[Qual programa] Inserir capas dos discos nos mp3
raftaro
Pessoal, que programas vocês usam para organizar os mp3? E principalmente para inserir as capas dos albums.
Mp3tag 2.42b Beta
Mp3tag is a powerful and yet easy-to-use tool to edit metadata (ID3, Vorbis Comments and APE) of common audio formats. It can rename files based on the tag information, replace characters or words from tags and filenames, import/export tag information, create playlists and more. The program supports online freedb database lookups for selected files, allowing you to automatically gather proper tag information for select files or CDs.
Mp3tag supports the following audio formats:
Advanced Audio Coding (aac)
Free Lossless Audio Codec (flac)
Monkey's Audio (ape)
Mpeg Layer 3 (mp3)
MPEG-4 (mp4 / m4a / m4b / iTunes compatible)
Musepack (mpc)
Ogg Vorbis (ogg)
OptimFROG (ofr)
OptimFROG DualStream (ofs)
Speex (spx)
Tom's Audio Kompressor (tak)
True Audio (tta)
Windows Media Audio (wma)
WavPack (wv)
Main features:
Write ID3v1.1-, ID3v2-, APEv2-Tags and Vorbis Comments to multiple files at once
Full Unicode support
Support for embedded cover art
Automatically create playlists
Recursive subfolders support
Remove parts or the entire tag of multiple files
Rename files based on the tag information
Import tags from filenames
Format tags and filenames
Replace characters or words from tags and filenames
Regular Expressions
Export tag information to user-defined formats (like html, rtf, csv, xml)
Import tag information from online databases like freedb or Amazon (also by text-search)
Import tag information from local freedb databases
Support for ID3v2.3 (ISO-8859-1 and UTF-16) and ID3v2.4 with UTF-8
and much more ...
Vou testar esse ai, sempre quis um bom programa pra organizar.
O que faço nas minhas é usar o Winamp para adicionar todas as informações nas MP3 (uma opção dele faz isso) e depois mandar o iTunes buscas as capas. Mas mesmo assim iTunes quase nunca acha músicas nacionais e Winamp muitas vezes coloca informações erradas.
Alguém teria um tutorial de como se utiliza esse programa ? Instalei aki mas não entendi nada.
Eu uso o MediaMonkey, ele traz um gerenciador de midia completo, eh possivel fazer a busca de todos os arquivos mp3 e video no disco, edição de tags e ateh procura na internet caso a tag possua jah o nome do album ou qualquer outra info de artista / album.
Pena ser pago :no:
Eu também não...Meio complicado o programa!
