Conector SATA-> IDE
mash
Fala galera,
Dando uma fuçada pela net e encontrei este conector, que converte IDE para SATA. :thumbs_up
LINK: SATA -> IDE
LINK DO SITE: SITE AKASA
Alguém sabe aonde consigo encontrar? Já procurei em vários sites e não achei, entre eles no Boa Dica e no SP1000.
Valeu quem puder ajudar!
mash
Então, vindo da AKASA deve ser um produto de qualidade!
A taxa de transferência deve ser a mesma coisa.
E lá fora, parece que está 20 dólares
Olha vários links!
BYTECC BT-200 USB2.0 to IDE Cable With Power Adapter - Retail
Features: The USB2.0 to IDE Drive Adapter implements a bridge between one USB port and one ATA or ATAPI based mass storage device port. The USB 2.0 to IDE Drive Adapter turns any IDE drive into a convenient external drive.
Specifications: Connect any device with an IDE Interface to a PC with USB interface Transfer rate Approx. 480 MBps Complies with ATA/ATAPI-66 Spe. V1.0 Backwards compatible to USB1.1 standards Supports ATA/ATAPI CD-ROM/R/RW DVD-ROM, 2.5" and 3.5" Hard Drives with the same cable External power adapter for IDE/ATAPI devices Microsoft Windows 98/98SE/ME/2000/XP
http://www.newegg.com/Product/Product.asp?Item=N82E16812156101
SYBA SD-SATA-IDE Serial-ATA to IDE Adapter - Retail
Features: Silicon Image SIL3611 Chipset Support ATA PIO and UDMA modes Serial-ATA 1.0 specification compliant Power-On and Read/Write access LED indicators Plug & Play and Hot-swapping capability Support Windows 98SE/ME/2000/XP Operating System Retail Box
http://www.newegg.com/Product/Product.asp?Item=N82E16822998001
SABRENT SBT-SCIDE Serial ATA to IDE Ultra ATA-100/133 Mini Converter - Retail
Features: This SATA-to-Ultra ATA-133 Converter Board is a converter solution for the Parallel Ultra ATA Device. It has a standard 40 pin ATA port can interface to a parallel Ultra ATA (IDE) devices (hard disk, CDROM, etc). It accepts SATA commands through the Serial ATA interface from the host, decodes the
Specifications: Supports all types of ATAPI, ATA/133, ATA/100, ATA/66, ATA/33, EIDE and IDE storage devices (such as DVD, DVD-RAM, MO, CD-ROM, CD-RW, Hard Disk) Can Attaches to all types of ATAPI, ATA/133, ATA/100, ATA/66, ATA/33, EIDE and IDE storage devices (DVD, DVD-RAM, MO, CD-ROM, CD-RW, Hard Disk, ?) 48 bits LBA
E tem mais!
http://www.newegg.com/Product/ProductList.asp?N=2010010353+4093&Submit=ENE&Subcategory=353
KinCaiD
Se eu pudesse matava MiL
bom naum deve t o msm desempenho
ia c legal c tivesse um adaptador SATA pra IDE
daria d coloka mais HDs IDE velhos q taum no armario
mash
Mas ele é um adaptador para HDs IDE para ligar na porta SATA da máquina. :p
fmthiago
GRÊMIO NADA PODE SER MAIOR
ae tenho 1 desses..... veio na placa mae de um amigo meu.... uma abit.... ele é todo pretinho tal.... imprestei pra um colega meu e ele uso no hd tach e disse q ficou a mesma coisa !
