Totalmente estranho mesmo!!! Que CPU foi usada?
Mas os resultados da 7950GX2 tb estão fracos no review do vr-zone... parece até incompatibilidade...de qualquer forma, Shamino usou a melhor CPU da atualidade, com umas das melhores mobos tb... e de noob ele não tem nada... a ATi sempre teve problema de maior 'driver overhead' - maior uso da CPU... entretanto, a 7950GX2 com tecnologia SLI também teria esse problema... coisa estranha!
resumindo: tá tudo meio 'nebuloso'. Mas a X1950XTX não tem obrigação nenhuma de bater a 7950GX2 : basta oferecer um custo x benefício melhor que a X1900XTX. E isso parece que ela vai conseguir tranquilamente.
fui
olha me parece que o teste do vrzone foi tirado do ar :lol:
Hi guys, just came back from a midnight outing and am here to address some of your concerns.
We've taken down the review because ATI personally got in touch with us with regards to the ongoing product embargo. Thus we gladly obliged, as we would like to maintain the best interests of all manufacturers. Though there have been rumors prior to this of the probable launch dates, ATI hasn't conveyed this to us, nor have we been under any NDA. Thus when the opportunity came upon us, we went ahead.
With regards to the results, both set of results from HWZ and VR could be perfectly fine. Why? We've seen through testing thousands of products over the 8 years we've been operating and we know the fine details that affect these scores. First and above all, the test systems are of a completely different grade where ours is more of an upper-midrange class but VR's system is totally top-end. When we transitioned our testbeds previously, we observed these shift in results, thus the outcome you see is everything that you will see on various test systems. There's nothing wrong or right in either set. Secondly, the drivers are beta and although it looks like a modified version of the existing catalyst drivers, we cannot say for certain what it affects. Thirdly, the drivers sets on both sites are a tad different.
There's probably no mistake in results, it's just the way things are - for now
We did mention before that the Radeon X1950XTX might not be much better than the overclocked HIS Radeon X1900XTX and the results are about there.
We'll re-look at this card once again when its time is right once more and by that time, perhaps better drivers could be available
Goodnight folks and just hope ATI delivers on the price point as they have rectified the thermal and noise portions really well. stay tuned!
was asked to
launch date may stretch
tentative now on 14th september
Não consegui acessar o site hardwarezone... sempre q entro ele redireciona pro indice de artigos. Alguém tem um link funcionando?
edit: Acabei de achar a explicação do admin do site hardwarezone.. Eles realmente tiraram do ar devido a um pedido da ATI.
edit2: O Shamino do vr-zone foi confrontado por um user de lá que rodou o mesmo benchmark e conseguiu o dobro da pontuação do Shamino usando a 7950GX2.
link: http://forums.vr-zone.com/showthread.php?t=86026
A desculpa por ter tirado o review do ar foi:
*cof cof* vendido *cof cof*
affe esse biba do Shamino so tá querendo zua com a nossa cara :ranting3:
Na verdade foi...V1PM4N disse:O Shamino não foi owned.
V1PM4N disse:Tá na cara que houve alguma incompatibilidade, algo assim. Driver? Alguma opção marcada no painel de controle?
V1PM4N disse:Não que eu seja 'esperto', mas era ÓBVIO: o teste do hardwarezone estava limitado pela CPU, o que 'atrapalha' os resultados - só ver que a X1900XTX tava quase igual a X1950XTX! Pq os caras iriam puxar a sardinha para alguma marca?
