Resolvi fazer esse tópico pq vejo muitos usuários aqui do Adrena com essas mobos e tendo um tópico específico poderemos trocar informações sobre elas !!!
Diegodiniz
cmlbrasil
Wester
JEFFER5ON
Montana.nF
Kaminahrri
Vicalvi
Tiago Piloneto
poisonmaniac
HumbertoPC
laureanoleme
__________________________________
GA-P67A-UD3-B3
![4092.jpg](http://www.gigabyte.com/fileupload/LineImage/2/3765/4092.jpg)
Descrição
CPU
1. Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package (Go to GIGABYTE's website for the latest CPU support list.)
2. L3 cache varies with CPU
Chipset
1. Intel® P67 Express Chipset
Memory
1. 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2. Dual channel memory architecture
3. Support for DDR3 2133/1866/1600/1333/1066 MHz memory modules
4. Support for non-ECC memory modules
5. Support for Extreme Memory Profile (XMP) memory modules
(Go to GIGABYTE's website for the latest supported memory speeds and memory modules.)
Audio
1. Realtek ALC892 codec
2. High Definition Audio
3. 2/4/5.1/7.1-channel
4. Support for S/PDIF Out
LAN
1. 1 x Realtek RTL8111E chip (10/100/1000 Mbit)
Expansion Slots
1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
2. 1 x PCI Express x16 slot, running at x4 (PCIEX4)
* When the PCIEX1_2 or PCIEX1_3 slot is populated with an expansion card, the PCIEX4 slot will operate at up to x1 mode.
3. 3 x PCI Express x1 slots
(All PCI Express slots conform to PCI Express 2.0 standard.)
4. 2 x PCI slots
Multi-Graphics Technology
1. Support for ATI CrossFireX™
* The PCIEX16 slot operates at up to x4 mode when ATI CrossFireX™ is enabled.
Storage Interface Chipset:
1. 2 x SATA 6Gb/s connectors (SATA3_0, SATA3_1) supporting up to 2 SATA 6Gb/s devices
2. 4 x SATA 3Gb/s connectors (SATA2_2, SATA2_3, SATA2_4, SATA2_5) supporting up to 4 SATA 3Gb/s devices
3. Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
USB Chipset:
1. Up to 12 USB 2.0/1.1 ports (8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Renesas D720200 chip:
1. Up to 2 USB 3.0/2.0 ports on the back panel.
Internal I/O Connectors
1. 1 x 24-pin ATX main power connector
2. 1 x 8-pin ATX 12V power connector
3. 2 x SATA 6Gb/s connectors
4. 4 x SATA 3Gb/s connectors
5. 1 x CPU fan header
6. 2 x system fan headers
7. 1 x power fan header
8. 1 x front panel header
9. 1 x front panel audio header
10. 1 x S/PDIF Out header
11. 2 x USB 2.0/1.1 headers
12. 1 x serial port header
13. 1 x clearing CMOS jumper
Back Panel Connectors
1. 1 x PS/2 keyboard/mouse port
2. 1 x coaxial S/PDIF Out connector
3. 1 x optical S/PDIF Out connector
4. 8 x USB 2.0/1.1 ports
5. 2 x USB 3.0/2.0 ports
6. 1 x RJ-45 port
7. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/ Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
1. iTE IT8728 chip
H/W Monitoring
1. System voltage detection
2. CPU/System temperature detection
3. CPU/System/Power fan speed detection
4. CPU overheating warning
5. CPU/System/Power fan fail warning
6. CPU/System fan speed control
*Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1. 2 x 32 Mbit flash
2. Use of licensed AWARD BIOS
3. Support for DualBIOS™
4. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
1. Support for @BIOS
2. Support for Q-Flash
3. Support for Xpress BIOS Rescue
4. Support for Download Center
5. Support for Xpress Install
6. Support for Xpress Recovery2
7. Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
8. Support for Dynamic Energy Saver™ 2
9. Support for Smart 6™
10. Support for Auto Green
11. Support for eXtreme Hard Drive (X.H.D)
12. Support for ON/OFF Charge
13. Support for Cloud OC
14. Support for Q-Share
Bundle Software
1. Norton Internet Security (OEM version)
Operating System
1. Support for Microsoft® Windows® 7/Vista/XP
Form Factor
1. ATX Form Factor; 30.5cm x 21.5cm
Remark
1. Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2. Most hardware/software vendors no longer offer support for Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
GA-P67A-UD4-B3
![4089.jpg](http://www.gigabyte.com/fileupload/LineImage/2/3759/4089.jpg)
Descrição
CPU
Chipset
Memory
Audio
2/4/5.1/7.1-channel
Support for Dolby® Home Theater
LAN
Expansion Slots
1 x PCI Express x16 slot, running at x8 (PCIEX8) * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
2 x PCI slots
Support for ATI CrossFireX™/NVIDIA SLI technology
* The PCIEX16 slot operates at up to x8 mode when ATI CrossFireX™ is enabled.
Storage Interface
Chipset:
Marvell 88SE9128 chip:
2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
Support for SATA RAID 0 and RAID 1
USB Chipset:
Up to 14 USB 2.0/1.1 ports (8 on the back panel, 6 via the USB brackets connected to the internal USB headers)
2 x Renesas D720200 chips:
Up to 4 USB 3.0/2.0 ports (2 on the back panel, 2 via the USB brackets connected to the internal USB headers)
1 x CPU fan header
3 x USB 2.0/1.1 headers
1 x USB 3.0/2.0 header
2 x eSATA 6Gb/s ports
1 x RJ-45 port
I/O Controller
iTE IT8728 chip
H/W Monitoring
BIOS
2 x 32 Mbit flash
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Q-Share
Bundle Software
Operating System
Form Factor
ATX Form Factor; 30.5cm x 24.4cm
Remark
GA-P67A-UD5-B3
![4081.jpg](http://www.gigabyte.com/fileupload/LineImage/2/3762/4081.jpg)
Descrição
CPU
Chipset
Memory
Audio
Realtek ALC889 codec
2/4/5.1/7.1-channel
LAN
Expansion Slots
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated with a PCI Express graphics card, the PCIEX16 slot will operate at up to x8 mode.
* The PCIEX4 slot shares bandwidth with the PCIEX1_1 and PCIEX1_2 slots. When the PCIEX1_1 slot or the PCIEX1_2 slot is populated with an expansion card, the PCIEX4 slot will operate at up to x1 mode.
2 x PCI Express x1 slots
2 x PCI slots
Support for 2-Way ATI CrossFireX™/NVIDIA SLI technology
(The PCIEX16 and PCIEX8 slots only.)
4 x SATA 3Gb/s connectors (SATA2_2~SATA2_5) supporting up to 4 SATA 3Gb/s devices
2 x eSATA 6Gb/s connectors (eSATA/USB Combo) on the back panel supporting up to 2 SATA 6Gb/s devices
USB Chipset:
Up to 10 USB 2.0/1.1 ports (6 on the back panel, including 2 eSATA/USB Combo, 4 via the USB brackets connected to the internal USB headers)
1 x Renesas D720200 chip and 2 x VLI VL810 hubs:
Up to 8 USB 3.0/2.0 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers)
* The USB 2.0 signals of the 4 USB 3.0/2.0 ports on the back panel are from the Chipset.
IEEE 1394 T.I. TSB43AB23 chip:
Up to 3 IEEE 1394a ports (2 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
1 x CPU fan header
3 x system fan headers
1 x Chipset fan header
2 x USB 3.0/2.0 headers
1 x IEEE 1394a header
1 x clearing CMOS button
1 x power button
1 x reset button
2 x IEEE 1394a ports
4 x USB 2.0/1.1 ports
4 x USB 3.0/2.0 ports
2 x eSATA/USB Combo connectors
1 x RJ-45 port
6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
iTE IT8728 chip
H/W Monitoring
BIOS
2 x 32 Mbit flash
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Q-Share
Bundle Software
Operating System
Form Factor
Remark
GA-P67A-UD7-B3
![4080.jpg](http://www.gigabyte.com/fileupload/LineImage/2/3761/4080.jpg)
Descrição
CPU
Chipset
Memory
Audio
2/4/5.1/7.1-channel
LAN
2 x Realtek RTL8111E chips (10/100/1000 Mbit)
Support for Teaming
Support for Smart Dual LAN
Expansion Slots
2 x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIEX16_1 and PCIEX16_2 slots.
2 x PCI Express x16 slots, running at x8 (PCIEX8_1, PCIEX8_2)
* The PCIEX8_1 slot shares bandwidth with the PCIEX16_1 slot and the PCIEX8_2 slot with PCIEX16_2. The PCIEX16_1/PCIEX16_2 slot will operate at up to x8 mode when the PCIEX8_1/PCIEX8_2 is populated.
1 x PCI Express x1 slot
2 x PCI slots
Support for 2-Way/3-Way ATI CrossFireX™/NVIDIA SLI technology
2 x Marvell 88SE9128 chips:
2 x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices
USB Chipset:
Up to 8 USB 2.0/1.1 ports (4 on the back panel, including 2 eSATA/USB Combo, 4 via the USB brackets connected to the internal USB headers)
2 x Renesas D720200 chips and 2 x VLI VL810 hubs:
Up to 10 USB 3.0/2.0 ports (6 on the back panel, 4 via the USB brackets connected to the internal USB headers)
* The USB 2.0 signals of the 6 USB 3.0/2.0 ports on the back panel are from the Chipset.
4 x SATA 6Gb/s connectors
1 x CPU fan header
1 x power button
1 x reset button
2 x USB 2.0/1.1 ports
6 x USB 3.0/2.0 ports
2 x RJ-45 ports
I/O Controller
iTE IT8728 chip
H/W Monitoring
BIOS
2 x 32 Mbit flash
Unique Features
Support for @BIOS
Support for Q-Flash
Support for Q-Share
Bundle Software
Operating System
Form Factor
Remark
Membros do Clube:
.::Chico::.
Lurt'z
[pacman]
IgorEFI
Joww
torrentman
maurochaves
Luciano Bion
megazz
MIC
edguybr
Gotoa
![140.jpg](http://thumbs4.ebaystatic.com/m/m01vQwBdGAZUXuVRm7_yOkg/140.jpg)
.::Chico::.
Lurt'z
![file_94_29.jpg](https://www.guerradigital.net/media/catalog/product/cache/1/small_image/135x135/5e06319eda06f020e43594a9c230972d/f/i/file_94_29.jpg)
[pacman]
IgorEFI
Joww
torrentman
maurochaves
Luciano Bion
megazz
MIC
edguybr
Gotoa
![h631633-180-130-gigabyte-ga-p67a-ud5-b3.jpg](http://stellaris.numerama.com/s/h631633-180-130-gigabyte-ga-p67a-ud5-b3.jpg)
Diegodiniz
cmlbrasil
Wester
![p67as.jpg](http://www.lojamegabrasil.com.br/media/catalog/product/cache/1/small_image/135x/9df78eab33525d08d6e5fb8d27136e95/p/6/p67as.jpg)
JEFFER5ON
Montana.nF
Kaminahrri
Vicalvi
Tiago Piloneto
poisonmaniac
HumbertoPC
laureanoleme
