Opa, vamos lá. Peguei o log do CPU-Z e tirei algumas coisas:
Processors
Number of sockets 1
Number of threads 12
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- CCX 1
-- Core 3 (ID 4)
-- Thread 6 8
-- Thread 7 9
-- Core 4 (ID 5)
-- Thread 8 10
-- Thread 9 11
-- Core 5 (ID 6)
-- Thread 10 12
-- Thread 11 13
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 6 (max 6)
Number of threads 12 (max 12)
Manufacturer AuthenticAMD
Name AMD Ryzen 5 2600
Codename Pinnacle Ridge
Specification AMD Ryzen 5 2600 Six-Core Processor
Package Socket AM4 (1331)
CPUID F.8.2
Extended CPUID 17.8
Core Stepping PiR-B2
Technology 12 nm
TDP Limit 65.0 Watts
Tjmax 95.0 °C
Core Speed 2590.0 MHz
Multiplier x Bus Speed 26.0 x 99.6 MHz
Base frequency (cores) 99.6 MHz
Base frequency (ext.) 99.8 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision 0x8008204
L1 Data cache 6 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 6 x 64 KBytes, 4-way set associative, 64-byte line size
L2 cache 6 x 512 KBytes, 8-way set associative, 64-byte line size
L3 cache 2 x 8 MBytes, 16-way set associative, 64-byte line size
SMU Version 43.12.00
TDP/TJMAX 0x41005F
TCTL Offset 0x0
Core Perf #0 0xFF510463
Temperature 0 40 degC (104 degF) (Package (Node 0))
Voltage 0 1.17 Volts (VID)
Voltage 1 1.19 Volts (CPU VDD)
Power 00 22.58 W (Package)
Power 01 2.94 W (Core #0)
Power 02 2.33 W (Core #1)
Power 03 1.91 W (Core #2)
Power 04 1.88 W (Core #3)
Power 05 2.11 W (Core #4)
Power 06 1.69 W (Core #5)
Power 07 12.86 W (Cores)
Clock Speed 0 2589.95 MHz (Core #0)
Clock Speed 1 3884.93 MHz (Core #1)
Clock Speed 2 3884.93 MHz (Core #2)
Clock Speed 3 3810.22 MHz (Core #3)
Clock Speed 4 3810.22 MHz (Core #4)
Clock Speed 5 3810.22 MHz (Core #5)
Core 0 max ratio (effective) 39.0
Core 1 max ratio (effective) 39.0
Core 2 max ratio (effective) 39.0
Core 3 max ratio (effective) 39.0
Core 4 max ratio (effective) 39.0
Core 5 max ratio (effective) 39.0
BIOS
UEFI Yes
BIOS Vendor American Megatrends Inc.
BIOS MSG 63-0100-000001-00101111-091015-Chipset
BIOS Date 09/10/15
Mainboard Vendor 000001
AMD AGESA PinnaclePI-AM4 1.0.0.1a
Chipset
Northbridge AMD Ryzen SOC rev. 00
Southbridge AMD A320 rev. 51
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR4
Memory Size 16 GBytes
Channels Dual
Memory Frequency 1197.1 MHz (1:12)
CAS# latency (CL) 16.0
RAS# to CAS# delay (tRCD) 16
RAS# Precharge (tRP) 16
Cycle Time (tRAS) 39
Bank Cycle Time (tRC) 55
Command Rate (CR) 2T
Uncore Frequency 1197.1 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR4
Module format UDIMM
Module Manufacturer(ID) Team Group Inc. (7F7F7F7FEF0000000000000000)
SDRAM Manufacturer (ID) SpecTek Incorporated (7F7FB500000000000000000000)
Size 8192 MBytes
Max bandwidth DDR4-2400 (1200 MHz)
Part number TEAMGROUP-UD4-2400
Serial number 02026E84
Manufacturing date Week 41/Year 18
Nominal Voltage 1.20 Volts
EPP no
XMP yes
XMP revision 2.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 10.0-10-10-25-35 @ 750 MHz
JEDEC #2 11.0-11-11-27-38 @ 825 MHz
JEDEC #3 12.0-12-12-29-41 @ 900 MHz
JEDEC #4 13.0-13-13-32-45 @ 975 MHz
JEDEC #5 14.0-15-15-34-48 @ 1051 MHz
JEDEC #6 15.0-16-16-37-52 @ 1126 MHz
JEDEC #7 16.0-16-16-39-55 @ 1200 MHz
JEDEC #8 17.0-16-16-39-55 @ 1200 MHz
JEDEC #9 18.0-16-16-39-55 @ 1200 MHz
XMP profile XMP-2400
Specification DDR4-2400
Voltage level 1.200 Volts
Min Cycle time 0.833 ns (1200 MHz)
Max CL 16.0
Min tRP 13.32 ns
Min tRCD 13.32 ns
Min tRAS 31.94 ns
Min tRC 45.32 ns
Min tRRD 7.00 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 11.0-11-11-27-38-n.a @ 825 MHz (1.200 Volts)
XMP #2 12.0-12-12-29-41-n.a @ 900 MHz (1.200 Volts)
XMP #3 13.0-13-13-32-45-n.a @ 975 MHz (1.200 Volts)
XMP #4 14.0-15-15-34-48-n.a @ 1051 MHz (1.200 Volts)
XMP #5 15.0-16-16-36-52-n.a @ 1126 MHz (1.200 Volts)
XMP #6 16.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
XMP #7 18.0-16-16-39-55-n.a @ 1200 MHz (1.200 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR4
Module format UDIMM
SDRAM Manufacturer (ID) SK Hynix (AD000000000000000000000000)
Size 8192 MBytes
Part number TEAMGROUP-UD4-3000
Serial number 0104A074
Manufacturing date Week 20/Year 20
EPP no
XMP yes
XMP revision 2.0
AMP no
XMP profile XMP-2998
Specification DDR4-2998
Voltage level 1.350 Volts
Min Cycle time 0.667 ns (1499 MHz)
Max CL 16.0
Min tRP 12.00 ns
Min tRCD 12.00 ns
Min tRAS 25.25 ns
Min tRC 37.25 ns
Min tRRD 3.70 ns
XMP #1 15.0-17-17-36-53-n.a @ 1411 MHz (1.350 Volts)
XMP #2 16.0-18-18-38-56-n.a @ 1499 MHz (1.350 Volts)
Monitoring
Mainboard Model A320M-HD (0x000001DC - 0x00944058)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6779
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC5
LPCIO Revision ID 0x62
Config Mode I/O address 0x2E
Config Mode LDN 0xB
DMI
SMBIOS Version 3.0
DMI BIOS
vendor American Megatrends Inc.
version P4.70
date 02/12/2018
ROM size 16384 KB
DMI System Information
manufacturer To Be Filled By O.E.M.
product To Be Filled By O.E.M.
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID {69C28570-41C8-0000-0000-000000000000}
SKU To Be Filled By O.E.M.
family To Be Filled By O.E.M.
DMI Baseboard
vendor ASRock
model A320M-HD
revision unknown
serial M8S-37631810044
DMI System Enclosure
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Extension Slot
designation PCIE1
type A5
populated no
DMI Extension Slot
designation PCIE2
type A5
populated yes
DMI Extension Slot
designation PCIE3_M2_1
type A5
populated no
DMI OEM Strings
string[0] To Be Filled By O.E.M.
DMI Additional Information Device
string # 1
string[0] MORDOR
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 256 GB
max# of devices 2
DMI Processor
manufacturer Advanced Micro Devices Inc.
model AMD Ryzen 5 2600 Six-Core Processor
clock speed 3400.0 MHz
FSB speed 100.0 MHz
multiplier 34.0x
DMI Memory Device
designation DIMM 0
format DIMM
type DDR4
total width 64 bits
data width 64 bits
size 8 GB
DMI Memory Device
designation DIMM 0
format DIMM
type DDR4
total width 64 bits
data width 64 bits
size 8 GB
Storage
Drive 0
Name TOSHIBA HDWD110
Revision MS2OA8R0
Serial 587UKJ8NS
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume d:\, 0.6 GBytes (94.0 percent available)
Volume e:\, 930.9 GBytes (73.3 percent available)
Drive 1 (O Windows 10 está neste SSD)
Name KINGSTON SA400S37480G
Revision SBFKB1H5
Serial 50026B76825B1B1A
Capacity 447.1 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 447.1 GBytes (78.7 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x04D9, product=0xA09F
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x045E, product=0x07F8
Graphics
Number of adapters 1
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1090304
Name NVIDIA GeForce GTX 1060 6GB
Board Manufacturer NVIDIA Corporation
Revision A1
Codename GP104
Core family 0x134 (GP104)
Cores 1280
ROP Units 48
TM Units 80
Technology 16 nm
Memory size 6 GB
Memory type GDDR5X
Memory vendor Micron
PCI device bus 38 (0x26), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x10DE)
Model ID 0x1B83 (0x12D9)
Revision ID 0xA1
Performance Level 0
Core clock 1518.5 MHz
Memory clock 4006.8 MHz
Win32_VideoController AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController DriverVersion = 27.21.14.6140
Win32_VideoController DriverDate = 01/22/2021
Monitor 0
Model 24G2W1G4 (AOC International)
ID AOC2402
Serial
Manufacturing Date Week 12, Year 2020
Size 24.0 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 160-160 kHz
Vertical Freq. Range 48-144 Hz
Max Pixel Clock 330 MHz
Gamma Factor 2.2
Monitor 1
Model DELL P2018H (Dell Computer)
ID DELD0C8
Serial VPCHG91E3T6U
Manufacturing Date Week 3, Year 2019
Size 19.4 inches
Max Resolution 1600 x 900 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-76 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 19042)
DirectX Version 12.0
Register Spaces
Register space PCI
Register space PCI #2
Register space PCI Express, base address = 0x0F8000000
Register space class = 0x12
Register space SMBus, base address = 0x0B00
Register space LPC, base address = 0x0290
Register space LPC, base address = 0x02E
Acho que tem informações bem detalhadas aí!
