Description:
Parallax Mapping Mod is a modification for Doom3's graphics engine.
It improves all of the game's bump maps by applying a technology
known as parallax mapping, which gives surfaces more depth and
realism.
Parallax mapping is also known as virtual displacement mapping or
offset mapping. This technology, featured in the upcoming Unreal
Engine 3 and Serious Engine 2, makes bump mapped textures look
more 3D by offsetting the bumps depending on your view.
With this mod, parallax mapping is applied to all textures in the
game by using a heavily modified vertex and pixel shader. Many
of Doom3's bump map textures have been manually modifed with custom
height information to produce a true parallax effect. All other
textures use simulated parallax mapping.
Instalei aqui e ficou muito bom. As screens que tirei (todas em high)mostrando a diferença estão mais escuras e com menos definição que o normal, mas mesmo assim dá pra ter uma idéia. Não consegui tirar com o Fraps. Pra quem ainda está jogando doom3 é uma boa, mas os fps caem de 5 a 10 na média. Tem que ter VGA boa. 9500 ou FX no mínimo.
http://www.fileplanet.com/files/140000/144453.shtml
Screen1 normal
realism.
Screen1 normal
