Agger não sai tão caro hein! Acho que não vai ganhar grana com ele!
Muito interessante as propostas desse user do fórum da EA para o UT 13... Quer quiser ler, em inglês no spoiler!
Here are some ideas for Fifa Ultimate Team 13. Take in mind that this is just IDEAS.
- A H2H season system in Ultimate Team aswell. Because the current tournament/single matches are getting boring and repetitive and a H2H season gametype would spice it all up a bit. Maybe there could be a coin reward when moving into a new division.
Matchmaking should be done based on your team rating. <This making silverteams and bronze teams still usefull.
But also they should then add a cup system along with the divisions as there is in H2H seasons. Maybe they could add some under 21 cups or over 30´s. < That would be amazing!
- Remove the 10k+ discard value for IF´s. It makes it soooooo boring. Cause a players price should not be determined whether the card is black or not. It should be determined by how good the player is. No one want to pay 10k+ for a player that isnt worth it, when you can get a better player for 1-2k instead.
- Take away the position cards and replace them with cards which has the choice of you putting a player anywhere. Explaining it all down below:
1. Ending of XX > YY
Why? It´s hard to find the exact cards, and some players arent currently able to play in certain positions that they are used to irl. Just make one card for each position.
Ex: CM card, using on the player, then he'll be a CM. (but he must be able to play in this position > Part 2)
2. Positions that the player is capable of playing.
In the game, you can see that every player have some positions that he is capable of playing
Ex: Wilshere. CDM - CM - RM - LM - CAM. Right now, you can turn him into a CDM, CM, CAM, CF, STR (unrealistic)
Add on the players bio/info (right stick) his capable positions. You can just use the RM card, done. He's a RM now. No more lacks of good players in certain positions in game, giving more options...
- A few changes to the chemistry system, maybe this:
Players under the age of 21 should get links and chemistry together no matter league or nation, making those kinds of teams really fun to build and age finally getting important in UT.
- Ability to save workrates and tactics in the actual FUT menu.
- More formations and/or the ability to create custom formations in the actual FUT menu.
- Changes to the contain system so that it isnt as effective to just hold that A button the whole game. It makes the game booring and slow-paced. For instance if I make a skill move or a quick turn, the defender should sometimes loose balance and get lost out of position. The way it is right now, is just too robotic and unrealistic.
- Remove the attribute boost cards.
- Ability to create kits and badges.
- Wager matches.
- Winning streak multiplier.
- Limit on consumables, maybe 5k?
- More 5* star skill players as the current selection of what players that get 5 star skills and not, is bad.
- Ability to cash in your UT12 coins for UT13 Packs, For example 100k could be 1 pack.
- Remove the limit of items allowed in the trade pile or atleast make it higher. Also a limit of max. 5 duplicates in the trade pile to eliminate price-fixing.
- Ability to search on a certain formation/position card rather then spending several minutes trying to find the one you want.
- Option to edit the kit numbers.
- Remove the leaderbords due to the hackers.
- Squad formation and contract cards.
- Remove the injuries or make them more rare.
- More availible leagues such as the Ukranian and the Turkish league.
- More availible players in the smaller leagues.
- Change the current "rising and lowering your bid/sale in the trade pile", to the way it is in the career mode. Where you can press Y and then make the amount higher/lower quicker.
- Ability to search on name for auctions.
- Ability to search for rating, example: 77-82.
- Ability to search for a special rating, example: min. heading 81.
- Ability to search for age.
- Ability to choose the weather.
- An ability to search for inform players only.
- Add assists, goals per shot, average match rating, etc. in the player stats.
- Reset the stats tracked on a card when a new owner buys it.
- Ability for the game to mutually end as a draw. For example if the kits turn out to be too similar, its snowing or raining and you cant see the ball, or its lagging really bad, one player can propose to end the match as a draw and the other can accept or decline.
- Fix the pace stats! No way Mertesacker is 4 times as slow as Ronaldo in real life. The thing is, pace difference is so minuscule in irl, most of the best players are around as fast. Not exactly the same but they are all fast! Therefore almost all gold players should have atleast 60 + in pace. EA got it so wrong when it comes to the pace stats. FIX THIS! It would also make pace-abusing less common aswell as it would make pace less important...
Remember all these ideas arent all "mine". But i think that they are all really good. The question is do you like them? And do you have some more suggestions?
Hopefully EA will look at the community of what they really want and take that into consideration when creating FUT 13.
Final question, could this thread be sticky?
sim sim concordo que o agger vale pouco , mas paguei 1k nele na formação 4-1-2-1-2 acho que vender por 2k pra ganhar 1k+ da sim..
gostei das sugestoes desse cara até que tem muito sentido oq ele falou , mas acho dificil a EA aceitar essas sugestoes para o proximo fifa..
acho que nesses tots ja devem vim com aquelas cartas coloridas da euro...
