http://www.xtremesystems.org/forums/showthread.php?286340-4770k-4670K-IHS-Removals
[video=youtube;FirsCzTnbdQ]http://www.youtube.com/watch?v=FirsCzTnbdQ[/video]
Antes do IHS Mod
Depois do IHS Mod
Stress testing was done by Prime95 64-bit version 27.9 on custom settings with FFT length set to 32 (Run FFTs in-Place checked). Duration: 10 minutes. CPU voltage and frequency were set to 1.312 volts and 4.3 GHz respectively.
Before delid:
Average CPU Load temperature: 87.5
Ambient: 24.9
Delta: 62.6
After delid (Cool Laboratory Liquid Pro between Die and IHS):
Average CPU Load temperature: 69
Ambient: 24.6
Delta: 44.4
As you can see, With a "simple" thermal grease swap, the temperatures droped by an average of 18.2 C while using 1.312 volts.
http://www.overclock.net/t/1397672/...g-temperatures-and-maximizing-overclockablity
Minha Conclusão: mesmo após o IHS Mod, ao meu ver as temperatuas seguem altas, o cooler usando Antec H20 920 Push/Pull e um overclock leve 4.3GHz com vcore médio 1.312v ainda deixa muito a desejar. acredita-se que não seja apenas problema com a pasta térmica interna.
