[TÓPICO OFICIAL] Elite Dangerous: Horizons
almostpilot
Na batalha entre os dois lobos....
6,975
7,126
interior SP
É vamos ver ao final do beta como ela vai ficar, eles vão aumentar a taxa do pitch and roll dela, por, como voces falaram o power plant maior classe 6 e tornar o resfriamento dela melhor. Com certeza vai ser uma nave de combate muiot boa(Se é que ja não era...)
O problema agora é a lista de pedidos pra fazer isso com "essa" e "aquela" nave...eu queria com a Python tambem:feelbad:
ErickTakada
Engenheiro Civil
407
249
12
Anápolis, Goiás
igual tu falou, a Fer-de-Lance já é uma nave boa para combate, é perigoso ela ficar OP kkkk
almostpilot
6,975
7,126
interior SP
Update para o Beta..
Agora a Cutter vai passar pela grade de torradeira....rs
novo SCB e FDL buffada....
Quem puder testar durante o dia...poste aqui como ficou...
Hey guys,
Quick update to let you know a new beta build is incoming. It should be here at 11am and the beta servers downtime will be roughly 30 minutes.
Here are the patch notes.
- Various server reliability fixes
- Fix Cutter not passing through docking port with landing gear up
- Made Cutter's cargo bay move down when deployed to allow for easier cargo pickup and fixed orientation of tiny hardpoints
- Left and right panels are smaller in 1.5 than 1.4
- Some Piracy missions now have their mission cargo overridden properly.
- Make missions unavailable to players in ships that cannot land at all stations during a mission
- Changes to when reward is displayed on panels and BB
- Assassination crash fix where system was trying to use the wrong ship
- Decrease mission respawn time and number of missions
- Don’t Die text fixes
- Fix for times in the past being mistaken for times in the future
- Make some assassination targets more likely to spawn
- Make some missions clearer to understand via timer’s etc.
- Fixed some ship names in the local traffic reports
- Fixed refuelling reserve tanks
- Update Viper MkIII descriptions to reflect the addition of the MkIV
- (all languages) Powerplay statistics tab missing translations
- Re exported Type 6 debris with charred materials
- Fixed Galaxy Map FOV cutting off the side panel
- Some missing Spanish and tweaks added
- Various text fixes
- Temporarily remove the new damage decals until a proper fix can be implemented
- Doubled the time a shield cell is actively providing a benefit
- Increased the amount of heat a heat sink can drain and doubling the time over which it drains it
- We are adding a small amount of thermal and kinetic resistance to hull reinforcement packages, again, increasing their effectiveness, including versus module damage
- Increased the maximum speed of recovery for collapsed shields (especially larger shields)
- Increased the manoeuvrability of the FDL, increasing its power plant capacity and increasing its heat dissipation
- Fixed Corvette hangar cameras
- Fixed orientation of Corvette's tiny hardpoints
- Fixed Corvette's collision so point defences work properly
- Make sure mission targets have the correct cargo
- Added missing discovery scanners to the Asp Scout, Imperial Clipper and Federal Assault Ship
- Bobbleheads should only render when inside the cockpit
Lorcar
1,572
456
Visitar Site
Se eu comprar o Horizons hoje eu ganho acesso ao beta ?
almostpilot
6,975
7,126
interior SP
ErickTakada
Engenheiro Civil
407
249
12
Anápolis, Goiás
Galera, eu concordei com o @CMDR BRUNN em criar o subreddit, mas eu parei pra pensar: a gente já tem o site do elite dangerous brasil que já tem o propósito de reunir o pessoal, então acho que não rola criar subreddit pra gente...
Lorcar
1,572
456
Visitar Site
Comprei, como faço para ter acesso ao beta...meu Elite Dangerous original foi comprado via steam...loguei mas não apareceu para baixar...
almostpilot
6,975
7,126
interior SP
rapaz tu é apressado....perguntasse antes....vc só vai ter acesso a partir do dia 24(data prevista) para lançarem o Beta....apesar que ja é a semana que vem...
O Beta agora é do 1.5 somente
e se viu se vc tinha desconto ja por ter o ED?
almostpilot
6,975
7,126
interior SP
Eu ia dizer isso pra voces, inclusive quem postou aqui pedindo autorização tambem citou que estão fazendo um site, não foi isso?
Lorcar
1,572
456
Visitar Site
Porra !!!!!!!!!!!!!!!!!!!!!:bwahaha::bwahaha::bwahaha::bwahaha::bwahaha::bwahaha::bwahaha::bwahaha: Trolado...como faço para ter acesso aos testes do Beta 1.5 ? Comprando o Horizons eu não tenho ? :medo::medo::medo::medo::medo::medo::medo:
almostpilot
6,975
7,126
interior SP
Não.....:coolface:
Mas ja é a partir de terça que vem(previsto), então menos mal...
Lorcar
1,572
456
Visitar Site
Nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
:vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader::vader:
Reações: almostpilot
ErickTakada
Engenheiro Civil
407
249
12
Anápolis, Goiás
Não.....:coolface:
Esse povo rico gastando dinheiro a rodo aí, tem crise não hein kkkkkk
CMDR BRUNN
DOG FIGHTER
1,895
1,467
Erick, o site não é interativo. Não é um espaço de discussão. O reddit sim foi feito pra isso. Pra galera interagir, discutir estratégias, etc. O site eu vejo como meio de divulgar comunicados e nada mais. O TS não tem participação massiva. Então fica esse vácuo na comunicação efetiva sobre estratégias entre os players da facção que só um reddit poderia resolver.
Volto a afirmar que se não tiver essa organização como existe para os poderes, nossa facção vai ser só "mais uma". Com a organização no reddit dos poderes o pessoal já faz lambança, imagina se não tivesse? Isso que vai ocorrer se a gente não tiver esse espaço pra se organizar e centralizar as estratégias, compartilhar ideias, etc.
Reações: ErickTakada
ErickTakada
Engenheiro Civil
407
249
12
Anápolis, Goiás
Tá criado então mano. A jogada agora é criar todo o código de formatação para a página, e para isso eu não tenho conhecimento.
Me passa seu nome de usuário do Reddit para eu poder te colocar como Mod.
Reações: Chico e CMDR BRUNN
CMDR BRUNN
DOG FIGHTER
1,895
1,467
Boa! Eu sei HTML :)
É "Kazulo". Coloca o @jr2506 tb pra ele postar os tutorias sobre facções! Rola @jr2506???
Lorcar
1,572
456
Visitar Site
Pessoal, depois da compra do Horizons começou a dar um erro no game...poderiam confirmar se na tela do load a versão do servidor e do game que aparecem para mim é a mesma que para vocês, tive um erro de mismatch e depois não consegui mais jogar aqui...
Segue a imagem que aparece para mim... embaixo do play 0.4.3842.0 (0.4.3497.0 SERVER)
É a mesma que aparece para vocês ?
ErickTakada
Engenheiro Civil
407
249
12
Anápolis, Goiás
mas não saiu nem o beta do horizons, então não tinha que dar erro '-'
Boa! Eu sei HTML :)
Adicionei você lá, quanto ao @jr2506 eu preciso do nome dele lá no reddit
Brunn, qual seu nick na steam?
Lorcar
1,572
456
Visitar Site
Erro de sem resposta do servidor...
No or empty response form server...nunca tinha tido isso...é hoje...
Chico
Darktronik
38,984
12,562
73
Issues detected no status do servidor
é o servidor que caiu mesmo.
Sometimes you can just see something is bad game design without testing it. SCBs (the base concept) are just plain broken. They were broken the day someone stuffed their Anaconda with SCBs and it worked, with the only inconvenience being they had turn some on or off. Really, this should have been evident from the conception.
As to why not limit them to one per ship, that's just so it's not an artificial constraint, which makes sense to me. What doesn't make sense is the acrobatics they're doing to keep SCBs in the game, which are ruining other parts of the game which were perfectly fine.
jr2506
CMDR JR BR
1,850
680
57
Rio de Janeiro - RJ - Brasil
Boa! Eu sei HTML :)
@Lorcar, @almostpilot, @Freemam_BR e demais
É claro que eu contribuo, mas gostaria de sugerir usarmos o forum do próprio Elite Dangerous Brasil (elitedangerousbrasil.com.br). E ainda iria sugerir incluirmos lá um tópico para a BLP.
Essas sugestões são pelo fato de que tenho visto muitas iniciativas e pouca gente para dar conta de tudo. Não que não tenha gente, tem sim, mas acabamos ficando descordenados e manter conteúdo atualizado não é fácil.
No meu caso, faço os Tutoriais com gosto, mas atualizá-los em mais de um local é trabalho dobrado.
E fique claro, estou com vocês! Se estiverem dispostos a mais uma iniciativa eu participo sim, ao menos tento!
Eu gostei do formato do fórum do Elite Dangerous Brasil (EDB) que o Constantino fez, já tem o Canal no YouTube que o CMDR ROOTBR mantêm, tem também o Facebook do EDB.
O nome Elite Dangerous Brasil é o que mais atrai os players brasileiros, então eu gostaria de usar isso a nosso favor. O TS deles também está bem movimentado.
Se concentrarmos nossos esforços nessas iniciativas, podemos crescer bastante nossa comunidade. E depois sim, abrir outras frentes.
Mas repito, estarei apoiando sempre que possível qualquer iniciativa que divulgue o jogo aos BRASILEIROS! Sem essa de bandeira A ou B, ou grupo C ou D.
Abraços
EDIT.: Só li com atenção depois e vi que o @ErickTakada criou. Assim, a sugestão é que seja uma página bem simples para podermos mantê-la. Meu usuário lá (REDDIT) é: jr2506
Freemam_BR
"THIS IS SPARTA!!!!"
1,441
398
Não acho que o reddit seja o local ideal para gerar conteúdo sobre a blp, pois como ele é em ingles , , acredito que grande maioria nem olha as paginas do redit, digo isso por mim mesmo e raro quando passo lá pra ler algo pois preciso usar tradutores, apesar de ja entender um poco de inglês, porem as vezes se faz necessário alguma ferramenta de tradução pra que eu tenha certez se entendi corretamente o que esta descrito, e convenhamos nem todo mundo se da esse trabalho, mesmo com tutoriais em pt-br , muitos nem se preocupam em aprender e estudar o game antes de começar.... Bem continuando o reddit é semelhante aqui ao foro do adrena e com o passar das paginas a informação se perde nas muitas paginas da discussão e recuperá-la nem sempre é uma tarefa fácil... portanto acho que o melhor mesmo e manter toda e qualquer informação acerca da BLP, no fórum do elite brasil, onde o conteúdo gerado pode ser facilmente acessado e atualizado e considero que discussões sobre o rumo da minor facção dever ser feitas em um local onde o acesso seja restrito a comunidade a quem ele interessa a salvo da interferência de terceiros, o que não ocorre no reddit.... onde o grupo de player que atualmente esta a frente disso em conjunto decidira qual o melhor caminho a seguir....
almostpilot
6,975
7,126
interior SP
Bom eu vou falar por mim, porque vc me citou né junior. Eu não sou muito obediente e sou até mesmo rebelde em seguir "grupos"...rs...eventualmente eu posso ajudar, como fiz com algumas missões la no sistema do BLP...mas fico sempre distante..não me levem a mal. Mas adoro divulgar o jogo como um todo.
Eu mesmo nunca me cadastrei no site do BLP do enjim, por razões pessoais(se tiverem duvida me questionem por MP aqui), mas mesmo de fora ta bem confuso, pois tem o site do enjim e tem o elitedangerousbrasil? Nossa da ultima vez que vi esse site/forum tava mais morto do que qualquer outra coisa. Mas voces que sempre estão juntos definam um lugar em comum que todos vcs acessem...se for o caso.
Como esta o forum la do elitedangerousbrasil junior? vivo?
Reações: Chico
Chico
Darktronik
38,984
12,562
73
Vou te acompanhar nessa e me expressar dizendo que sinceramente fiquei desestimulado com as constantes migrações de TS,grupos, etc e aumento de pessoal e falta de identidade que acabou se ocorrendo.
Somos/fomos do grupo do fórum (adrena gangue) para algo "maior" com pessoas desconhecidas com outros objetivos ou com objetivos em andamento. Não me entenda mal, conhecer e agregar é sempre bom, mas nao acho que se deva perder a identidade individual, a únidade como grupo em favorecimento de projeto de terceiros, mesmo com interesses maiores em comum.
Eu sou essencialmente daqui e a gente mal conseguia se entrosar corretamente (ces choram demais :haha:, né junior, esctasy :coolface:), quiça com mais de 10 cabeças novas.
Caí num TS desse site, no dia do nosso evento que não ocrreu como combinado, onde debatiam sobre outra coisa (na verdade foi um monólogo), com um monte de gente que nao conhecia.
E sinceramente TS é bom, mas nao se comunica com 30 cabeças na mesma sala. Todos falam. Ninguem ouve.
Acho a ideia do reddit do BLP ótima, pois ainda me manterá aqui, mas quando eu quiser socializar em prol de uma causa única, que é o BLP, estarei lá, assim como faço/fazia com Sirius.
E apesar do BLP ser de todos os brasileiros, o zero é nossa ponte de contato com a frontier para tratar de "administrar" a facção, então de certa forma, é um grupo/facção sim do adrena, mesmo que indiretamente. Tentem assumir a liderança disso e não ratificar muito isso de é de todo mundo, pois bem ou mal, isso vai precisar sim de organização e liderança (principalmente no reddit) para decidir objetivos, principalmente caso vire um powerplay.
E eu confio nas decisões e posições do Zero e Erick (estratégia), do Junior e Esctasy (combate), almost (exploração) quanto a isso.
Procurem manter a unidade. Isso não quer dizer que nao possam socializar e formar aliança externamente.
Volto a jogar depois de Horizons e de zerar/enjoar F4 :coolface:
