[TÓPICO OFICIAL] Elite Dangerous: Horizons
jr2506
CMDR JR BR
1,850
680
57
Rio de Janeiro - RJ - Brasil
Finalmente, depois de 3 meses que estou no Deadly :bua:
@Zero. PARABÉNS!!!:allgoods:
Eu ainda estou nos 30% do DEDLY! :challenge:
Bom, finalmente amanhã a FD vai estar disponibilizando o 1.4/CQC. Os servidores vão estar "fora" a partir das 4 da manhã (nosso horario local) e eles informam que o processo deve levar umas 6 horas.
As 12 horas (vulgo meio dia nosso...)vai ter um livestream com o David Braben. Link no link abaixo...
https://forums.frontier.co.uk/showthread.php?t=188010
Complementando com o que a FD reporta para voce ter uma experiencia "sem problemas com o update", aonde vai ser necessario baixar um novo LAUNCHER do store da FD, o qual deve bater com a numeração constante no texto abaixo..
Ela sugere tambem fazer copia dos seus mapeamemtos de controle.....
How to prepare for the 1.4 launch
In preparation for the v1.4 update, please check the following points to minimise any potential issues:
  • Back up any custom key bindings you may have created. These are located in the following folder on your PC: %localappdata%\Frontier Developments\Elite Dangerous\Options\Bindings
  • Please make sure that your router supports UPnP and has it enabled if you plan to play CQC (or Open Play). If UPnP is not supported by your router, please see here for a workaround.
  • A launcher update containing several fixes and improvements will be released alongside the update. To ensure you have the latest Elite: Dangerous game launcher, please get the latest launcher from our store page here and install this before updating the game. The new launcher versions releasing alongside v1.4 should be: PC v0.4.3497.0, Mac v0.4.3450.0
  • Check that the launcher is not blocked by your anti virus program or firewall, additionally check if your router has any content filtering options activated, these can interfere with the update process.
  • Planning to play CQC? Firstly check to see if your NAT type is open for the best matchmaking experience. For details on changing your NAT type, head to our support article about it here.
In general this update will be similar to the previous major patches. The servers will go down, while they are updated, the downloads for the new launcher and game client become available. As soon as both are installed and the servers come back online, everything should be good."
Valeu @almostpilot !! Sempre trazendo informações que agregam ao fórum! ;)
Nosso encontro de quinta-feira, já vai ser no 1.4!!!! Oba!!!! :allgoods:
E ainda bem que já bati a meta do UNDERMINE, pois costumo jogar 1h entre 6 e 9 da manhã!
Reações: almostpilot
jr2506
CMDR JR BR
1,850
680
57
Eles não param!!!!
200
Os imperiais estão se afundando no mar negro dos piratas!!!!!
FONTE: https://www.reddit.com/r/kumocrew/
For those of you that missed it, we won our expansion at HIP 106072 https://www.reddit.com/r/kumocrew/comments/3n2s7z/archon_delaine_invites_hip_106072_to_discover_the/
Fortification
https://www.reddit.com/r/kumocrew/comments/3n3czw/fortification_cycle_18/
Expansion
We have 3 systems on the expansion list this week.
2 of them are good, if you want to work on an expansion for Archon Delaine, go to either:
  • OR Delphini 291% vs 288%
  • Wolf 1148 317% vs 150%
Mandii is a system that will cost us CC each week, it will harm the Kumo Crew if we expand to it, steps have been taken to try to make us lose this expansion, but it is very difficult for this to happen.
Preparation
Systems that are useful for Archon Delaine are those with a high profit.
More than 60cc is preferred, but greater than 50cc is acceptable because we are situated in a low income part of the galaxy.
Usually we have preferred systems with a large station that is close to the star, but these systems are becoming harder and harder to find.
Agricultural systems are preferred over Industrial, because they will produce lower cost Narcotics and Tobacco.
This is what is currently on our Preparation list in game:
  1. Gliese 828.4, 62cc
  2. Jormor, 58cc
  3. Evejitaka, 28cc
  4. Devana, 1cc
  5. Dhak, 70cc, Small Station Only
  6. VVo 19, 57cc, it's V V o not Wo
  7. Inheimagni, 19cc
  8. Binjhwarku, -7cc
  9. Apacnada, 52cc
  10. Yuror, 56cc
You can see we really don't want Devana, Evejitaka, Inheimagni or Binjhwarku with their low cc profit per week.
We can only afford to prepare the top 4 systems, so ideally we want to push VVo 19 up to 4th in place of Devana.
Dhak has the highest cc but only has a small station, but systems like this might be what we need to expand to in the future.
Undermining
You only need 100% for undermining to be complete anything over is a waste
Operation Uranus against Patreus continues.
Patreus has a weekly starting cc balance of 184, that is, we need to undermine him for 184 more than he fortifies for him to fall back into Turmoil.
Here are some systems to focus on:
  • Turbacobo 81%
  • Paesi 4%
  • Smei Tsu 16%
  • Cuchua COMPLETE
  • Parsi 98%
  • Turir COMPLETE
  • HIP 117865 COMPLETE
  • LTT 8260 100% COMPLETE
  • Guguroro 490% COMPLETE (It really is complete!)
ODD (Operation Dead Dame) is also on the go against ALD
  • Baal 25%
  • HIP 21778 12%
  • Lutni COMPLETE
  • Nyalayan COMPLETE
  • Vodyanes 131% COMPLETE
Reações: NoVaCa Rei
Zero.
19,289
12,633
74
Somewhere in the galaxy.
steamcommunity.com
haha valeu!
Subiu mais rápido fazendo bounty hunting (porque estou ajudando um amigo novato) e indo nas conflict zones (pra ajudar o power)... rápido assim né, se dedicando em uma conflict zone sobe 1% por hora :nps:
Mas a melhor maneira mesmo é matando player :melior3:
Chico
Darktronik
38,984
12,562
73
O beta vai se apagar automaticamente do HD? Não existe uma opção de desinstala-lo...
Rash
3D vision user
1,304
120
Curitiba
www.vetorsistemas.com.br
Como as minor factions se expandem em cima das outras minor factions???
É dando "boom" interno e aumentando o campo pra cima das outras?
Zero.
19,289
12,633
74
steamcommunity.com
Se vários jogadores fizerem missões para um minor faction que não é a que comanda o sistema ela vai ganhar mais influência, com isso uma hora, contra a que comanda o sistema, pode rolar uma guerra se o tipo de governo delas for diferente ou uma votação se forem iguais.
No caso de votação não sei os detalhes, mas no caso da guerra basta ajudar a facção que você quer que ganhei a guerra nos conflict zones
NoVaCa Rei
Macaco Guia
2,026
1,768
Brasília
www.go.to
Essas instruções são legais, mas quem tem a versão steam não deve ter que fazer nada disso, atualiza automático.
Ecstaasy
1,845
709
Eu tava aqui pensando, um efeito que falta e que ficaria muito legal é o cara que esta usando o SCB ver o efeito que as pessoas que estão de foram veem. Aquela pulsação passando pelo canopy seria bem legal.
manotroll
11,341
3,912
teresopolis
Não tem nem comparação, VUlture é muito mais nave de combate, agilidade no elite em um dogfight é a melhor arma e defesa, a vulture só peca mesmo em velocidade, pra fugir ou pra pegar alguem... meu deus
mais a ASP e mult função como a cobra a vulture ele tera que fazer apenas combate
Reações: Zero.
almostpilot
Na batalha entre os dois lobos....
6,975
7,127
interior SP
Quanto ao "mapeamento dos controles" o risco é o mesmo pra quem tem steam ou não. Ha muitos casos de gente que perde esta configuração apos updates. Quanto ao Launcher eu não sei mesmo, mas vou baixa-lo da store da Fd por via das duvidas....
manotroll
11,341
3,912
teresopolis
mais so vale pro link de amanha ou pode baixar hoje ?
Mity-RB
CMDR Mity-BR
741
941
Onde posso encontrar Beam laser Gimball 3C? Já rodei 6 sistemas hitec e nada....:mas:. Pra dar um Up na vulture.
Rash
3D vision user
1,304
120
Curitiba
CQC não ta rolando??? Fiquei um bom tempo fora do E:D e não joguei o CQC.. baixei agora.. e nao acha game nenhum :mad::mad::mad:
almostpilot
6,975
7,127
interior SP
Segundo a FD, os dois(launcher e update) somente a partir das 4 de la matina.
Da uma lida no primeiro post desta mesma pagina. Ha uma grande chance de estar fora por conta disso....
Mity-RB
CMDR Mity-BR
741
941
Tem como tirar ou diminuir a intencidade das linhas de orbita no hud do hipercruyse? Tira um pouco a beleza do jogo minha opinião
manotroll
11,341
3,912
teresopolis
hum... que pena
agora vai demorar pacas pra baixar
gabrielmeiser
"..O segredo para a imortalidade?..não morra.."
2,533
539
Rj
Queria agradecer a colaboração da galera que tava hj no TS comigo e q entendeu meu problema quando eu pedi ajuda sobre n ta enxergando meu HUD
Ficaram rindo e mandaram eu apertar alt-F4...
Eu ainda to na busca desde as 20:00 tentando solucionar ja apaguei o arquivo q altera as cores do hud e dei Repair mas continua...
manotroll
11,341
3,912
teresopolis
apaga tudo dentro desta pasta
e tenta novamente
Reações: gabrielmeiser
Cartesius
225
Pessoal, alguém sabe onde acho o manche T-flight HOTAS X para comprar?...
Ou então vocês tem alguma sugestão de joystick maneiro para usar e que esteja mais presente no mercado?
Vou de XBOX360 Controller enquanto isso...
almostpilot
6,975
7,127
interior SP
No painel que voce abre a direita no cockpit, na ultima aba dele, tem uma opção pra desabilitar as linhas....
Reações: Mity-RB
