Após MEGA SENA:
Intel i7 965 / Water Cooler swiftech / Water Block Gold Edition / 12 GB Corsair Dominator GT 1800 / Tri SLI GTX 285 SSC com Water Cooler / Asus Rampage II / 4 Hds Velociaraptors 300 GBs Raid 0+1 / Thermaltake Spedo Ultimate Version / Blue Ray Disc LG / Fan Controler Zalman / Dual PSU Corsair 1000w HX / 12 Fans Cooler Master 90 CFM
