Galera, só para avisar e mantendo minha promessa de sempre dá um feedback, saiu driver novo:
AMD Radeon Adrenalin Edition 20.3.1
Fixed Issues
- Frame skipping or choppy audio may be experienced in videos captured using Radeon ReLive.
- Some games may experience stutter while using Instant Replay or third-party applications that stream or perform screen capture.
- Hotkeys may fail to apply to scenes in ReLive scene editor when the scene has a custom name.
- Webcam elements may fail to appear on screen when a custom location is set during ReLive recording.
- AMD A-Series/E-Series APU Processors will reflect older Radeon Software Adrenalin 2019 Edition Settings user interface.
- Zero RPM toggle may fail to reset or appear when disabling advanced fan tuning options in Performance Tuning.
- Radeon Software may automatically close when a live stream is started or stopped.
- Desktop cursor may intermittently remain visible after toggling Radeon Software's overlay in some games.
- Red Dead Redemption 2 may experience a blank screen when launched using the Vulkan API.
- Radeon Software may experience an application crash, or a system TDR may occur, when VRAM reaches 8GB or more with HBCC enabled on Radeon RX Vega series graphics products.
- DOOM may experience an intermittent system hang or application crash during gameplay.
- Space Engineers may experience an application or hang during gameplay when Grass Density is turned on.
- A system hang or black screen may occur when exiting SteamVR with multi display system configurations.
- Monster Hunter World : Iceborne may have lower than expected performance in some areas of the game on Radeon RX 5700 series graphics products.
- Video playback may exhibit corruption on Interlaced content in Movies and TV on Ryzen 3000 with Radeon Graphics Processors.
- PassMark may experience an application hang on some Ryzen with Radeon Graphics Processors.
- On Radeon RX Vega and older discrete GPUs and on APUs, enabling integer display scaling could result in a reduction of frame rate.
- Integer display scaling may not show up as available in Radeon Software on some GCN-based GPUs.
Known Issues
- Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
- Performance Metrics Overlay and Radeon WattMan incorrectly report higher than expected idle clock speeds on Radeon RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
- Radeon Software may open with an inconsistent window size or may not keep its previously set size when opened.
- Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
- Some games may exhibit stutter intermittently during gameplay on Radeon RX 5000 series graphics products.
- Desktop or In-game corruption may occur intermittently when HDR is enabled.
- Radeon RX Vega series graphics products may experience a system crash or TDR when playing games with Instant Replay enabled. A workaround for users experiencing these issues is to disable Instant Replay.
- A system crash or hang may be experienced when using Edge browser to play Netflix content.
- Some users may still experience black screen or system hang issues during extended periods of gameplay. AMD will continue to monitor and investigate reports of these issues closely.
Minha opinião:
Esse driver manteve todas as correções da última versão e trouxe novas correções, fora algumas otimizações.
Aliás, para mim, o melhor desse driver é justamente não ter perdido nenhuma correção do último. Isso é um sinal que o padrão de qualidade desses drivers podem começar a melhorar. Meu maior medo é que as correções fossem desaparecendo em novas versões. Se a AMD conseguir manter o que está feito em cada driver desse, não demorará muito para que os drivers finalmente cheguem no ponto ideal.
Nem tudo são flores; ainda há varias coisas a corrigir, e a AMD precisa ser mais rápida em várias dessas (Estão demorando muito para restabelecer o Enhanced Sync e alguns problemas que já estão aí há algum tempo).
O grave problema de Stuttering com a Fan permanece e nem sinal em uma nota, ou seja, o tutorial ainda é necessário para quem sofre o problema e parece que ainda será por um tempo.
Enfim, um driver melhor como o último.
