Placa Mãe....Qual a melhor?
  • Iniciador de Tópicos RFS007
  • Data de Início
R
RFS007
Guest
Boa tarde e feliz ano novo.
Gostaria de saber qual placa mãe é melhor para quem usa processador Pentium 4?
Valeu...
RFS007.:p
Broda
ASUS P4G8X
The P4G8X, leveraging Intel®'s latest E7205 chipset, supports Intel®'s Hyper-Threading Technology and processing power of 3.06GHz and beyond to bridge you to a new dimension of computing experience. With dual-channel DDR up to 4GB, the P4G8X provides the bandwidth for the most memory-intensive applications.
3GHz+ CPU and Intel® Hyper-Threading Technology support
Leveraging the Intel® E7205 chipset to support 3GHz+ P4 CPUs on 533MHz FSB, DDR memory, Intel Hyper-Threading Technology and a full-range of advanced features, the P4G8X Deluxe delivers a full-value, high-performance solution for today's most demanding tasks.
Dual-Channel DDR
Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market. The P4G8X allows you to hancle memory-intensive tasks with ease.
C.P.R. (CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Simply restart the system and the BIOS will automatically restore the CPU default setting for each parameter.
AGP 8X Technology
AGP8X (AGP 3.0) is the next generation VGA interface specification that enables enhanced graphics performance with high bandwidth speeds up to 2.12GB/s. With a bus of 533MHz, AGP8X is twice as fast as AGP4X.
Multi-language BIOS
ASUS provides friendly localized BIOS setup menu to help you configure your system as easy as possible.
** For multi-language BIOS, please visit the ASUS website for supported languages information.
Q-Fan Technology
ASUS Q-Fan technology intelligently adjusts fan speeds according to system loading to ensure quiet, cool and efficient operation.
ASUS® EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
Extreme Overclocking
ASUS P4G8X offers robust overclocking options to maximize your system performance.
Flexible CPU Core Voltage Adjustments in 0.025V increments over defaults
SFS (Stepless Frequency Selection) from 100Mhz up to 200MHz at 1MHz increments
Fixed AGP/PCI frequencies
ASUS propritary C.P.R.(CPU Parameter Recall)
AGP Warning LED
ASUS has designed into this motherboard an AGP Warning LED. The AGP Warning LED automatically stops you from turning on your system with incompatible voltage AGP (3.3V) cards, and protects from permanently damaging your motherboard.
ASUS EZ Plug™
The ASUS EZ Plug power connector lets you use your existing power supply and eliminates the need to buy a special ATX 12V power supply to support your Pentium 4 CPU.
AGP Warning LED
ASUS Reliability
All ASUS motherboards are designed and tested to meet the highest quality standards. Responsive customer support and frequent BIOS and driver updates ensure that you're getting the fastest, most reliable performance - all the time. All ASUS motherboards are also backed by a 3-year limited warranty.
Comprehensive Software Bundle
All ASUS motherboards include a valuable software bundle of popular third party programs that enable you to enjoy the full capabilities of your ASUS product:
Trend® Micro PC-cillin 2002 anti-virus program
InterVideo® WinCinema bundled (Gold version only)
ASUS® PC Probe for system monitoring
    22.7 KB · Visitas: 64
