Pow,o better battlelog não funfa mais nao?
ta dizendo >
How to install: Open file with firefox, drag & drop into open firefox window or install directly (a layer pops out - you must allow to install)
How to update: If you already installed a version of BBLog you can use auto-update of your browser. Goto "Tools -> Addons (CTRL+SHIFT+A)", right click on BBLog extension entry -> Find Updates. This will be done automatically periodically by the browser but you can instant update when you do this manually.Download 2.4.1 for Chrome 14.0 and higherAttention: You are using Chrome Version 21+. Since this update chrome don't allow direct install of extension from outside the chrome web-store. If you have BBLog already installed goto "Tools->Extension" and click update extensions (Developer Mode). If you new to BBLog you need to download the file to disk and than drop the downloaded file into the browser as described bellow.How to install: Open file with chrome, drag & drop into open chrome window (since chrome 21+ you must drop the file into "Tools->Extensions" window) or install directly (a layer pops out - you must allow to install)
How to update: If you already installed a version of BBLog you can use auto-update of your browser. Goto "Tools -> Extensions", enable Developer Mode and click "Update all extensions". This will be done automatically periodically by the browser but you can instant update when you click the button.
ta dizendo >
, e muitas vezes eu nem vejo o que aconteceu
