eMule 0.47c oficial
Shinkirou
TOKYO 2016
Lançado eMule 0.47c OFICIAL:
v0.47c Hotfix
- Sep, 14. 2006 -
.: Fixed some major bugs in Kad 2.0 source/keyword publishing
- Sep, 13. 2006 -
.: Fixed Kad bug with processing Kad1.0-Packets which is believed to be remotely exploitable and therefore a potential risk if Kad is enabled [found by tHeWiZaRdOfDoS]
.: Fixed bug with lost setting for disabled UDP port.
.: Fixed bug in First Runtime Wizard with previously disabled UDP port.
.: Added more sanitizing for Kad packages to ignore all unrequested packets
- Sep, 11. 2006 -
.: Fixed some Kad memory leaks in exception handlers [tHeWiZaRdOfDoS]
.: Tweaked reading of "addresses.dat" and "shareddir.dat" files to skip spaces and empty lines.
.: Fixed bug with wrong file type mismatch warning for multiple selected part files.
DOWNLOAD: http://prdownloads.sourceforge.net/emule/eMule0.47c-Installer.exe
MrDuckGod
Mr. DuckGod
UP!
Baixando...
Gargula
Gamer since 1994!
Alguem sentiu alguma melhora?
Eu to com o E-Mule Plus 1.1f e por enguanto esta bom.
Se alguem falar que deu melhoras, ai sim eu baixo :)
MrDuckGod
Mr. DuckGod
MrDuckGod
Mr. DuckGod
Saiu a versão 0.47C Build 2: As melhorias são:
- Updated LinkCreator to 0.7, LinkCreator can be used to create ed2k links with or without hashset
- Updated the IP blocklist, this will prevent a lot of computers who monitor filesharing activity or spread fake files from making a connection
- Updated the included links to sites with verified files
- Improved the default configuration
- Minor fixes and improvements
Download aqui e aqui.
MrDuckGod
Mr. DuckGod
Não sei, postei a noticia pq os links são de sites conhecidos. Pode ser que seja um beta leaked da vida...
EDIT...
Baixei aqui para ver as diferenças, e porem nada significativo. O instalador possui mais opçoes.
    7.8 KB · Visitas: 37
