- Este tópico foi criado para facilitar a procura, e o download dos drivers mais recentes para as placas de vídeo das fabricantes AMD e Nvidia.
- Tópico sujeito a autorização, a alterações e edições da moderação do Fórum Adrenaline sem aviso prévio.
- Este tópico será atualizado e moderado constantemente.
Local para DOWNLOADS: https://www.guru3d.com/files-details/amd-radeon-adrenalin-edition-20-12-1-driver-download.html
Ou
https://support.amd.com/en-us/download
NVIDIA
Último driver lançado: GeForce 460.79 WHQL
Local para DOWNLOADS: https://www.guru3d.com/files-details/geforce-460-79-whql-driver-download.html
Ou
http://www.nvidia.com/Download/index.aspx
AMD
Último driver lançado: AMD Radeon Adrenalin Edition 20.12.1
Ou
NOTAS
Support For
- Radeon RX 6900 Series
- Cyberpunk 2077
- Gaming applications can sometimes get stuck running at lower than expected graphics clocks on Radeon RX 6800 series graphics products.
- The HP Reverb G2 VR headset may fail to sync or may have a black screen when run with Radeon RX 6800 series graphics products.
- Tom Clancy’s Rainbow Six® Siege may experience corruption in Hybrid Graphics scenarios when using the Vulkan API on an extended display.
- Crossfire™ may experience issues when attempting to change the games resolution to a 16:9 ratio.
- Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon™ RX 5700 series graphics products.
- Brightness flickering may intermittently occur in some games when Radeon™ FreeSync is enabled, and the game is set to use borderless fullscreen.
- Some displays such as the Sceptre C series or Samsung™ Odyssey G9 series may experience an intermittent black screen on Radeon RX 6000 series graphics products.
- The Samsung™ Odyssey G9 C49G95T may experience display or corruption issues when set to 5120x1440@240hz.
- Metro Exodus™, Shadow of the Tomb Raider™, Battlefield™ V and Call of Duty®: Modern Warfare may experience intermittent application crashes with DirectX® Raytracing enabled.
- Anisotropic Filtering in Radeon™ Software graphics settings is not taking effect in DirectX®9 applications on RDNA graphics products.
- Some games may experience stuttering when set to borderless fullscreen and an extended display is connected running the Netflix™ windows store application on RDNA graphics products.
- Radeon™ recording and streaming features may fail to enable on AMD Radeon™ HD 7800 series graphics products.
- Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
- Oculus Link users may experience intermittent crashes on Polaris and Vega series graphics products.
- Screen flickering might be observed when using MSI Afterburner.
- Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
NVIDIA
Ou
NOTAS
Game Ready for Cyberpunk 2077
This new Game Ready Driver provides the ultimate gaming experience for Cyberpunk 2077. In addition, this driver provides optimal day-1 support for the official launch of Minecraft with RTX for Windows 10.
New Features and Other Changes - NVIDIA Control Panel
Fixed Issues in this Release
Windows 10 Issues
- Added Background Application Max Frame Rate control (Manage 3D Settings page)
- Added Color Accuracy Mode feature (Display > Adjust Desktop Color Settings page)
- [Forza Motorsport 7]: The curb may display a black strip during a race on certain tracks. [2781776]
- When setting the refresh rate higher than 100Hz, the color format switches from RGB to ycbcr422. [3053990]
- [GeForce RTX 3090][SLI][G-SYNC]: When G-SYNC is enabled in SLI surround (3x monitors), the system locks up when launching a game. [3167493]
- [GeForce RTX 3-series]: NvAPI_GPU_GetGPUInfo() returns an incorrect number of GPU Tensor Cores. [3140329]
- [MPC-HC]: The video player crashes when playing 1088 pixel-width videos. [3148082]
- [5k display]: When the display is set to 5k resolution, you cannot set the color settings from the NVIDIA Control Panel > Change resolution page. Either the controls are greyed out or they revert to the default after applying any change. [200630939/3182567].
Windows 10 Issues
- [Steam VR game]: Stuttering and lagging occur upon launching a game. [3152190]
- [G-SYNC][NVIDIA Ampere GPU architecture]: GPU power consumption may increase in idle mode on systems using certain higher-refresh-rate G-SYNC monitors. [200667566]
- [Freestyle][Vulkan apps]: With the freestyle filters applied, a blue-screen crash occurs when pressing [Alt+Tab] while running Vulkan applications. [200667477]
