Guia de mineração
Claudecir
Be free, be true, be you.
2,464
1,774
lolMiner 1.39​
Feature Changes​
  • Added support for mining TON. Use --algo TON to mine it. Developer fee is 1.5%, AMD cards since GCN1 (via OpenCL) and Nvidia cards Maxwell and newer generation (via Cuda) are supported.
  • Added support for mining Ubiq. Use --algo UBQHASH to mine it. The fee is 0.7% as with all Ethash based coins.
  • Added support for routing your stratum traffic through a socks5 proxy server. Use --socks5 : to enable it. Note: at the moment this does not work with https traffic as in the TON algorithm. We will work on that.
Fixes​
  • Added a timeout for DOH requests, so they can no longer hang indefinitely.
  • Fixed ethash support for RX 5500 series GPUs on more recent drivers.
Notes about TON pool connection​
At the moment only the https pool communication protocol is supported. Therefore your --pool address must start with https://. This protocol is not ideal for mining, but we work on establishing a real stratum protocol with some pools in the near future, stay tuned!
Note when using a pool address starting with https:// specifying a port is optional (the default 443 is used when not specifying one). Also when mining TON via https lolMiner automatically uses TLS 1.2 encryption with skipped host name verification. As a final notice: always make sure your TON pool either does not need miner wallet registration or you registered - many popular pools require to register your wallet address to mine it.
Notes about TON performance and tuning​
With regard to tuning for TON: The algorithm needs core, core and more core. Therefore maximizing the core clock within the limits of you cooling and energy supply is the key for the ideal performance. It might be beneficial to reduce the core voltage to produce less heat and less energy consumption - this way the cards keep more distance to their thermal limits and can often clock higher as well. We recommend this algorithm on your AMD RX 6000 cards!
Reações: 2agames
wandersondb
Você me deve 40 reais
2,009
985
Alguem me manda o link dos bots de preços do telegram?
N3SSO
Sem Paciência
3,040
6,531
Americana-SP
japalesado
13
78
Alguém minerando esse TON? Tinha ouvido falar uns 15 dias atrás quando estava us2... preguiça de configurar tudo manual no hive pra testar... Agora já passou de 3 doletas e dá pra minerar no lolminer... Vai que é promissora...
leomestre
7
276
Feliz ano novo, minêros!
Foi um ano de muitas emoções e aprendizado. Aprendi muito por aqui... Obrigado!
Grande abraço!
catanineto
atlantean
dkTTTT
The Dark Knight
3,581
1,708
56
Feliz ano novo galera. Passando só pra avisar que a mineração em 2022 vai acabar.
:bem:
Oriens
Leia ali ->
456
725
Feliz ano novo, nos vemos no próximo enterro da mineração!
Alexandre B T N
102
345
Feliz 2022! Ano que o BTC tem chance de subir a U$100k e também de cair a U$10k.
sonic pestinha
Origin : SonicPestinha
407
1,384
Não consigo por a 3060ti LHR em 40 MHS, já tentei várias config, ele só mfica em 35 MHS
Alguém usa o Nb Miner, consegue mais que isso?
Soufly3xtr3m3
Loading...
13,168
5,609
Brasilia-DF
Minerar TON ta dando 25% a mais do que ETH, pena que isso não dura 1 mês e ainda é na porcaria do LolMiner.
Reações: Claudecir e Panda
xfileman
Bitwork
Underworld
Você usa no riser? Já passei por isso e era riser ruim, ou pode ser o cabo de energia que alimenta ele.
Outra hipótese é o driver, usa 471.11 com T-Rex, o Gminer para as 3060Ti não rende bem.
Claudecir
2,464
1,774
Tem material dela, qual TON? Tem mais que uma, pools?
E essa?
sonic pestinha
407
1,384
Entendi, pode ser o riser mesmo
Claudecir
2,464
1,774
Leninn
Tiangua
Pesaol boa noite.
Antes de tudo Feliz ano novo.
Comecei a minerar faz uma semana e pouco, e vejo um problema na minha rig.
Minero pela flex e uso Gminer.( 6600 xt e 3060ti)
Mas sempre o valor reportado pelo hiveos é um e o o da pool é outro. Além do hiveos não mostrar nenhum invalido e na pool mostra.
Outra coisa é no miner diz q esta 93 a 97% de eficiencia, tem como melhorar? Pois tem vezes q chega a 88 e 89%.
Na pool sempre fica aasim, sendo q no hiveos e miner diz esta com 75 e ela sempre reporta menos.
OBS: Resolvi minerar pela flex pois a binance tava dando muito rejeits e os mhs era ainda menor.
Grato a todos.
Soufly3xtr3m3
Loading...
13,168
5,609
Brasilia-DF
E essa?
Sim, esse site ai, tem as 4 pools com 0% de fee que eles recomendam.
Como conseguiu comparar?
Batendo os dados desse vídeo com o whattomine e minestat:
japalesado
13
78
Coloquei as minhas lhr aqui pra rodar no toncoin, dava us55 bruto dia no eth... Em 13h chegou nos 10 toncoins na carteira, 37,5 dolares... Ruim que o bridge pra metamask custa 5 toncoin, fiz pra testar e foi pra metamask... parece que logo vai usar uniswap...
Reações: Claudecir
dkTTTT
The Dark Knight
3,581
1,708
56
Pesaol boa noite.
Grato a todos.
A sorte faz "efeito" na eficiência. Digamos q em um intervalo de tempo específico, de acordo com o seu hash power, vc envia muito mais shares válidas do q o normal, daí vc fica com mais de 100% de eficiência, e vice-versa. Para tentar "estabilizar", procurar uma pool com boa latência é importante, assim como ter um overclock estável.
Reações: neo666
