Meu Deus q pl eh essaaa????????????
tozzi
Usuário Registrado
ou galera deem uma olhada nisso, q placa eh essa
CREATIVE LABS WILDCAT III 6210
ela eh melhor ou pior q a R9700????
olha soh os detalhes
FEATURES
Wildcat III 6210 Professional Graphics Card AGP Pro 50 Slot, 416MB card with Dual-pipeline configuration (supports dual-head* digital and analog displays). * Dual monitor support is only available under Windows® 2000 and Windows XP. Eliminate creative boundaries with 3Dlabs Wildcat III 6210 - the latest Wildcat graphics accelerator to offer the best image quality and highest performance available on the desktop. With a massive 416 MB total on-board memory, you'll get the speed and performance you need without sacrificing any of the renowned quality you've come to expect from 3Dlabs. If you're working in MCAD, DCC, Visualization, or any professional graphics field where you need ultra high-end performance, you'll appreciate the advances in speed we've made to the "fastest graphics on the planet." Support for 32 lights in hardware and doubled texture memory translates to more realistic renderings and much faster geometry acceleration - even with complex scenes. In addition to phenomenal performance enhancements, the Wildcat III 6210 offers standard support for dual analog and digital monitors. So, when you're working on a complex project or a large assembly, you can increase your visual real estate two-fold. And, with standard multiview and genlock support, DCC, Video Production, CAVE,and Visual Simulation professionals can synchronize multiple Wildcat III 6210s together or to an external sync source. Wildcat products have always offered the best image quality in the industry with 10-bit sub-pixel accuracy, exclusive SuperScene™ antialiasing, and high geometry and texture coordinate precision. With this well-established legacy of quality, you can be confident in the accuracy of your designs.
* Dedicated 256 MB texture memory and 128 MB frame buffer (plus 32 MB DirectBurst™ memory for 416 MB total memory).
* Six T & L engines for performance and programmability.
* Stereo Sync
* Multiview and genlock support
* 3D volumetric texture support
* Exclusive SuperScene antialiasing
* AGP Pro 50 - AGP Version 2.0
INTERFACE
- AGP Pro 50 (AGP Version 2.0 Compliant)
MEMORY
-128MB DDR dedicated frame buffer
-256MB DDR dedicated texture buffer
-32MB DirectBurst
CHIPSET Data Width:
-Frame buffer- 128 bits
-Texture buffer- 64 bits
-DirectBurst- 64 bits
-Integrated 320MHz RAMDAC
Geometry Acceleration:
Model view matrix transformation of vertex and normal coordinates.
Perspective and viewport transformations.
Texture matrix transformation of texture coordinates.
Local display list storage and processing.
Full lighting calculations (up to 24 lights).
View volume clipping.
Up to six user clip planes.
Image processing.
CONNECTORS 1) 3-pin, mini-DIN stereo sync output
(2) 29-pin DVI-I output connector
(1) BNC connector
(2) 6-pin modular jacks
HARDWARE 3D Gourad-shaded triangles, Z-buffered: 33.0 million tri/sec. Trilinear fill rate: 400 M pixels/sec 3D Vectors, solid-color, 10-pixel: 26.1 M vec/sec Complete OpenGL® 1.3 geometry acceleration -- The Wildcat III 6210 uses a highly-tuned T&L engine to accelerate the complete OpenGL 1.3 pipeline, including all geometry operations, triangle setup, texturing, and pixel operations. OpenML™ 1.0 support DirectX 7.0 support (single display only)
3D FEATURES SuperScene™ full-scene multisampled antialiasing:
Point sampled with 16 samples.
Sample location jittering.
Dynamic sample allocation.
Dynamic sample backoff.
2D FEATURES 16- and 32-bit color depths (565, 8888)
Solid and patterned area fills
Vectors (diamond rule compliant)
Block moves (screen-to-screen)
Block gets (screen-to-system)
Block puts (system-to-screen)
Bilinear scaling
DISPLAY True color resolutions up to 2048x1152 double-buffered and 32-bit Z per monitor. 60Hz-90Hz screen refresh rates (monitor dependant). Dual display support under Windows® 2000.
STEREO SYNC Female, 3-pin, VESA-standard, mini-DIN connector provides connection to a LCD shutter glasses emitter module or to other stereo shutter devices.
GENLOCK Synchronizes the vertical refresh rate of the system display to and external signal.
MULTIVIEW Provides frame locking and rate locking of multiple workstations.
DRIVERS Microsoft® Windows® NT, Windows 2000, Windows XP
REQUIRES Intel® Pentium® processor or compatible
Microsoft Windows 2000 or Windows XP
One AGP Pro 50 slot
One open PCI slots adjacent to the AGP Pro 50 slot for cooling and mechanical.
Minimum of 32 MB DRAM (64 MB recommended)
3 MB of free space on the computer's primary system disk for the video display driver software.
50 W of available power
falto a foto:D :D :D
e ela custa em torno de 2000 mil dollares:eek: :eek:
    22 KB · Visitas: 139
Essa é uma placa de uso profissional, portanto se falarmos em jogos, superioridade da Radeon 9700, pois é voltada para games.
eh veio
mercado profissional certesa...
Exatamente, esqueçam ela pra jogos, é pra aplicações profissionais em OpenGL... o suporte dela pra DirectX é minimo só pra não dizer que não tem, é só olha ali, é Dx7 ainda.
E outra, slot AGP Pro não é em qualquer placa e também não é qualquer fonte e placa mãe que consegue mandar energia suficiente pra essa bixinha funcionar. :D Sem contar o gabinete... tem que ser gigante, ela via de ponta a ponta. :cool:
[]´s
Flávio
