Which leaves one final question: should you buy the Ryzen 9 5900X? And the answer, as is often the case, is: it depends. Had AMD rolled this chip out at the same price point as the 3900X's $499, it would have been the easiest yes I've ever uttered. That extra $50 does give pause for thought though, especially when you factor in that you've got to buy a decent aftermarket cooler as well. It's a great chip, but it's costly.
It very much feels like this is a chip that was built to last though. Support for PCIe 4.0 is a definite tick for AMD's chips, and while we may have had such support since the release of Zen 2, it doesn't lessen its impact. Given the push for speedy SSDs, pairing this chip with some serious storage should see you right as we move into a world that begins to make the most of the storage technology available. And actually this is reason enough for AMD's chips to pull ahead of Intel's PCIe 3.0 supporting behemoths.
If I were building a high-end PC right now, would this be the CPU of choice? Yes, it probably would. This alongside an Nvidia GeForce RTX 3080 makes for a formidable core that can handle 4K easily, and also turn its hand to more productive tasks without really breaking sweat. It'll surely play nice with the upcoming RX 6000-series GPUs, too. Throw in a quality next-gen SSD, a decent motherboard and some quality RAM and you've got a build that will easily outlive the PS5 and the Xbox Series X. Obviously it'll cost a lot more, but it can do so much more as well.
The key factor in this is that AMD has wrestled the gaming performance crown off Intel. And even if it isn't quite a knockout, more a win by points if we stick with that metaphor, it doesn't diminish the fact that the last cry of Intel diehards has now vaporised. It doesn't matter if you side with Intel or AMD when it comes to gaming, they're both just as capable. And given the overall package from AMD, that makes this the better chip.
Tradução Google:
O que deixa uma pergunta final: você deve comprar o Ryzen 9 5900X? E a resposta, como costuma acontecer, é: depende. Se a AMD tivesse lançado este chip com o mesmo preço do 3900X de $ 499, teria sido o sim mais fácil que eu já disse. Esses $ 50 extras dão uma pausa para pensar, especialmente quando você leva em consideração que você tem que comprar um cooler de reposição decente também. É um ótimo chip, mas é caro.
Parece que este é um chip que foi construído para durar. O suporte para PCIe 4.0 é uma marca definitiva para os chips da AMD e, embora possamos ter esse suporte desde o lançamento do Zen 2, ele não diminui seu impacto. Dado o impulso para SSDs velozes, emparelhar este chip com algum armazenamento sério deve ver você bem enquanto avançamos para um mundo que começa a aproveitar ao máximo a tecnologia de armazenamento disponível. E, na verdade, esta é uma razão suficiente para os chips da AMD ultrapassarem os gigantes de suporte PCIe 3.0 da Intel.
Se eu estivesse montando um PC de última geração agora, este seria o CPU de escolha? Sim, provavelmente seria. Isso junto com uma Nvidia GeForce RTX 3080 cria um núcleo formidável que pode lidar com 4K facilmente, e também se dedica a tarefas mais produtivas sem realmente suar muito. Ele certamente funcionará bem com as próximas GPUs da série RX 6000 também. Adicione um SSD de última geração de qualidade, uma placa-mãe decente e um pouco de RAM de qualidade e você terá uma construção que sobreviverá facilmente ao PS5 e ao Xbox Series X. Obviamente custará muito mais, mas pode fazer muito mais também.
O fator chave nisso é que a AMD lutou contra a coroa de desempenho em jogos da Intel. E mesmo que não seja exatamente um nocaute, mais uma vitória por pontos se ficarmos com essa metáfora, isso não diminui o fato de que o último grito dos obstinados da Intel agora evaporou. Não importa se você está do lado da Intel ou da AMD quando se trata de jogos, ambos são igualmente capazes. E dado o pacote geral da AMD, isso torna este o melhor chip.
