O que é encoder Chip?
Alvinho
Gato
Todo mundo sabe que meu xbox uma vez por dia me mostra a tela E74 não é verdade?
Pois então, me mandaram um link aqui, que realizando alguns testes agente descobre EXATAMENTE qual é o problema.
* Turn the xbox 360 on, and wait till the 3 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code (as described below).
* Release the eject button and press it again.
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
* All four lights flashing - 0
* One light flashing - 1
* Two Lights flashing - 2
* Three lights flashing - 3
0001 power supply problem
0002 power supply problem
0003 (not yet known)
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 (not yet known)
0022 GPU Error / GPU Overheating
0101 (not yet known)
0102 unknown error - littereally means the console does not know what is wrong. possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
0110 Memory Error / Memory Overheating
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a currupt or missing Eprom.
1013 (not yet known)
1020 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1030 (not yet known)
Então, o meu problema é o 1022, problema no cabo AV ou encoder chip.
Visto que no dia em que desbloquiei eu testei o videogame com outros cabos AV, o problema não é no cabo, e sim no encoder chip.
Agora a pergunta que faço é.
Encoder chip?? wtf???
Xenos
¬¬ se tu tivesse me mandado teu email a 3 meses atras como eu pedi eu tinha te mostrado isso ai
nao eh nada novo nao...
cara, isso quer dizer q pode ser um problema no cabo AV(o que liga na TV), no conector, ou talvez no encoder chip, que é o chip q eh responsavel por fazer o sinal da TV, na frequencia certa...tipo o VG manda as imagens para ele e ele codifica pra TV reproduzir.
mas acho muito pouco provavel q seja isso
experimenta pegar tua escova de dentes, ou um pincel, e passar no conector da TV, nos pinos, talvez melhore o contato.
Alvinho
Gato
3 meses atrás nem videogame eu tinha.
Quando desbloqueei, além de testar em outros cabos AV, como antes havia informado, tb testei em outras tv visto que não é necessário levar a tv para o técnico que faz desbloqueio.
Mesmo assim, obrigado pela ajuda.
Xenos
foi mais ou menos isso ai, foi a um bom tempo q mandei uma mp pra tu.
mas tipo, tenta falar com o FREITAS.
me manda uma MP com teu msn q eu te adiciono e mando o telefone dele
so fala com ele....
Alvinho
Gato
o brodi, adiciona aê
[email protected]
Mas vo ligar no freitas não :p hauahuahuaha num quero arrumar esse problema... deixa ele assim, tá funfando.. queria só entender melhor o que ocorre.
