tambem acho que lança dia 07/07. Departamento de marketing ia comemorar.
Mas queria que fosse 6nm esta cpu, ai iria lançar em 06/06 :bwahaha::bwahaha::bwahaha:...
Thyfer
428
354
12
Kkkkkk
Só espero que não seja paper launch com lançamento real lá pra setembro....
Keiji Kawamori
I'm Batman!!
5,030
2,935
Kkkkkk
Pela mor de Deus, virá está boca para lá. Meu 4790K está gargalando bonito na 2080TI, quero está cpu da AMD para ontem!
ljbsvg
2,020
634
Alguem tem alguma ideia de qual seria o equivalente do chip Nanya A-die no ryzen dram calculator ?
La so tem o Hynix A-die, sera que a qualidade é a mesma ? (ps: memoria da hyperX padrao de 2400mhz)
brender
12,326
19,255
Reações: user101
lenondmf
A volta dos que não foram!!
1,898
1,523
Brother bom dia. A suas memorias devem ser Hynix da uma olhada no Thaiphoon Burner se você não tiver ele me fala que eu te mando.
Reações: ljbsvg
ljbsvg
2,020
634
O Thaiphoon mesmo marca como Nanya Technology no fabricante, por isso nao to entendendo.
kameraider
3,174
2,033
Goiania-GO
Nao tem segredo. Os chips da da marca Nanya. Pega o part number, vai no site da Nanya e pega o datasheet se quiser ( não que va ajudar alguma coisa hehe)
Acho que esses A-die sao usados nos pentes 3466Mhz. Costumam vir em 2666mhz ainda em 1.2V.
Sua memoria deve chegar em 2933Mhz com 1.35V sem maiores problemas
Reações: ljbsvg
ljbsvg
2,020
634
Não fui no site da nanya, mas usei o Hynix A-die como parametro pra botar 2933mhz no ryzen dram calculator.
Rodou uma hora estavel com os parametros e ai fiz um ajuste a mais e ja ta a 1 hora +ou- estavel tb.
Ficou assim:
Porem, com 3200mhz o PC não liga de jeito nenhum. Acho que o chip nao deve aguentar.
Prof. BoomerJack
993
46
46
Vem 07/07 ;)
Concordo, mas com SMT ativo não atrapalha o over de certa forma? Pode causar mais instabilidade ou não?
Além disso, acreditam que uma mobo x370 vai conseguir rodar todo potencial dos ryzen 3000 por conta do chipset antigo ou o desempenho vai ser praticamente o mesmo de uma x570?
Thyfer
428
354
12
O SMT diminui a estabilidade ou potencial de OC? Sim
Mas num nível bem pequeno. Exatamente o que disse: o ganho por overclock é infimo perto do ganho do SMT ativo!
Não, as X370 não conseguiram desbloquear todo o potencial dos Ryzen 3000. Se já as b450/x470 têm o XFR2/PBO2, as novas devem vir com mais features e melhor potencial de overclock nas memórias, além de VRM esperadamente mais robustos.
A troca vai valer a pena ou o desempenho ruim? Acredito que em ambos os casos não, caso não queira ir com 12C ou 16C, mas é achismo, temos de esperar pra ver como vai ser após os benchmarks!
Abçs
Arthuria
321
203
Abçs
XFR e PBO tanto 1 quanto 2 são intrínsecos ao processador, você pode usar um Ryzen 2600X com uma X370 que vai continuar sendo XFR2 e PBO2, única feature que é atrelada as placas mãe com chipset B450/X470 é o StoreMI.
Thyfer
428
354
12
Realmente, quando ao XFR2 achei que é no chip da CPU, mas teria alguma fonte comprovando que o PBO2 também é do CPU? Só achei falando que era de placas X470 ou X370 (com implementação dependente da fabricante).
Arthuria
321
203
A minha ASUS B350 sempre possuiu a opção de ligar ou desligar o PBO. Nessa penúltima AGESA que saiu pra ela ainda foi adicionado a opção do PBO Scalar, recurso este que só tinha visto na linha Strix da ASUS...
O PBO é atrelado ao processador mas ele depende sim de recursos da placa mãe pra funcionar adequadamente, como um bom VRM...
https://community.amd.com/community...precision-boost-overdrive-in-three-easy-steps
"All 2nd Gen AMD Ryzen-branded Processors use Precision Boost 2, which intelligently leverages a large network of sensors built into the CPU to determine whether it’s okay to boost."
brender
12,326
19,255
Prof. BoomerJack
993
46
46
essa noticia de bios da AMD é de quando?
resumindo, isso é bom ou ruim? a minha mobo com meu setup de assinatura se comportaria bem com um ryzen 3000 R7 ou R9 ?
Sabemos que um 1700 pra um 2700 não possui uma diferença tao grande... mas do 1700 para o 3700, será que vai valer o upgrade? e será que minha mobo suporta bem esse proc?
Arthuria
321
203
Provavelmente os Ryzen 3000 virão com XFR3/PBO3 e estes muito provavelmente funcionarão em placas mãe com chipset série 300 e 400, porém dependendo da placa mãe em si ele pode não funcionar em toda a sua plenitude.
Caso realmente seja lançado Ryzen 12n/24t e 16n/32t não tem milagre que vá fazer o PBO funcionar adequadamente numa placa mãe com 4 phases pra CPU, que é a grande maioria das B350/450.
user101
1,995
2,356
Resumo
Comunicado oficial da Gigabyte sobre suporte Ryzen 3000:
X470 e B450 - bios F40 já disponível para download
X370 e B350 - bios F40 ficará disponível para download até o final do mês
F40
Update new AGESA for next Gen. AMD Ryzen™ CPUs full support
https://www.gigabyte.com/br/Motherboard/B450M-GAMING-rev-10#support-dl-bios
"BIOS updates for the X370 and B350 AMD motherboards will be released before the end of the month."
"In anticipation of the release of next gen. AMD Ryzen™ CPUs, GIGABYTE engineers have successfully tested and validated GIGABYTE AMD motherboards with the newest BIOS to ensure that users have full support for their new CPUs with top notch compatibility. Users can visit the official GIGABYTE website to download the newest BIOS version (F40 and later versions), so that they can fully unleash the power of these next gen. CPUs."
https://www.gigabyte.com/Press/News/1689
Lembrando: o recomendado é não atualizar bios se tudo estiver rodando sem problemas. Só atualize para correção de bug específico ou para ter suporte (nova geração de CPUs).
Reações: brender
Ademastor
aconteceu alguma coisa com a produção de placas mae am4? estou a 3 meses acompanhando a disponibilidade de algumas b450/x470 e nenhuma aparece pra venda nos sites como kabum, pichau, terabyte, etc
Keiji Kawamori
I'm Batman!!
5,030
2,935
No caso do Brasil, não é falta de produção. É sempre culpa dos importadores/distribuidores.
Por vários motivos isso. Ou eles importam poucas peças, demora para importar... É agora ainda tem está alta do dólar, ai acaba com nosso mercado BR de peças de computadores.
brender
12,326
19,255
ops
