Olá a todos!!!
Sou novo aqui no Adrenaline, então não sei se estou postando no lugar certo.
Gostaria da opnião do pessoal aqui.
Estou em duvida entre uma placa para raid com dois HDs SSD ou
Uma placa OCZ RevoDrive2.
Aqui vão as specs de cada um:
HighPoint Global website
HighPoint RocketRaid 640
Pcie 2.0 x4
Controladora Marvel 88SE9128
Interface SATA 3
Raid 0,1,5,10,JBob
Junto com ela seriam dois SSD Corsair Force 3 120g
Force Series
Unformatted Capacity 120 GB
Read Performance (max) 550 MB/s
Write Performance (max) 510 MB/s
Random 4k write (max) 85,000 IOPS (4k aligned)
Form Factor 2.5”
Interface Type SATA 3 6Gb/s
Onboard cache NA
Operating Temperature 0C to +70C
Storage Temperature -20C to +85C
Operating Humidity 10% to 90% RH (0° to +40° C)
Storage Humidity 5% to 90% RH (-10° to +60° C)
Maximum Operating Altitude 3,048 m (up to 10,000 ft.)
Maximum Non-Operating Altitude 12,192 m (up to 40,000 ft.)
Ou então o OCZ RevoDrive 3 120g
OCZ RevoDrive 3 PCI-Express SSD - OCZ
120GB Max Performance
Read: Up to 975 MB/s
Write: Up to 875 MB/s
Max Random Write 4KB (Aligned): 120,000 IOPS
PCI-Express Gen. 2 x4 interface
MLC NAND flash
Full height form factor
OCZ SuperScale Storage Controller
Virtualized Controller Architecture 2.0
Bootable as a direct-attach device
128-bit & 256-bit AES-compliant data encryption
SMART monitoring
167.64 (L) x 98.42 (W) x 15.25mm (H)
Weight: 114g
Operating Temp: 0°C ~ 70°C
Ambient Temp: 0°C ~ 55°C
Storage Temp: -45°C ~ 85°C
Power Consumption: 7.5W idle, 8.3W active
MTBF: 1,000,000 hours
3-Year Warranty
Current OS Supported: Windows 7 32/64
Ambos os sistemas tem dezempenho e preços bem relativos.
Não sei se ajuda mas a minha configuração atual:
i7 920 2.66 @3.6
Gigabyte GA-EX58-UD5
12g Corsair Dominator GT 1866
CrossFire MSI ATI-HD 6870 920/1100 @965/1200
SSD Intel x25 120g e Corsair Force 3 120g em raid 0
1HD seagate 1T
1HD seagate 500 g
1HD wd 2,5T
Desde ja agradeço a atenção!!!
Pcie 2.0 x4
Interface SATA 3
Raid 0,1,5,10,JBob
Force Series
Form Factor 2.5”
Onboard cache NA
MLC NAND flash
SMART monitoring
Weight: 114g
3-Year Warranty
i7 920 2.66 @3.6
1HD seagate 1T
1HD seagate 500 g
1HD wd 2,5T
