BOA NOITE. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ATUALMENTE TENHO DINHEIRO PRA MONTAR ESTE SETUP,
POREM MAIS PRO FINAL DO ANO, MUDAREI O PROCESSADOR PRA UM I3 ou um i5 USADO,
UMA PLACA DE VIDEO 1050 TI 4GB E +1 PENTE DE MEMORIA 4GB. COMPENSA OU NAO?
GOSTARIA DE SUGESTÕES OU OUTRAS OPÇÕES DO Q FAZER COM ESSE VALOR (1600)
LEMBRANDO QUE QUERO PRA USO DO DIA A DIA E JOGOS.
ATUALMENTE SERIA:
ATUALMENTE SERIA:
Gabinete: Sharkoon TG5 White Vidro Temperado 4mm Led Fan 12cm ATX
249 REAIS
Placa-Mãe GIGABYTE p/ Intel LGA 1151 mATX GA-B250M-GAMING 3 4xDDR4 64GB, HDMI, DVI, M.2 PCIe NVMe para SSD/Optane, USB 3.1 Ger 1
349 REAIS
Processador Intel Pentium G4560 Kaby Lake, Cache 3MB, 3.5Ghz, LGA 1151, Intel HD Graphics 610
239 REAIS
Fonte Corsair 450W 80 Plus Bronze CX450
218 REAIS
HD WD SATA 3,5´ Blue PC 1TB 7200RPM 64MB Cache SATA 6.0Gb/s
195 REAIS
Memória Kingston HyperX FURY 4GB 2400Mhz DDR4 CL15 Black Series
289 REAIS
Cooler para Processador CoolerMaster AMD/Intel Hyper T4 RR-T4-18PK-R1
79 REAIS
TOTAL = 1.600,00 +
