MSI KT4 Ultra....
EzQ
!!The Fodelis AMD!!
to pensando em troca a minha mobo por essa ae.... qq vcs acham, vale a pena???
CPU
• Supports Socket A (Socket 462) for AMD® Athlon™ XP/
Athlon™/Duron™ processor
• Supports 800MHz up to Athlon™ XP 2700+ processor
Chipset
VIA® KT400 Chipset
- FSB @200/266/333MHz
- Supports DDR200/266/333/400* memory
- AGP 8X and PCI advanced high performance memory
controller.
VIA® VT8235 Chipset
- Dual channel Ultra DMA 66/100/133 master mode EIDE
controller.
- ACPI & PC2001 compliant enhanced power management.
- Integrated USB 2.0 controller.
FSB
100/133/166 MHz clocks are supported.
Main Memory
• Supports six memory banks using three 184-pin DDR SDRAMs.
• Supports up to 3GB memory size.
• Supports DDR400*/DDR333/DDR266/DDR200 SDRAM
* When FSB setting 166MHz the memroy only can
running at DDR333 mode.
* DDR400 memory support by MSI certified module only
* DDR400(PC3200) max. up to 2 DIMM slots.
* The tested and qualified DDR400/PC3200 DIMMs are
listed below: Vendor Type S i z e Maximum Number of DIMMs
Samsung K4H560838D-TCC4 256MB 2
Apacer Samsung K4H560838D-TCC4 256MB 2
TwinMos Winbond W942508BH-5 256MB 2
TwinMos TMD7608F8E50B 256MB 2
Winbond W942508BH-5 256MB 1
ADATA Winbond W942508BH-5 256MB 1
Kingston Winbond W942508BH-5 256MB 2
Samsung K4H560838D-TCC4 512MB 1
Apacer Winbond W942508BH-5 512MB 1
Kingston Winbond W942508BH-5 512MB 1
TwinMos Winbond W942508BH-5 512MB 1
TwinMos TMD7608F8E50B 512MB 1
Slots
• One AGP (Accelerated Graphics Port) slot.
- Supports AGP 3.0 4x/8x.
• Six 32-bit PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE
An IDE controller on the VT8235 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes.
Serial ATA Interface (Optional)
Promise 20376 controlls 2 Serial ATA ports in 150 MB/s operation mode and 1 Ultra DMA port
Bluetooth (Optional)
1 extra pinheader for Bluetooth connect connection.
Audio
C-Media 8738MX 6-channel audio + SPDIF out.
On-Board Peripherals
On-Board Peripherals include:
- 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M
and 2.88Mbytes
- 2 serial ports (COM A + COM B)
- 1 parallel port supports SPP/EPP/ECP mode
- 1 IrDA connector for SIR/ASKIR/HPSIR
- 1 audio port
- 6 USB 2.0 ports (Rear * 4/ Front * 2)
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which
detects the peripheral devices and expansion cards of the
board automatically.
• The mainboard provides a Desktop Management Interface
(DMI) function which records your mainboard specifications.
• ACPI, 1.0a, APM1.2, PnP 1.0a, SMBIOS 2.3, USB 2.0, WFM 2.0,
Overclock, Boot from USB device.
Dimension
30.5 cm(L) x 23 cm(W) ATX Form Factor
Mounting
6 mounting holes.
Accessories:
2 cabos serial ATA
3 IEEE 1394
D Bratek
S Bratek
    85.9 KB · Visitas: 165
FagnerK
Gamer
Bom cara, se for trocar visando tanto o DDR400 ou o AGP8x, eu não trocaria por enquanto. O DDR400 pelo que sei muitas vezes fica abaixo do DDR333...Tipo, espera um poco e ve se sai uma atualização dele, pro KT266 saiu o KT266A. E o AGP 8x não é nada de espetacular comparado ao AGP 4x, ganhando insignificantemente em desempenho, e tb pra poder usar toda sua capacidade vc precisaria ter uma Radeon9700 ou uma GeForce4(NV28). Agora se tiver com dinheiro sobrando vai fundo que vc vai passar inveja em muitos com essa mobo....:p
Valew
EzQ
!!The Fodelis AMD!!
tem um cara q qh me vende por R$650, tah no estoque dele parado.... nao teve muitas vendas dela e ele que vende-la de barbada!
DekerBSB
Registered User
devo receber essa placa para review nessa semana....
pode deixar q vou falar o bom e o ruim da placa....
Aurus
Powered by 64bits
Uma coisa que a galera nao se toca eh que o athlon tem uma banda de memoria maxima de 2.1GB com fsb em 266 e 2.7GB com 333. Ou seja, ao usar memos ddr400, mesmo com baixas latencias, nao vai passar disso, somente vai ajudar a chegar mais proximo desse maximo.
FagnerK
Gamer
Originally posted by PsychoBoy
ela vem com aquela anteninha do Bluetooth???
Audio
EzQ
!!The Fodelis AMD!!
o meu caso eh se vale ou não a pena, ou se pego uma kt3 de ateh R$650.
Tshasko
Aprendiz de Carpinteiro
Bem eu acho que vc deveria pegar ela sim, e me vender a sua placa atual....*rs
Mas falando sério a placa é muito boa, mas eu tb acho que vai haver uma revisão do chipset vai haver um Kt400a...
Sucesso.
EzQ
!!The Fodelis AMD!!
e essa revisão q vc diz... vai se atualizavel por software?
FagnerK
Gamer
Com certeza não, se ouver alguma mudança, será no próprio chipset.
Tshasko
Não esta revisão vai ser de hardware mesmo, vai haver algumas mudanças no proprio chipset, mas isso é tudo especulação, isso quer dizer ninguém tem certeza, mas se achar que o preço esta bom, por tudo que a placa oferece, compre ela sim, pois é uma ótima placa, e depois me vende a sua, e eu vendo a minha.
Sucesso.
EzQ
!!The Fodelis AMD!!
o cara qh me faze a placa por R$650, mto barbada!
Tshasko
Então faz assim comprar ela por este preço que realmente esta barato e me vende a sua por 400 reais...
AHHAHAHAHAHAH
Sucesso
EzQ
!!The Fodelis AMD!!
a minha esta quase vendida por R$550, hehe.... paguei R$450 no paraguai!
M
marceeloc
Guest
Pois é a minha mobo é uma KG7 ABIT, estava pensando em pegar um xp200+ e trocar minha mobo pela kt400 da MSI e tb trocar minha memória pc2100 266 miocrom registrada por uma ddr de 333mhz vale???
FagnerK
Gamer
E tb...será que ta facil achar pentes DDR 400 ?
Douglaster
A BESTA FERA >=D
eu só nao peguei DDR 433 Prq nao deu
Fiquei com 1 Giga de 333 doque 512 de 400:rolleyes:
Douglaster
A BESTA FERA >=D
Aurus
Powered by 64bits
Nao se deve pensar que ao colocar memos maiores que ddr333 vai aumentar muito a taxa de transferencia no athlon. O athlon pode transferir no max 2.7GB, entao, sem um over de fsb, nao iremos conseguir uma banda maior que isso. Entao, eu acho que alem das ddr400 tarem com altas latencias, o ganho nao eh ta grande assim, nao valendo a pena compra-las.
