Changelog:
- Add: System tray icons configuration.
- Add: Support for Intel's latest CPUs.
- Add: ClearType font support.
- Add: Time\Date column to the log file.
- Add: Always on top option.
- Fix: Core Temp does not proprerly display temperature and CPU select fields.
- Fix: Log file layout.
- Fix: Hide\Show does not properly Minimize\Restore window.
- Fix: Core code names aren't properly detected. (Intel)
- Fix: Incorrect\Missing CPU rating when not using stock\maximum multiplier. (Intel)
- Fix: Wrong CPU clock is reported when using EIST\non-maximum multiplier. (Intel)
- Fix: Wrong detection of Merom based CPUs.
- Fix: Single core Athlon 64s and Semprons reading -49C constantly. (Rare)
- Fix: C2D M0 rev. report very low temperatures. (Tjmax to 100C)
- Fix: Layout and display of tool tip text in the system tray. (Now shows a core per line)
- Change: Log the start and end of a session even if logging is disabled.
- Change: Settings and Systray settings windows appear in center of main window.
- Change: Rename "Tjunction" field to "Tj. Max" to make things clearer.
Supported CPUs:
AMD:
All Athlon64 series.
All Athlon64 X2 series.
All Athlon64 FX series.
All Turion64 series.
All Turion64 X2 series.
All Sempron series. (K8 based)
Single Core Opterons starting with SH-C0 revision and up. (K8 based)
All Dual Core Opteron series. (K8 based)
Intel:
All Core Solo series.
All Core Duo series.
All Core 2 Duo series.
All Core 2 Quad series.
All Celeron-M 400 series.
All Celeron E1000 series. (Initial support)
All Pentium E2000 and E2100 series.
All Dual Core Low Voltage Xeons series (Yonah based. Untested).
All Xeon 3000, 3200, 5100, 5300, 5400 series.
Download (Core Temp)
Supported CPUs:
AMD:
Intel:
