Sim, caso o PC não for reiniciado corretamente reseta.
As vezes desligo ele normal. Quando vou ligar pela manhã, ta resetado.
Onde você pegou esta Bios?Hell Yeah!! 5700 Red Devil + Custom Bios
Não é bios de XT, apenas a bios original reajustada.
- Nvidia lançou um driver com essa nova função do Win10 2004 uns dias atrás![]()
Windows 10's hardware-accelerated GPU scheduling is almost here
Windows 10 May 2020 Update (version 2004) is now available for seekers and it includes support for WDDM 2.7, but the option to enable hardware-accelerated GPU scheduling isn’t included yet. Hardware-accelerated GPU scheduling is the main feature of WDDM 2.7 and it allows the integrated/dedicated...www.windowslatest.com
Hardware-accelerated GPU scheduling is the main feature of WDDM 2.7 and it allows the integrated/dedicated graphics card to manage its own video RAM directly, which in turn give you better performance, reduced latency, increased average or minimum frame-rates, and improved video playback.
The hardware-accelerated GPU scheduling option isn’t included in the latest drivers, regardless of the graphics card (Intel, Nvidia or AMD) you’re using.
Support for WDDM 2.7 (Windows Display Driver Model) is included in both Intel and AMD drivers, but the catch is that the hardware-accelerated GPU scheduling option isn’t available in Windows Settings.
If you don’t see the option, you can force it by tweaking Windows Registry, which you should not, because it has no effect whatsoever: (não vai fazer diferença de qq jeito hjuauaua)
- Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
- Locate ‘HwSchMode’ and change its DWORD value.
- Set ‘1’ to turn it off and ‘2’ to turn it on.
For now, we are all in the same boat deep in a sea of frustration.
Departamento de marketing da MS achou legal, mas não tem muita informação real&oficial ainda rs
eu fiz em cima da original.Onde você pegou esta Bios?
Excelente hein. Mnha Nitro vem com Clock máximo de 2025/1200mV. Nunca testei aumentar mais o clock sem alterar o mV, mas pelo visto não conseguirei um resultado muito melhor. Ultimamente estou utilizando 2000/1118mV e 1785 VRAM, se aumentar um pouco mais a VRAM já crasha. E a voltagem pra 2000 não pode ser menor. Não tive tanta sorte.Hell Yeah!! 5700 Red Devil + Custom Bios
Valeu, instalei aqui e ficou muito top, Warzone ficou lisinho e sem as osciladas que davam antesRadeon™ Software Adrenalin 2020 Edition 20.5.1 Beta with Graphics Hardware Scheduling Highlights
Nada como ter concorrência no seu pé- Nvidia lançou um driver com essa nova função do Win10 2004 uns dias atrás
Windows® May 2020 Update
AMD is excited to provide beta support for Microsoft’s Graphics Hardware Scheduling feature. By moving scheduling responsibilities from software into hardware, this feature has the potential to improve GPU responsiveness and to allow additional innovation in GPU workload management in the future. This feature is available on Radeon RX 5600 and Radeon RX 5700 series graphics products.
1.20V é demasiado para 2020Mhz, baixe para 1.140V e vai subindo o clock até quando mantiver estável.Excelente hein. Mnha Nitro vem com Clock máximo de 2025/1200mV. Nunca testei aumentar mais o clock sem alterar o mV, mas pelo visto não conseguirei um resultado muito melhor. Ultimamente estou utilizando 2000/1118mV e 1785 VRAM, se aumentar um pouco mais a VRAM já crasha. E a voltagem pra 2000 não pode ser menor. Não tive tanta sorte.
aquela la era uma 5700 referencia, a Red Devil esta em 2150 1.14VVi um teste que tu fez com a 5700XT Red Devil com 2022mhz/1,075v, tu conseguiu melhorar esses valores ou é o pico do pico mesmo? Tenho usado essa config aqui e tem funcionado tranquilamente.
Amigos. Estava lendo a respeito do Zero RPM. Em alguns fóruns do exterior, li que após o Drive 19.2.3 a opção de ativar/desativar o zero RPM foi tirada. Acontece que baixei um drive anterior a ele e onde deveria constar a opção de marcar esta opção não está no local que deveria estar (olhei alguns vídeos no youtube). Li a respeito de criar um perfil e editar o XML e alterar o arquivo e usar o mesmo, porém não funcionou. A maioria do tempo do meu computador é usado como servidor de mídia pela rede e fica ocioso, sendo que gostaria de preservar os ventiladores.
É uma RX 570 4gb XFX com Bios original (a única disponível pelo que ví no Tech Power Up). Alguma sugestão? No MSI afterburner também não consegui diminuir muito a velocidade, no watmann consego baixar no máximo até 45% de rotação, se não me engano.
Uma 5700 xt referência consegue 2022/1075mV e minha Nitro só consegue esse Clock com 1145mV... Muita falta de sorte mesmo.aquela la era uma 5700 referencia, a Red Devil esta em 2150 1.14V
Boa tarde.Sua placa da suporte para o Zero RPM? nem todas tem essa opção.
devblogs.microsoft.com
Aqui com a 5700XT a opção não aparece para ativar, mesmo com windows 2004 e esse novo driver beta.Directx developer blog - Hardware Accelerated GPU Scheduling
Hardware Accelerated GPU Scheduling - DirectX Developer Blog
Introduction to Hardware Accelerated GPU Scheduling. Modernizing the GPU scheduler at the heart of the Windows Display Driver Model (WDDM).devblogs.microsoft.com
What to expect when switching to the new GPU scheduler
The transition should be transparent, and users should not notice any significant changes. Although the new scheduler reduces the overhead of GPU scheduling, most applications have been designed to hide scheduling costs through buffering.
The goal of the first phase of hardware accelerated GPU scheduling is to modernize a fundamental pillar of the graphics subsystem and to set the stage for things to come… but that’s going to be a story for a another time 😊.
We do not expect customers to experience performance regressions but if you encounter any, please be sure to file feedback at: https://aka.ms/submitgameperformancefeedback.
Lá no forum guru3d quem tem CPU mais antiga com 5700/XT notou melhora nos Call of dutty e outros pesados pra CPU - fim de queda de FPS abrupta
Estão dizendo por lá que é "outra linha" de drivers e a AMD não disse se vai incorporar isso nos drivers igual à nVidia... AMD malandra
Aqui mesmo com Vsync melhorou uns 2 ou 3 ms do frametime nos jogos, vou ficar com ele p eqto
Sim, sempre reinicio em modo de segurança e desinstalo pelo DDU.Vish.. rodou DDU antes de colocar ele? Talvez seja preciso garimpar os foruns de Windows pra ver
Unica dependencia é driver da placa de video mesmo, pra ter a opção lá. Tentei com outro driver criar a chave pelo regedit (dica de uns dos links antigos que postei) e nada aparecia lá
Aqui ainda não recebi a atualização 2004, ainda está na 1909. Está sendo gradativa, essa atualização?
Aparece assim aqui: "A atualização do Windows 10 de maio de 2020 está a caminho. Quando seu dispositivo estiver pronto, você verá a atualização disponível nesta página".
