Assassin's Creed Terá uma melhor IA no Xbox 360
Cyrx
Adrena Old School
http://pc.ign.com/articles/736/736396p1.html
While the PlayStation 3 and 360 versions of Assassin's Creed are virtually identical, Raymond did say that on the 360 the team is putting a special emphasis on achievements. The hardware also allows for improved threading, which will improve even further the crowd AI.
0-------------------------------------------------------------------------
Essa Raymond é uma gracinha!
PIC dela :p Abaixo da PIC segue uma entrevista com ela.
Ele conta como entrou no mundo dos jogos, etc etcc
http://www.g4tv.com/prestitial.aspx?r=/electricplayground/features/51427/Jade_Raymond_QA.html
Cyrx
Adrena Old School
Algumas possivel explicações para o fato, porem não entendo nada.
However bad off Xenon will be in that department, the PS3's Cell will probably be worse. The Cell has only one PPE to the Xenon's three, which means that developers will have to cram all their game control, AI, and physics code into at most two threads that are sharing a very narrow execution core with no instruction window. (Don't bother suggesting that the PS3 can use its SPEs for branch-intensive code, because the SPEs lack branch prediction entirely.) Furthermore, the PS3's L2 is only 512K, which is half the size of the Xenon's L2. So the PS3 doesn't get much help with branches in the cache department. In short, the PS3 may fare a bit worse than the Xenon on non-graphics code, but on the upside it will probably fare a bit better on graphics code because of the seven SPEs
Physics is a difficult problem to do multi-threaded (dedicated core, ok... but 3 or 4 cores for physics?); AI can be even more difficult as it can be very branchy and is often part of the core game loop.
Cell may be great for such in the future, but fitting your code into 256K on an SPE, and maybe even less if you have to use a buffer for DMA requests, means a lot of hard work.
Growing pains for both consoles right now.
SHAFT
Adrena Old School
Parece que o PS3 é limitado no L2 consequentimente o cache iria interferir nessa melhora do AI.
Não sei se é isso, mais estranho...PS3 tem o mais pika de todos os cpu, e IA não estaria mais ligada na CPU?
:eek:
Portanto que a AI do PS3 não seja a de um peixe acho que não vai tão diferente hehehehe acho eu :whistle:
T2.Gondii
Sem AA?? Afff
Pooo, já havia postado com uma paginação mais irônica....
Dizem que o PS3 tem o mesmo erro de projeto do PS2 ao não compartilhar a memória do sistema, gerando este tipo de limitação apesar de uma banda maior....
Isso não me importa, o que importa e que eu não pago U$100 a mais por um negócio que seja inferior ao console lançado um ano antes....
Ou o PS3 começa a dar linha na pipa, ou então não vai ver a cor dos meus dólares!
EDIT: lendo com calma, ensinua-se que ambos os consoles estão na ***** para gerenciar tudo, o X360 um pouco menos. E graficamente o PS3 tem mais facilidade para ser programado devido às 7 SPEs do Cell
Cyrx
Adrena Old School
Não entendo nada de arquitetura, li que o PS3 é bom para Fisica.
Em contra partida o 360 vai se sair melhor em IA.
T2.Gondii
Sem AA?? Afff
Ela diz que o X360 será melhor para AI. E que o PS3 pode ser melhor para física se investir muita $$$ e tempo para programar com o Cell......
BlackBurN
Gamer
o q deu pra concluir é q a Jade eh uma fofura mesmo.....
acho q ela tem chance comigo, se tiver bom papo :)
[EU]
nusssa Assassin's Creed loucura dimaissssssssssssss q video é aquele!!! xbox 360 rulezzz to jogando dead rising.. outro jogo q promete.. hj mesmo peguei um cortador d grama e podei alguns mortos vivos ehheheeh loucura loucura.. o black.. vai em uma igreja rapah.. tira essa macumba do corpo .. eheheh
Allan
Trust the plan!
asuiashuahushuashuas...vo fingir q eu n li isso....:slap:
Xenos
cara, tipo, a galera diz q o PS3 tem mais cache, mas isso se somar tudo.
ali encima disse q o Cell só terá um PPE(processador comum, power PC), o resto será processadores específicos para algumas tarefas como renderizacao de cenario, etc...
comentou q o 360 terá 3 PPE, entao a programacao poderá ser bem melhor.
o problema, é q para obter bom desempenho no PS3, precisará de boa programacao, e esse nao é o melhor porte da Sony.
o OS do PS3 já havia dado problemas, a Sony teve q reprograma-lo 100%
Alxramm
O que tá dando pra perceber é que cada sistema tem vantagens, desvantagens e programação diferentes.
Temos que esperar prá ver!!!
1 mês e 1/2 galera!!!
Quanto mais concorrência entre os consoles, melhor prá nos que teremos jogos com mais qualidade, mais baratos e em maior quantidade.
Imaginem o tio Bill sozinho no mercado? Seríamos assaltados!!!
flwsssss
Fratini
!!Galo doido!!
Noh cara.. de boa.. onde vc leu isso ai? Pq nao tem nada com oq ta falando no post citado do cyrx!! hehehe
Ou entao to lendo ingles como se tivesse lendo grego! Ou vc! :fun:
Xenos
é boa parte doq eu falei o Cyrx nao citou, oq eu falei, eu peguei na INFO, q li ontem(uma antiga) de um representante do Cell na IBM, e ele msm falou q o PS3 só terá um core baseado no PowerPC(tipo como se desse para usar num PC), o resto era td core direcionado para outras tarefas.
ELE falou isso.
o cara da INFO perguntou se o Cell sairia para PC e ele disse q nao, pq se saisse, serviria de um core só, ja q o resto é td direcionado para outras tarefas
SHAFT
Adrena Old School
"The PS3's L2 is only 512K, which is half the size of the Xenon's L2. So the PS3 doesn't get much help with branches in the cache departme."
:p
Cell é o melhor cpu disparado dos consoles e até melhor que o C2D. IA é praticamente CPU, afimar isso é totalmente "gogo" pro lado da microsft. Ou sejá dinheiro.
Karazu
:p
É inquestionável que o Cell seja o melhor dos processadores nos consoles atuais, mas se você quer conquistar e dominar algum mercado, você PRECISA pisar nos calos da concorrência, e sobre tudo, manter uma imagem limpa do seu produto.
O X360 não faz sucesso apenas por sua qualidade...
E a gente ta vendo o depoimento de uma mulher! Mostre o "limite" do seu cartão e você vai conquista-la sem problemas...
ZUERA.. XD
hargeen
AVANTE VINGADORES!!!
Karazu, como diria Hermes e Renato...
"Mulher gosta de dinhero, quem gosta de pi%* é bicha..."
uhahahahahhahahahahhahaa
Enfim, fora a piada, se um especialista diz, é claro que eu acretido, então X360 faz IA melhor que o PS3, ate me provarem o contrario, esse é o certo.
Mais segundo a lindinha ali, no futuro isso pode mudar, com certeza, daqui a uns dois anos apos o lançamento o PS3 deve ser uns 30 a 60% melhor que o X360.
Mitchell1985
pff, quando eu pensava que já tinha visto tudo... "só faltava essa"
1 coisa: desde o início falaram por aí que a AI do ps3 ia ser melhor por causa do cell, não?
JEDI
Hj em dia é melhor que investe mais.
E a M$ consegue ser a melhor pq investe muito em marketing.
Pra quem ja acompanhou a briga do Win vs Linux sabe muito bem como funciona o MKT da M$.
SHAFT
Adrena Old School
Sim.
Mais isso é para as pessoas que lembram dos fatos.
Se chega um cara desses e fala uma porra louca que nem ele disse, é obvio que um pequeno newba vai entrar na pilha e achar que o xbox é melhor em AI :lol: ele é bom, sem duvidas, mais PS3 é melhor e toda verdade merece ser dita.
E po..."regular" a ai de um console para outro não é algo dificil...basta por $$ na conta deles :lol:
Shinigami
Sim, era o Fuck3r
Sim.
Posta um link que prove o que tu ta falando :said:
Saco ficar afirmando um monte de coisa, sem ter como provar.
Shinigami
Cyrx
Adrena Old School
Pois é, em nenhum momento foi dito que a IA do play ia ser melhor, apenas a fisica, e tem gente afirmando.
LoSel 0 JaBa
Nossa, como o povo tá nervoso.. é claro que o ps3 vai extrunchar....
Apesar de ter os 3 cores genéricos com HT, ou SMT como preferirem, com certeza contra apenas 1 do PS3, falando logicamente e friamente... sim, o 360 teria a A.I melhor, mas o jogo ficaria igual a um jogo WII, por que não ia sobrar mais nada. Enquanto no ps3 o balanceamento é bem melhor pois som é feito nas SPEs, a física tb, então o 1 desocupado do ps3 chega junto dos 3 no talo do 360 (se é que ele vai usar os 3) ou até mais.
Vlw.
Jin-Roh
Q coisa.... Mas outros desenvolvedores falaram o mesmo? Sei não, não vejo motivos pra acreditar q isso seja verdade... O dinheiro compra (quase) tudo, eheheh.
Mas vejam bem, não duvido q seja verdade, apenas não da pra acreditar soh com isso...
