tb uso o Mplayer
Só encontrei um problema com ele, qndo vou carregar a legenda via modo gráfico ele sempre fecha o video, só consigo usar legenda via terminal....
edivan@server:~$ gmplayer
MPlayer 2:0.99+1.0pre7try2+cvs20060117-0ubuntu8 (C) 2000-2006 MPlayer Team
CPU: Advanced Micro Devices (Family: 15, Stepping: 0)
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
Cannot load font: /home/edivan/Desktop/font-arial-iso-8859-1/font-arial-14-iso-8859-1/font.desc
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Opening joystick device /dev/input/js0
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
No bind found for key 'JOY_AXIS2_MINUS'
No bind found for key 'JOY_AXIS3_MINUS'
Playing /home/edivan/Desktop/Arquivos Geral/Azureus/The Butterfly Effect/The Butterfly Effect (2004).avi.
AVI file format detected.
VIDEO: [XVID] 576x320 12bpp 25,000 fps 768,7 kbps (93,8 kbyte/s)
Clip info:
Software: Nandub v1.0rc2
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 48000 Hz, 2 ch, s16le, 128,0 kbit/8,33% (ratio: 16000->192000)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Building audio filter chain for 48000Hz/2ch/s16le -> 0Hz/0ch/??...
alsa-init: 1 soundcard found, using: default
alsa: 48000 Hz/2 channels/4 bpf/69644 bytes buffer/Signed 16 bit Little Endian
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Building audio filter chain for 48000Hz/2ch/s16le -> 48000Hz/2ch/s16le...
Starting playback...
VDec: vo config request - 576 x 320 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1,80:1 - prescaling to correct movie aspect.
VO: [xv] 576x320 => 576x320 Planar YV12
[GUI] Loading subtitles: /home/edivan/Desktop/Arquivos Geral/Azureus/The Butterfly Effect/The.Butterfly.Effect Bob2Bob[AR].srt
SUB: Detected subtitle file format: subviewer
SUB: Read 1352 subtitles.
SUB: Adjusted 179 subtitle(s).
alsa-uninit: pcm closed
