Mais a p5n-e sli suporta até 8gb tbm!
'4 x soquetes DIMM de 240-pinos suportando até 8GB de memoria DDR2 800/667/533'
Mas vou ver essa da Gigabyte ai
E aah. eu tenho um isso ai aqui em casa. esse filtro de linha. 'regua'
sim e conhecido como regua tb asuhasuhas
Olha as especificacoes da Gigabyte GA-P35-DS3
CPU Supports Intel® Core?2 Extreme Quad-Core / Core?2 Duo / Intel® Pentium® Extreme/ Intel® Pentium® D processors
Supports1333/1066/800 MHz FSB
Chipset Northbridge: Intel® P35 Express Chipset
Southbridge: Intel® ICH9
Gigabit Lan Controller
8 Channels ALC889A Audio controller
Memory Supports DDR2 1066*/800/667 memory
Dual Channel architecture supports up to 8GB by 4 DIMM slots
Expansion Slots 1 PCI Express X16 slot
3 PCI Express X1 slots
3 PCI slots
Form Factor ATX form factor, 305 x 210mm
Internal I/O Connectors 1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x floppy disk drive connector
1 x IDE connector
6 x SATA 3Gb/s connectors
1 x CPU fan header
2 x system fan headers
1 x power fan header
1 x front panel header
1 x front panel audio header
1 x CD In connector
1 x S/PDIF In header
2 x USB 2.0/1.1 connectors (supports 4 ports)
1 x chassis intrusion header
1 x power LED header
Back Panel Connectors 1 x PS/2 keyboard port
1 x PS/2 mouse port
1 x coaxial S/PDIF Out connector
1 x optical S/PDIF Out connector
1 x serial port
8 x USB 2.0/1.1 ports
1 x RJ-45 port
6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
BIOS Supports Virtual DualBIOS
1 x 8 Mbit flash
Use of licensed AWARD BIOS
PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
Other Features Ultra Durable 2 Motherboard
All Japanese manufactured solid
Over-clocking Enhanced
