Trecho interessante da conclusão:
"The most exciting thing we saw so far wasn’t the average frame rates, but the minimum. People are often quick to leap to the maximum frame rate, and I’ll give you a bit of a tip, high frame rates are great, but they’re not all that. You can run some games as low as 20FPS and it’ll play great, just look at classics like Zelda 64 and Goldeneye, they ran at 20FPS and they felt pretty smooth. The trick is they didn’t drop frames. If you’re gaming at 100+ FPS and your frame rate drops below 60FPS for a moment, you’re going to notice; the same is true from 60-40, and so on. The Ryzen 1800X helped maintain the highest minimum frame rates we’ve ever seen, and that means a more consistent, smoother and overall better gameplay experience. When it comes down to it, this higher minimum number is what you want from a gaming chip, not just the bigger average or maximum number."
