Olá, pessoal !
Então, estou migrando para a plataforma 64bits da AMD (socket 939) e estou fazendo algumas pesquisas sobre qual placa-mãe comprar.
Qual dessas duas, baseadas no nForce4 e PCI-Express, vcs me recomendariam comprar ?
DFI LANPARTY UT nF4 Ultra
Supported CPU: AMD Athlon 64 processor
Chipset: nForce4 ULTRA
RAM: 4x DIMM Supports DDR266/333/400 Max 4GB
Slots: 2x PCI-E x16, 1x PCI-E x1, 1x PCI-E x4, 2x PCI
Ports: 2x PS/2, 6x USB2.0, 1x RJ45, 2x 1394, Audio Ports
IDE/RAID: 2x ATA 133 up to 4 Devices; RAID 0,1
SATA/RAID: 4x SATA RAID with NVIDIA RAID 0,1
Onboard Audio: Realtek ALC850(8-Ch)
Onboard LAN: Vitesse VSC8201 Gigabit Phy, Marvell 88E8001 Gigabit PCI
ou
MSI K8N Neo4 Platinum
Supported CPU: Socket 939 AMD Athlon 64FX/64 processor
Chipset: NVIDIA nForce4 Ultra
RAM: 4x DIMM Dual Channel DDR 266/333/400 Max 4GB
Slots: 1x PCI-Express X16, 1x PCI-E X4, 1x PCI-E X1, 4x PCI
Ports: 2x PS/2, 1x COM, 1x LPT, 10x USB2.0(Rear 4), 2x RJ45, 1x 1394, 2x SPDIF Out, Audio Ports
IDE: 2x ATA 133 with NV Raid 0/1/0+1
SATA: 4x SATA2 3.0Gb/s with NV Raid 0/1/0+1, 4x SATA with RAID 0/1/5
Onboard Audio: RealTek ALC850 7.1 ch
Onboard LAN: Marvell 88E1111 GbLAN, Marvell 88E8053 GbLAN
Onboard 1394: 2x Ports by VIA 6307
Obrigado pela vossa atenção !
ou
