Sexta feira de tem novo update, segue mensagem do usar kimmundi, funcionário da FROM software no reddit.
Hello everyone,
a new update will be deployed this Friday, however the exact times are not set yet. I will add them here as soon as I know them.
I'm sorry, I won't be able to offer any more precisions to the changes, I already did my best. And you would be disappointed if you couldn't look for it yourselves, wouldn't you
I tried to make it as understandable as possible, but if you spot any worthwhile edits, please let me know.
The update will include the app version 1.05 and regulation version 1.08. It will implement the following changes:
- Archdragon Peak: Fixed the freeze when jumping into the fog after ringing the bell.
- The Rinfinger Leonhard quest will now start properly after the removal of the restriction on the maximum number of Pale Tongues that can be offered to Rosaria, Mother of Rebirth.
- Trophies will now unlock correctly even if the required item is sent directly to the storage.
- Fixed a Skill being changed based on a right hand weapon when equipping White Hair Talisman on the left hand while holding the Sacred Flame with both hands
- The Horsehoof Ring (which increases stamina drains of ATK) will no longer affect other attacks besides its initial effect on kicks.
- It will no longer be possible to equip a helm when using a Wax Pool after using the Dragon Head Stone.
- Fixed the HP drain damage of Symbol of Avarice when resting near bonfire.
- Fixed a spell animation and effect not synching up when using the magic repetitively.
- Fixed when summoning the white phantom NPC under a certain circumstance, the character's collision will properly function nullifying all enemy attacks.
- Fixed issue where skills could be performed even when a certain amount of FP was not available.
- Adjusted the attack cancel parameters of some curved swords attacks.
- Adjusted the attack power and skills of fist and claw weapons.
- Adjusted the skills of twin blade weapons.
- Fixed the scythe not penetrating shields at close distances.
- Adjusted stamina consumption and attack cancel parameters for rapier weapons.
- Adjusted the attack collision for the washing pole weapon.
- Adjusted parameters of Farron Hail and Busting Fireball.
- Adjusted casting speed, stamina consumption, cancel timing of some Spells.
- Increased the number of arrows/bolts that can be possessed.
- During online multiplayer: During the invasion of a Dark Phantom, the host will no longer be separated from his area.
- During online multiplayer: A dark phantom can no longer be forcibly brought back in some maps.
- During online multiplayer: When the player is summoned during a boss battle, the boss will no longer become motionless even after the player is back to his/her world.
- The status effects below the stamina gauge will no longer be hidden when opening the top menu with HUD display set to auto.
- The voice chat icon will now remain visible when the HUD display is set to "Auto."
- Fixed the display of strength level shown in the equipment menu when using two-handed weapon.
- Other game balance parameters have been adjusted.
- Several game flaws fixed.
Embrace the Darkness!
Adeus simple gem, que venham os frascos de estus de fp.
Vai ficar ainda mais punk usar meu Mornes Greathammer...
Mas enfim, parece dar uma balanceada legal...
