[TÓPICO OFICIAL] Playerunknown's Battlegrounds
joguei umas três partidas, cai em servidores NA, mas estava liso rodando tudo liso acima de 100 fps, pelo menos pra mim deu uma melhorada.
Não sei porque mas parece que servidores de fora são melhor otimizados que os nossos. Alguém ja sentiu essa diferença ?
Para quem ficava querendo BF em PUBG. O modo conquest está ativo e funcionando.
Mas atrelada a bosta da mecânica do war mode
Alguém notou melhorias visuais no jogo? :hmm:
Ontem por varias vezes ficou bem perceptível os raios de luz pelos objetos...
As partias customizadas parece que houve mudanças
Event Mode: One Gun Warrior
Lock and load warrior, because this week’s event mode puts your skills with a single weapon to the test! In One Gun Warrior, you’ll start out with a weapon kit immediately upon drop. You’ll have to scavenge ammo and other supplies, but no weapons spawn in the world! Kill others to take their weapons or make it through the round with your own.
Possible Weapon Kits:
  • [SR] AWM with 4x Scope, Compensator, QuickDraw Mag, and Cheek Pad
  • [LMG] M249 with 3x Scope
  • [DMR] MK14 with Suppressor, QuickDraw Mag, and 2x Scope
  • [AR] Groza with Suppressor, Extended Mag, and Holographic Sight
  • [SMG] UMP with Flash Hider, Laser Sight, Red Dot Sight, Extended QuickDraw Mag, Level 1 Vest, and Level 1 Helmet
  • Win94 with Bullet Loops, Level 2 Vest, and Level 2 Helmet
    [*][SG] S686 with Choke, Bullet Loops, Level 2 Vest, and Level 2 Helmet
    [*][Pistol] P18C with Suppressor, Laser Sight, Extended QuickDraw Mag, Red Dot Sight, Level 3 Vest, and Level 3 Helmet
    [*][Melee] Frying Pan, Level 3 Vest, Level 3 Helmet, and Ghillie Suit
    [*][Throwable] Ten Frag Grenades
    [*][ETC] Crossbow with 6x Scope, Quiver, Level 3 Vest, Level 3 Helmet, and Ghillie Suit
    [*][ETC] Flare gun (Items from flare gun airdrops follow the normal flare gun loot rules)
Acquirable items from world spawn:
  • Ammunition
  • Medical items
  • Backpacks
  • Gas Can
EVENT SCHEDULE
STARTS: Oct 25, 7pm PDT / Oct 26, 4am CEST / Oct 26, 11am KST
ENDS: Oct 28, 7pm PDT / Oct 29, 4am CEST / Oct 29, 11am KST
QUEUES
TPP Only (This is to help balance out the different kits since there can be so much variance.)
RULES
  • 100 Players, in a free-for-all Battle Royale, will fight on Erangel.
  • This Event Mode will be open in TPP only.
  • Players will be given a random weapon kit at the start of the match with attachments, but without any ammunition.
  • Weapons will not spawn as world loot; win with your given weapon, or take them from others!
OTHER EVENT RULES
  • Solo mode only
  • Weather is set to Sunny
  • Red zones are enabled
  • General care packages are disabled
  • Killer Spectating is enabled
Aparenta ter melhorado no geral. PC de sobrinho com i3 2120 + gtx 660 estava bugado demais em FHD (baixo/médio). Ontem, ficou bem, com fps > 40, sem quedas bruscas. Só o avião e o salto que é uma loucura de 14-18 >> 32 >> 22 fps. Mas, ao menos dá pra pra jogar FHD.. em resoluções menores, fica muito ruim.. borrado, pixelizado.. não vê um carro!..rs
Não notei melhoria visual. Mas meu FPS voltou a ficar bom como estava no patch #21. O jogo está rodando muito bem pra mim.
Virou moda: lança-cancela. :facepalm::umad::fail::bwahaha::bwahaha:
essa Blue Hole ta mais perdida que eu em Pollyana com 10 fps
:bwahaha::bwahaha::bwahaha::bwahaha::bwahaha:
Esse jogo e como no casamento, na alegria e na tristeza, mas não largamos nunca.
Erro em PUBG fez com que usuários de placas AMD com driver 18.9 fossem banidos
Durante a noite a equipe de anti-cheat teve trabalhar em inúmeros bans por engano no PC que tinham uma coisa em comum - suas placas de vídeo AMD com driver 18.9.1 Adrenalin. Sim, aparentemente PUBG decidiu que usar GPUs Radeon para jogar o battle royale era trapaça.
Link da notícia ??
Colocaram servidor SA no modo DUO FPP ?
Acabei de cair em uma partida com ping de 50
Ja tinha a algumas semanas já, se não me engano desda atualização que tirou a opção de escolher os servidores.
