http://sites.amd.com/us/game/downloads/Pages/downloads.aspx
Highlights of the AMD Catalyst™ 11.2 Windows release includes:
New Features:
The new Catalyst Control Center features
* Catalyst AI Texture Filtering updates
o The Quality setting has now been improved to match the High Quality setting in all respects but one; it enables an optimization that limits tri-linear anisotropic filtering to areas surrounding texture mipmap level transitions, while doing bilinear anisotropic filtering elsewhere. This optimization offers a way to improve filtering performance without visibly affecting image quality
o The Performance setting has been updated to address the sharpness of the default Quality setting causing shimmering in certain cases. It now provides a smoother filtering option that eliminates most shimmering while preserving the improved detail provided by anisotropic filtering.
* Tessellation Controls
o Supported on the ATI Radeon HD 5000 Series and the AMD Radeon HD 6000 Series
o New settings give users full control over the Tessellation levels used in applications.
+ The default selection “AMD Optimized” setting is intended to set the best level of Tessellation on a per application basis. The “AMD Optimized” setting is designed to help users get the maximum visual benefit of Tessellation, while minimizing the performance impact associated with enabling Tessellation. Currently no applications have been profiled.
+ The “Use Application Settings” option gives applications full control over the Tessellation level.
+ Users can also manually set the maximum tessellation level used by applications with the slider control
* Morphological Anti-Aliasing support for the ATI Radeon HD 5000 Series
o AMD Catalyst now includes official support for Morphological Anti-Aliasing for the ATI Radeon HD 5000 Series
Support Video Quality settings during Blu-ray 3D playback
* Supported on the AMD Radeon HD 6000 Series
* Requires Blu-ray 3D player software, 3D supported display and 3D Stereoscopic glasses
* Users can now enable the Video Quality settings within the Catalyst Control Center when playing Blu-ray 3D content
Performance Improvements:
* Call of Duty: Black Ops:
o Performance increases up to 11% on ATI Radeon™ HD 5000 Series single card configurations with anisotropic filtering and anti-aliasing enabled
* Batman Arkham Asylum:
o Performance increases up to 4% on ATI Radeon™ HD 5000 Series single configurations with anisotropic filtering and anti-aliasing disabled.
Resolved Issues for the Windows 7 Operating System
This section provides information on resolved known issues in this release of the AMD Catalyst™ 11.2 software suite for Windows 7. These include:
* Corruption is no longer randomly observed running the Unigine Heaven benchmark.
* Texture corruption is no longer observed when running the Unigine Heaven benchmark with Super AA enabled in the Catalyst Control Center.
* HAWX no longer intermittently displays corruption when running in DirectX 9 mode.
* Visual corruption is no longer seen when running Lost Planet in DirectX 10 mode.
* Playing a 720p WMV format file no longer randomly causes laggy system performance.
* Video corruption no longer intermittently affects the display when playing a SD format DVD using Windows Media Player.
* Choppy video playback is no longer observed when playing a DVD with interlaced content using WinDVD 10.
* 8x Anti Aliasing is now correctly listed as available with certain 3D applications.
* The AMD Ladybug demo no longer freezes when viewed in camera mode.
* DirectX 9.0 games no longer show intermittent corruption at the bottom of one of the cloned displays.
Resolved Issues for the Windows XP Operating System
* Flickering is no longer randomly observed when applying Video Gamma settings.
* The system no longer hangs intermittently when playing Medal of Honor.
* Civilization V no longer generates a VPU Recovery faulty when Crossfire mode is enabled.
* Warhammer – Dawn of War 2 no longer randomly displays a wireframe when running at High game settings.
Known issues under the Windows 7 operating system
The following section provides a summary of open issues that may be experienced under the Windows 7 operating system in the latest version of AMD Catalyst™. These include:
* Texture corruption may be randomly observed when task switching from OpenGL applications with Super AA enabled.
* Texture corruption may be randomly observed when swapping displays with Open GL applications running and Super AA enabled.
* 3D Mark Vantage benchmark may randomly hang at the end of the benchmark.
* Playing Bioshock may display random corruption with Vsync and MLAA enabled.
* Water textures may display flickering in World of Warcraft with the AA filter set to “Edge Detect” and Crossfire enabled.
* Visual corruption may be randomly displayed playing Dirt2 in DirectX 11 mode and driving through water.
Known Issues under the Windows Vista Operating System
The following section provides a summary of open issues that may be experienced under the Windows Vista operating system in the latest version of AMD Catalyst™. These include:
* World of Warcraft may fail when alt-tabbing out and into the game.
Known Issues Under the Windows XP Operating System
The following section provides a summary of open issues that may be experienced under the Windows XP operating system in the latest version of AMD Catalyst™. These include:
* Civilization V may stop responding during launch.
* Texture corruption may be observed running Quake 4.
* AVIVO settings my stop working intermittently.
Known Issues under all Windows Operating Systems
The following section provides a summary of open issues that may be experienced under all supported Windows operating systems in the latest version of AMD Catalyst™. These include:
* LCD Overdrive settings may be lost when enabling/disabling Crossfire.
* OpenCL™ 1.1 conformance tests have not been run with this version of the AMD Catalyst™ Driver Suite and the ATI Stream SDK v2.3. If you require an OpenCL™ 1.1 conformant driver, we recommend that you install the AMD Catalyst™ 10.12 Driver Suite.
New Features:
