Changelog:
Version 0.99.3 - 22th August, 2008
- Add: Correct TjMax values for 45nm Core 2 series, according to this document.
- Fix: When TjMax = 0 (undefined) "Delta to Tjunction" was not added to the temperature string.
Version 0.99.2 - 18th August, 2008
- Fix: Start with Windows option was broken in 0.99.1.
- Fix: Default color for the second system tray icon is invisible with WinXP blue theme.
- Fix: Save screenshot function would create a corrupted BMP in some viewing software.
- Fix: Nehalem does not report VID like earlier CPUs. VID field now disabled for Nehalem.
- Fix: Incorrect 65nm Turion X2 code name detection.
- Fix: Potential bug of improper K10 and up recognition.
- Fix: Enabling distance to Tj.Max with "Highest temp." for system tray would show the largest distance to Tj.Max instead of smallest.
- Fix: Vendor ID and Device ID values were reversed in the register dump file.
- Fix: 3/4 temperatures logged for Phenom X3/X4 instead of 1.
- Add: Support for Core Temp plugins. (Still in beta phase and not in GUI yet).
- Add: Full support for AMD's Puma platform CPUs (in previous version reffered to as Griffin).
- Add: Initial support for 45nm AMD processors.
- Add: Update K8 and K10 recognition code to support all currently known CPUs.
- Add: Default TDP detection for Nehalem.
- Add: On the fly CPU speed detection.
- Add: Close to system tray option.
- Change: Log file is now produced in CSV format - easily import your logs into Excel.
- Change: Logging interval is now in Seconds instead of miliseconds.
- Change: Default logging interval is now 10 seconds.
- Change: Logging is now off by default.
Download
Download
