joaorosini
PC Enthusiast!
17,540
7,527
Santo André - SP
Support For
  • Doom™ Eternal: The Ancient Gods
  • Watch Dogs™: Legion
  • DIRT 5™ Early Access
  • World of Warcraft™: Shadowlands Pre-Patch
Fixed Issues
  • Audio may experience instability when connected through an Audio Video Receiver via HDMI® on Radeon RX 5000 series graphics products.
  • Desktop may experience frame rate fluctuation when exiting a Vulkan® API game with Radeon FreeSync enabled on two or more display system configurations.
  • Uploading or streaming content to YouTube™ may be unavailable or not working correctly.
  • Genshin Impact™ is not detected or listed in Radeon Software gaming tab.
  • Some specific Windows® screensavers such as ‘Bubbles’ may cause an application crash when applied on Radeon RX 5000 series graphics products.
  • Graphical corruption may occur on desktop or at idle when two or more connected high refresh rate displays are Radeon FreeSync enabled on Radeon RX 5000 series graphics products.
  • Upgrading to Radeon Software Adrenalin 2020 Edition releases from Radeon Software 2019 Edition releases via Radeon Settings may sometimes fail with an error message.
Known Issues
  • Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
  • Performance Metrics Overlay and the Performance Tuning tab incorrectly report higher than expected idle clock speeds on Radeon RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
  • Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
Pedro Igor
588
464
Support For
Fixed Issues
Known Issues
Será que passa a 2070S de vez?
joaorosini
PC Enthusiast!
17,540
7,527
Santo André - SP
dacfeb31
980
501
Support For
Fixed Issues
Known Issues
Enhanced Sync é uma verdadeira lenda.
Reações: rgpc
joaorosini
PC Enthusiast!
17,540
7,527
Santo André - SP
Reações: dacfeb31
Keiji Kawamori
I'm Batman!!
5,030
2,935
Parece que as Big Navi, vão passar dos 355W:
Halseluk
2,178
2,885
Circuito das Armas - SP
Merda. Consumo igual ao da 3080.
Kael Andassol
107
218
Aparentemente então para ter uma performance similar a de uma 3080 vai precisar de ter um TDP similar também.
Interessante essa convergência todavia com diferentes quantidades de VRAM e frequencias.
guisalgado
164
Será que a linha nova das AMD, virá com algum concorrente bom para o NVENC da Nvidia? PQ meu amigo, pra stream, as AMD deixa a imagem muito pixelada.
Pedro Igor
588
464
Mas a concorrente da 3080 não é a XL?
a XT não fica entre a 3080 e 3090?
RHBH
6,483
9,822
São Paulo / SP
Pelo que li AMD viu o gap de TDP entre as placas dela e a verdinha e colocou mais CU e subiu clock até igualar pra extrair o máximo de performance.
"Se a verdinha pode e ninguém reclama, porque eu não?"
Jogada ousada da AMD, vai tentar competir em performance e preço, não no consumo.
Devem ter pensado "quem liga pra consumo em desktop"? Enfim... Vamos ver no que dá.
Se não ganhar em performance e o preço não for essas coisas, pode ser um tiro no pé
RHBH
6,483
9,822
São Paulo / SP
Pedro Igor
588
464
Só lembrnaod que o TGP da 5700xt era de 255w e o TDP ficou em 225w.
15% aproximadamente de diferença entre o TGP e TDP.
hexa
1,588
2,763
Não estou colocando muita fé nesses números porque o teste da Digital Foundry mostrou que a midrange RDNA 2 consome por volta de 150W, é muita eficiência pra uma placa no nível de uma 2070 Super.
Pedro Igor
588
464
2080S pelo o que os testes indicam.
Reações: hexa
RHBH
6,483
9,822
São Paulo / SP
Deve ser aquelas...
Alguns cenários 2070S...alguns cenários 2080S.
Oscila muito de jogo pra jogo. É só ver a 5700XT.
Pedro Igor
588
464
Deve ser aquelas...
Então, a 5700XT é mais fraca que o Series X, tem alguns benchs no youtube mostrando isso.
Os consoles dessa geração basicamente mataram as VGAs passadas
exclusive
Royal Enfield Meteor 350
2,462
1,570
Alto de Pinheiros - SP
Se tem processador bom da pra deixar bem próximo ao da Nvidia
Reações: Crowley_ES
flep
www.twitch.tv/flepgg
2,643
2,188
Vila Velha
www.twitch.tv
Não vi nenhuma novidade informada sobre os codecs da AMD pra streaming, e sinceramente acredito que eles não irão investir mais nisso com todo o papo sobre o AV1 com grandes nomes investindo no formato aberto.
MS já confirmou suporte do Windows a hardware decoding pra RTX30/BigNavi e suas próprias futuras placas, e os codecs estão evoluindo a cada mês, com Netflix e YT já experimentando a entrega de conteúdo em AV1.
2021 deve ser o ano que AV1 vai começar a se popularizar, e provavelmente em algum momento vai começar a mudança e AV1 vai estar disponível pra streaming no Twitch / YT
MineradoraBR
4,158
3,135
Qual a vantagem desse av1 ? Queria entender melhor como isso funciona . Eu tenho uma placa de captura usb dessas baratinhas , será que vou conseguir alguma vantagem ou só na captura com a placa de vídeo no PC rodando o jogo ?
Pedro Igor
588
464
Reações: AgleoEoleO
RHBH
6,483
9,822
São Paulo / SP
Mesma qualidade numa bitrate menor.
AV1 > HEVC (H.265) > AVC (H.264)
Os principais ganhos pro usuário:
Consumir menos dados do teu 5G pra abrir o mesmo vídeo na mesma qualidade.
Downloads/stream/buffers mais rápidos de carregar.
Quando existir decode via hardware, mais rápido e mais leve no aparelho do usuário.
Os principais ganhos para empresas:
Economia de espaço de armanezamento.
Os principais ganhos para operadoras/provedores de links:
Menor carga sobre o link.
Se o download/upload termina antes, o link/rota ocupado fica disponível mais rápido, aumentando a vazão da rede.
Os principais ganhos para criadores de conteúdos:
Quando existir AV1 encode por hardware
Menor bitrate na mesma qualidade, menor bitrate = menos carga de trabalho, mais leve e mais rápido que outros codecs.
Ta chegando...
Basicamente tá sugerindo que abram prevenda/reservas, usem captcha, vendam 1 por usuário e façam verificação manual dos pedidos.
Deveria ter colocar em letras garrafais
NÃO VENDER PARA MINERADORES.
carcier
275
127
Eu não vejo problema os mineradores até porque no final são usuários(eles compram em quantidades mas, de acordo com a news eles vao limitar logo...). O que ferra sao os bots scalpers que alem de darem um jeito de sumir o estoque ainda inflam o mercado de forma muito pior que os mineradores. O que quebra é que por baixo dos panos os caras dao um jeito e a gnt nao chega nem a ver o estoque
