Estou com um esquema para comprar algumas peças de pc com um amigo meu, e estou pensando em comprar a seguinte config.
Dêem suas opiniões, por favor:
- AMD Athlon 64 3000+, 512KB L2 Cache, Socket 939 64-bit Processor - Retail
- Specifications -
Model: Athlon 64 3000+
Core: Winchester
Operating Frequency: 1.8GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.5V
Process: 90 nm
Socket: Socket 939
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Warranty: 3-year MFG
Packaging: Retail(with Heatsink and Fan)
- DFI "LANPARTY UT nF4 Ultra-D" NVIDIA nForce4 Ultra Chipset Motherboard For AMD Socket 939 CPU -RETAIL
- Specifications -
Supported CPU: AMD Athlon 64 processor
Chipset: nForce4 ULTRA
RAM: 4x DIMM Supports DDR266/333/400 Max 4GB
Slots: 2x PCI-E x16, 1x PCI-E x1, 1x PCI-E x4, 2x PCI
Ports: 2x PS/2, 6x USB2.0, 1x RJ45, 2x 1394, Audio Ports
IDE/RAID: 2x ATA 133 up to 4 Devices; RAID 0,1
SATA/RAID: 4x SATA RAID with NVIDIA RAID 0,1
Onboard Audio: Realtek ALC850(8-Ch)
Onboard LAN: Vitesse VSC8201 Gigabit Phy, Marvell 88E8001 Gigabit PCI
Form Factor: ATX
- Geil Ultra Series Value Dual Channel Kit 184 Pin 1GB(512MBx2) DDR PC-3200 w/ Blue Heatspreader -Retail
- Specifications -
Manufacturer: Geil
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5 8-4-4
Support Voltage: 2.55V-2.95V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Special Features: Optimized SPD for Dual Channel DDR motherboards
Warranty: Lifetime
eVGA nVIDIA GeForce 6800 Ultra Video Card, 256MB GDDR3, 256-Bit, TV-Out/Dual DVI, PCI-E, Model "256-P2-N377-AX" -RETAIL
- Specifications -
Chipset/Core Speed: nVIDIA GeForce 6800 Ultra/400MHz
PixelPipelines: 16
Memory/Effective Speed: 256MB GDDR3/1100MHz
BUS: PCI-Express x16
Support SLI(Scalable Link Interface): Yes
Ports: TV-Out (S-Video Out) + 2x DVI
Support 3D API: DirectX 9, OpenGL 2.0
Max Resolution@32bit Color: 2048X1536@85Hz
RAMDACs: 400MHz
Retail Box (See pics for details)
E aí?
Isso vai se juntar a minha config atual, e em breve irei comprar uma raptor SATA 30 gigas pra jogar o sistema operacional.
Valeu
- Specifications -
Core: Winchester
Voltage: 1.5V
Process: 90 nm
Socket: Socket 939
- Specifications -
Form Factor: ATX
- Specifications -
Manufacturer: Geil
Bandwidth: 3.2GB/s
Warranty: Lifetime
- Specifications -
PixelPipelines: 16
RAMDACs: 400MHz
E aí?
Valeu
