Listinha de bons programas 64-bit
Kayke
Bons programas 64-bit. Se houver interesse, depois se faz a listinha de games, que infelizmente ainda é pequena.
7-zip: www.7-Zip.org
Achive manager (compactador de arquivos)
BlackBox: http://blackbox.hardwaremania.com/en/download
HWM BlackBox is a utility designed to deliver precise details on the core components of your computer to the maximum. As well as providing you with you with in-depth information about hardware such as the processor, memory modules, mainboard, hard drives and video card, it also offers the opportunity to assess critical parameters such as clock speeds and temperatures.
Cerberus FTP Server: http://www.cerberusftp.com/download.html
ComicRack: www.comicRack.cyolito.com
Comic book reader
Copyhandler: http://www.copyhandler.com/
Copy Handler is a free software for Windows systems, which allows you to take full control over the file copy and move operations. Program is highly customizable and fully integrates with the operating system. In addition, Copy Handler offers many advanced options such as task queuing, filtering files according to specific criteria, pausing and resuming copying files operations, changing the copying parameters on the fly and in many cases also offers a significant acceleration of the entire copying files
CoreTemp: www.alcpu.com
Monitor de temperatura para processadores Intel e AMD.
CPU-Z: http://www.cpuid.com/cpuz.php
CPU-Z is a freeware that gathers information on some of the main devices of your system.
DLL Export Viewer: www.nirsoft.net
EmEditor: www.emeditor.com
Eraser: www.sourceforge.net
Deletador permanente de arquivos.
FAVC: www.favc.com
Firefox: wiki.mozilla x86-64.com
(warning: add-ons will not work with 64-bit version)
GIMP: gimp-win.sourceforge.net
Image manipulation program
Hash Tab: beeblebrox.org
Hex Editor Neo: hhdsoftware.com
HWMonitor: http://www.cpuid.com/hwmonitor.php
HWMonitor is a hardware monitoring program that reads PC systems main health sensors : voltages, temperatures, fans speed.
IconViewer: http://www.botproductions.com/iconview/download.html
IconViewer is a free Windows Explorer extension that lets you easily view, copy, and save icons contained within programs and libraries. Open a file's Properties box, select the "Icons" tab, and view the icons contained in the file.
ImageResizer: http://phototoysclone.codeplex.com/R...eleaseId=26281
This is a clone of the Image Resizer Powertoy for Windows XP -- a PowerToy that allows you to right-click on one or more image files in Windows Explorer to resize them. This clone was created to extend support to non-XP and 64-bit versions of Windows (including Windows 7 & Vista)
InfraRecorder: www.InfraRecorder.org
CD/DVD burning software
Java: java.com
(for use with 64-bit IE)
LockHunter
http://lockhunter.com/download.htm
It is a free tool to delete files blocked by something you do not know. LockHunter is useful for fighting against malware, and other programs that are blocking files without a reason. Unlike other similar tools it deletes files into the recycle bin so you may restore them if deleted by mistake.
Macrium Reflect Free: http://www.macrium.com/reflectfree.asp
Criar e restaurar imagem de sistema.
Media Player Classic: http://mpc-hc.sourceforge.net/downlo...lassic-hc.html
Media Player
Microsoft Security Essentials: microsoft.com
Anti-virus
Microsoft Windows Malicious Software Removal Tool: microsoft.com
Malware scanner
MyDefrag: http://www.mydefrag.com/Manual-DownloadAndInstall.html
MyDefrag is a disk defragmenter and optimizer (a maintenance utility to make your harddisk faster)
Nirsoft File Types Manager: FileTypesMan - Alternative to 'File Types' manager of Windows
Nirsoft ProduKey: http://www.nirsoft.net/utils/product_cd_key_viewer.html
Notepad 2: 3.1.21 - http://code.kliu.org/misc/notepad2/3...ad2.x86-64.exe
4.0.22 - http://code.kliu.org/misc/notepad2/4...ad2.x86-64.exe
Notepad alternativa
Paint.NET: getpaint.net
Edição de imagens
PeaZip: sourceforge.net
Archive manager
PC Tools Firewall Plus: http://www.pctools.com/firewall/
PC Tools Firewall Plus is a powerful free personal firewall for Windows® that protects your computer by preventing unauthorized users from gaining access to your computer through the Internet or a network. By monitoring applications that connect to the network Firewall Plus can stop Trojans, backdoors, keyloggers and other malware from damaging your computer and stealing your private information.
PDF Converter
http://www.dopdf.com/
doPDF is a free PDF converter for both personal and commercial use. Using doPDF you can create PDF files by selecting the "Print" command from virtually any application. With one click you can convert your Microsoft Excel, Word or PowerPoint documents or your E-mails and favorite web sites to PDF files.
PDF XChange: docu-track.com
PuTTY: splunk.net
Remote console
Rainmeter: Downloads - rainmeter - Project Hosting on Google Code
Rainmeter is a Windows customization application. Empower your desktop with an expandable library of useful tools – handy notes and application launchers, weather and feeds from the web, system status and more. Then, rearrange and modify them to suit your personal style. With Rainmeter, your desktop is finally yours.
Recuva: http://www.recuva.com/download
Recover lost and deleted files
RunAsDate: nirsoft.net
(Ignore any virus warnings
on these applications as they're just False Positives.)
ShellExView: nirsoft.net
Shell Extensions are in-process COM objects which extends the abilities of Windows operating system. Most shell extensions are automatically installed by the operating system, but there are also many other applications that install additional shell extension components. For example: If you install WinZip on your computer, you'll see a special WinZip menu when you right-click on a Zip file. This menu is created by adding a shell extension to the system. The ShellExView utility displays the details of shell extensions installed on your computer, and allows you to easily disable and enable each shell extension.
ShellMenuView: http://www.nirsoft.net/utils/shell_menu_view.html
ShellMenuView is a small utility that display the list of static menu items that appeared in the context menu when you right-click a file/folder on Windows Explorer, and allows you to easily disable unwanted menu items.
Sophos Anti-Rootkit: http://www.sophos.com/products/free-...i-rootkit.html
Sophos Anti-Rootkit detection and removal tool has native support for Windows 7 64-bit. Actually it runs on all 64-bit platforms.
SpecialFoldersView: nirsoft.net
System Protect: http://www.system-protect.com/
System Protect guards your precious personal and system files, and does not allow anyone to modify or delete them.
Thunderbird: wiki-mozilla x86-64.com
Email program
Ventrilo: ventrilo.com
Voice communication with multiple people
VistaSwitcher: http://www.ntwind.com/software/vistaswitcher.html
VistaSwitcher is an elegant and powerful task management utility for Windows OS. Once installed, it replaces the default Windows Alt-Tab dialog with a nice box that shows a list of all running tasks with their names and preview snapshots and enables the user to take actions on them using the mouse and keyboard shortcuts. With just one click, you can switch to a task, minimize, maximize, restore the main window or close the process.
Volumouse: nirsoft.net
WirelessKeyView: nirsoft.net
Zune Sofware: http://www.zune.net/en-US/software/download/default.htm
