Chackall
| Maximum Effort |
Moderador
14/07/2008
13,649
12,637
120
Uberaba (MG)
www.nerdfield.com.br
mas no windows vista ele roda sem esses erros de textura mas com o over muito alto. E4400 @3.5 =X
(tem gente com 3, 4, 2gb de memoria com o mesmo problema que o meu...)
Ai bro... pelo que entendi vc ta com um problema com as texturas do jogo que estão sumindo né...
Aki no meu pc as texturas nem estavam aparecendo...
Mas o problema eram com os drives da placa de video...
Um kra aki do forum me passou um eskema pra resolver... eu fiz e ficou perfeito... tenta ai:
Missing Textures Issue
If you are experiencing an issue where textures are not visible, the following instructions may solve the issue.
This issue can occur if your video drivers are incorrectly installed or have become corrupt.
These instructions explain how to completely remove all existing driver files and are recommended for advanced computer users only.
These instructions recommend using a third party application called Driver Sweeper, which was not developed by Valve and therefore we provide no support or guarantee regarding its use.
Please proceed at your own risk.
1. Uninstall your existing video drivers from the Add/Remove Programs window.
Click Start, then Run (or Windows Key + R) and type in the following command:
appwiz.cpl
Locate and uninstall your video drivers (They should be listed alphabetically under Nvidia or ATI)
2. Download and install the free driver removal utility call Driver Sweeper, available at the following URL:
http://www.guru3d.com/category/driversweeper/
3. Restart your computer in Safe Mode. This can be accomplished by tapping the F8 key while your computer is booting up. A list should appear with Safe Mode as an option.
4. Launch Driver Sweeper (It should be located on your start menu where you installed it previously)
There will be checkboxes for "ATI - Display" and "NVIDIA - Display". Check both of these and click "Clean"
If you receive errors, please note exactly what they are.
It is recommended to repeat the cleaning process a few times to make sure all files are properly removed.
5. Restart your computer in normal mode (This should happen automatically. Pressing F8 again is not required)
You may notice some graphical irregularities (Items being larger than usual, and etc). This is normal.
Run Driver Sweeper one more time from normal mode to ensure that all driver files are removed.
6. Download and install the latest video drivers for your video card.
Nvidia Desktop Drivers - http://www.nvidia.com
ATI Desktop Drivers - http://www.ati.com
Notebook drivers should be obtained from your notebook manufacturer's website.
7. Restart your computer once the drivers are installed.
8. Launch the game and re-test the issue.
9. If the issue is still not resolved, some users have found that the issue was only resolved after downloading Riva Tuner (A third party graphics card tweaking tool) and doing the following:
- Launch Riva Tuner
- On the main tab, click the arrow to the right of "ForceWare detected"
- Click on the broom icon (last icon on the right). This will reset all graphics driver settings to their default values.
- Click OK and restart your computer.
- Test the game.
As with Driver Sweeper, Riva Tuner was not developed by Valve and we do not offer any support or guarantee of its use.
Riva Tuner is available here:
http://www.majorgeeks.com/download737.html
P.s.: Se vc tiver nvidia... instala o drive oficial (180.48) e depois instala o beta (180.84) da uma melhorada boa no jogo... abrass!!
PanzerOps
Administrador
31/03/2005
37,442
4,908
255
:slap: vlw por contar uma parte da ultima missao :lol::lol:
Última missão que ele jogou né....
Pelo menos eu espero :cry:
Mals galera,sai pra trabalhar e só cheguei agora.E a página andou pra cacete.Upei em outros servers pra galera.Peguem esse arquivo txt e coloquem dentro da pasta aonde vcs instalaram o jogo e acreditem se quiser o desempenho no jogo será outro.Aqui rodo numa boa em 1280x1024 em hight e higthest distancia em 44,qualidade de distancia em 100,densidade dos carros em 100 e em sombra deixei em zero e os fraps ficam em 25 na média,variando de 22 até 35 e dá pra jogar numa boa.Minha configuração é core2duo E8400 stock,geforce 8800gts g92,4 gigas ram,windows xp sp2.
http://www.megaupload.com/?d=KMXR1KPL
http://www.flyupload.com/?fid=462393685
Espero que gostem:thumbs_up
Valeu, megaupload é coisa fina :yes:
Ar4Gorn
67
Qual o resto da tua config?
Fiquei preocupado :eek::eek:
AMD Athlon 64 x2 5200+, 4GB de RAM 800Mhz Dual Channel(Mas estou usando 3GB por causa do SO de 32bits) e a 8600GT Fatal1ty.
Ta jogavel, com umas quedas chatas as vezes. E tudo no low e com aquelas specs la embaixo reduzidas para 1 :(.
Algum modo de melhorar isso?Algum driver?Patch?
Gargula
Gamer since 90s
19,255
942
Porto Alegre - RS
www.adrenaline.com.br
Mas é, saca.... Primeira parte tu corre para o barco, subindo nele ele explode. Blz... Fiz 3x essa parte e explodiu, raramente nao acontece. Na segunda parte na ANIMAÇAO do jogo tu morre, fica com a tela preto e branco e nao tem como sair, só dando ALT+F4 no jogo, fiz 14x está mesma parte.... Jogo tá bugado ou tá impossivel ai.
Vi os videos, muito mais facil o cara jogando no console, nao tem nada disso, tudo 100%...... Ridiculo demais.
PanzerOps
Administrador
31/03/2005
37,442
4,908
255
Gargula, vc não tá entendendo a situação, a galera tá pasma de vc SPOILAR a ÚLTIMA MISSÃO DO JOGO!!
Entendeu? :p
Kaos
League of Noble Peers
1,581
12
Numa praia de SC.
Entendeu? :p
HAUhAUHauhuaHuaHuAHuaHuaHUAHuAHU
Essa entra para as pérolas...
[]´s
Kaos
digaosn
DiGAUM
1,363
620
Campo Verde MT
Entendeu? :p
Pqp... ri alto aqui no trampo hUAHaUhAUhaUhAUhAUhaUhAU
Brunor2
Psicologia 2° ano
1,254
Entendeu? :p
Pois é.
Eu fiquei puto, ainda bem que nem li tudo, parei ali na parte da ultima missão, uaiehauieh ! :slap:
panda49
16,720
hahahahah vou dar bad report, hein! hahahhaa
Acontece, acontece. Ele ficou tão revoltado com a situação que nem pensou em mais nada, hahahah.
PanzerOps
Administrador
31/03/2005
37,442
4,908
255
Heheuahuahuahuahauhauahuahauahuah
rafaelfelipebauer
175
to no trampo, baixei meio dia, quando fui almoçar, mas quando chegar, e ver que ninguem posto, eu up em outros servers
Ta legal... :thumbs_up
Gargula
Gamer since 90s
19,255
942
Porto Alegre - RS
Po, foi mal... Até tinha esquecido de usar a tag do spoiler e tava sentindo que faltava algo, nao sabia o que eras. Mals mesmo :) E essa revolta tambem, fodz viu AEHUIEAHUIAEHUIAE
XgeN
163
GVSPFC
Peace!
5,765
189
Blumenau/SC
Ban do tópico pro Gargula!!!
Que sacanagem! hehehehe
Ainda bem que percebi quando chegou na parte do "última missão" e tirei os olhos na hora!
XgeN
163
Poderia passar seu .txt?
Abraco.
Opa.
Nao to usando txt eu coloco no icone no desktop isso:
"D:\Rockstar Games\Grand Theft Auto IV\LaunchGTAIV.exe" -norestrictions -nomemrestrict -novblank -windowed availablevidmem 512 -percentvidmem 100
Outra coisa,tenho amigos com config parecida com a minha so muda que tem um E8400 a 3.2ghz e rodando muito PIOR que eu...
GTA IV Quad Core...ALL THE WAY!
VIDEO: http://www.youtube.com/watch?v=2nkJ4fX4F9o
Gargula
Gamer since 90s
19,255
942
Porto Alegre - RS
darkz
1,692
60
Manchester - England
Eh, eu andei lendo muito em foruns gringos, pelo jeito precisa de quad mesmo ehehehe, bom, isso ninguem pode reclamar, viviam reclamando que os jogos nao usavam nem 2 nucleos, agora ja estao comecando usar 4 eheheh. Pessoal de Quad devem estar rindo de nos agora hehee. Meu proximo sera Quad certo!
Abraco.
chadruns
The Legend
1,477
pessoal, só uma duvida cruel, eu criei um conta no social club blz, ai criei a da live e botei a cdkey, joguei online e tals tudo certo, agora eu criei outra conta na live pois eu queria trocar o gamertag(nome) pois não tem como alterar, agora a pergunta, posso usar a mesma cdkey nessa nova conta na live???
abraços
