aderbalnunes
3,418
1,509
João Pessoa
aderbalnunes.com
K39 ITX montado,
8IPBBegzLKt9B37RZAZxxkt234XId7L3Z8n2PXe73NIP8ibBIyvGM-CZiTbUjJTfIhdyBcyCdXuhIQcTxGrTzqNKIAZlZ0Ggsrlz0mshzJm099WntC3J9KQoII4L-M6beOEwwcp7o6qF0dJ2blnMREujASymdVy5kg5HVwpKsHl2bzZh8_tH-ysxjGA-3QMjjc0xmD6LVb0wpvYBiLhpRLt7G8CkGDddFl3GkLEzJ8cTzvNSq1M8ndFgbMbGLEWd3m3feYiJJUeI0gb0nJ37MLQy4HXTNBHXlx_wre9nLdfpfHkDZ8B16XB1MrMMLfagF0RpUhKUjq2j6_YGPUJUBaW2zDAyl6ZD33PmsB644DyufhOIVSPvgD7Fxb4YwjcGrQomq3cI2cSviLX5A1MJ5Od_LnpBHkkfaMhVdMSCMwqfr_pmop_1bK7dbeGCBYzj_1jZz-jOK2RANOG14w_uajN4TxIXUkOq6Sa0sQTqTWqSk_000EMWaCv4kWQLDePpwaqOU08ANwO2adzC1zSKyv0vdZ-b4b4t_ItJpv_MWhlppX3DDgmJadVDyzxjmPvGLxf8VkKXu-7NapPg0WfLLrh0SY3YbLbb25uuTUrmlT3lCxSuLa2EiyDoCN-e4wTMJovcnow6GGm248_ZZdn4JSB1Aw=w708-h944-no
5iAZjWDfb-WgaVgGzT1QJDHQ4acDwOO39bFX1hh80jBfL246PAjJbXIuWe2hC8ldQSsr8PHgjzlFd-Vpk93HKgGqW88rgJ0HwMyHTNSStGXKf1Rv1BHNYE0KsGJRreOjtiMLU2KQLQ2HC6TcnxVT-t8UL7kc5AABmo2UUNFfrZhgJHTx486qimzwSTGX8PkE-P5nS0ovhszbbyEOG_DgDodkyKO1mkCv0DeM2G3qqccuVustncz2kBUR8wIIPTzNaQsVHHOQWK3yM4kUrKLfqLaYKo171idSEWY0JFvb_E4vQemwhhFDWI_cqvBdjfJhQPKxllk_u9geiZsfHgubmhz861la4vuAjVe58wQ-o2na3N2dLdgYfTqhwVIenXBSxTQFqe_JWuCfi0zK9Tjt6RqjgY7uyPvTszqg473cloG_KH_kiDB0JkF_Rlg5eLNWyqT8TZdEOKTdMrz_hw1seo9MKwSxnK0P0knVGaao1U9czhnGv8TYwnm6oCMR_cNzNBcXntCP14d6Vq243HofTiVCb3sjiiZ0VfHD5Q_7CEiAM2oQeezyDZaT8OBi-TK0kpU7u3LgmMrISis4sPfhbqWi5Moyay3RZrYZzrRjDBoGWjNvWfxq2yb4Jft_SbxKl2sNEMJ1-F7xugv2FB4GAdgh6g=w708-h944-no
Bem dificil de montar, mas está funcionando beleza
Ryzen 3 1200
B450 i Aorus
1TB ssd micron
16GB ram 1 reeino aliexpress 8gb ,1 smart 8gb generiquissima
fonte 230w chinesa flex atx de baixo ruído
RX 570 itx sapphire.
Undervolt na rx e trabalhando no over suave do ryzen e tentar subir as memorias diferentes uma da outra.
esperando um cooler pequeno, provavelmente um jonsbo hp 400, mas ainda vou ver o que faço,por enquanto a tampa do processador nao fecha hue
Deu bruxa nas imagens.
Celso_Aoryu
313
275
FelipeAbreu
231
132
Alguem ficou sabendo de algum modelo 2060 de 1 fan?
rodrigooocosta
233
92
Galera qual a chance de haver uma 2050 ???
Estou a um ano sem placa de vídeo minha ultima foi a 1050ti da PNY único fan, caso não haja lançamento de uma 2050/2050ti seria uma boa opção uma 1060 de 6Gb para minha configuração da assinatura (quero comprar mais um slot de 4gb 2133mhz ou então ir logo para um único de 8gb pois o preço esta mais convidativo)????
aderbalnunes
3,418
1,509
João Pessoa
aderbalnunes.com
Rapaz, espera um pouco que parece que vai sair a linha GTX 11xx (é isso mesmo) teóricamente uma RTX sem o inútil ray tracing
bcorreia
1,784
1,999
Acho que na linha 50 só vai rolar a GTX1150, mesmo a RTX2060 pessoal ta reclamando porque parece que a placa não tem poder suficiente para segurar a onda do ray tracing, com vários reviews recomendando esperar as GTX1160.
Reações: rodrigooocosta
rodrigooocosta
233
92
Vamos aguardar então.
rodrigooocosta
233
92
bcorreia
1,784
1,999
Mano e os projetos com os processadores APU Am4 chega as lombriga piram.
Essa m.2 na traseira aparentemente ligada direto no processador é interessante pra adicionar uma placa de vídeo, agora gostaria de ver uma versão csm da asus, achava a versão deles a mais interessante, com portas sata normais e duas redes. Agora por 109 dolares com o gabinete e a fonte externa de 120W não achei ruim não, pena que dificilmente chaga por essas bandas.
TheShadow
387
495
Fala galera, estou me desfazendo por completo do meu PC, menos monitor. Inicialmente iria ficar só com o Smartphone mas preciso de Windows/Desktop.
Me interessei inicialmente pelo DEX da Samsung que transforma o Smart em um Desktop mas vi que não compensa, então conheci o Intel Compute Stick.
Sei que o que busco não é diretamente ligado ao proposito do tópico mas, existe alguma opção que posso comprar ou montar (com peças usadas) melhor que o Intel Compute Stick? (Até uns R$300~400,00)
Preciso de algo extremamente compacto (Sei que igual ao Stick é impossivel) pra colocar atras do monitor e de baixo consumo apenas para Internet, Documentos, Netflix, Youtube e .MKV em 1080p. (Windows 10)
Consigo montar um Mini ITX muito compacto com esse orçamento? ou realmente pro que busco esse Compute Stick será a melhor opção? (Média de R$300). E sim, eu sei que o desempenho dele é bem limitado.
Intel Compute Stick: Intel Atom Z3735F (1.83Ghz, Quad-core), 2GB RAM, 32GB Armazenamento, Windows 10
Agradeço a quem puder contribuir com alguma informação ou caminho.
rodrigooocosta
233
92
Mano estou um por pouco por fora dos valores mais para montar um ITX por R$ 400,00 aqui no BR é praticamente impossível, porém pode ser que aqui nesse tópico deva ter algum manolo que tenha algumas peças a venda.
Reações: TheShadow
NeoConker
Unregistered User
5,441
7,094
Sampa
Infelizmente não, o mercado de PCs já está inflado a algum tempo e as lojas vem trazendo só o main stream.
Reações: TheShadow
aderbalnunes
3,418
1,509
João Pessoa
aderbalnunes.com
Se for pegar o Stick da Intel, se der pra instalar o Linux (Mint por ser mais leve) eu recomendo. Mexi em um stick desse e o bixu n é a mil maravilhas como parece ser nos vídeos. Não sei se era por causa do sistema.
Reações: TheShadow
ThomasTheLord
188
135
São José do Rio Preto - SP
Imagino que nessa faixa de preço você consiga algo usado, como aqueles J1800 ou os mais novos. Dá um especulada no ML pra ter certeza. Mas assim, tb não dá pra garantir que vá rodar tudo em 1080p com qualidade. Nunca vi muitos testes mas nenhum que vi foi MUITO animador.
Reações: TheShadow
bcorreia
1,784
1,999
Tive uma Lattepanda com essa configuração de hardware, funcionava até bem com um linux usando xfce, agora, se possível pegue um com 4GB de ram.
Reações: TheShadow
AthanatosITX
PCqueCabeNaMochila
679
646
São Paulo/SP
Garoto esperto!
Interessante - além de todo o restante do projeto - é esse water cooler que está usando. Alguém conhece o modelo?
Reações: douglasdcds
douglasdcds
Comunidade ITX
1,294
760
Cachoeirinha
Bom dia, pessoal
Ontem foi dia de instalar o M.2 da Kingspec que eu tinha comprado no Ali, que chegou em uns 15 dias, mas com as correrias de final de ano não tive tempo de instalar, ainda mais que lembrava da bagunça lá dentro e ficava protelando.
Abaixo uma foto de como estava antes, com o gigantesco cabo de alimentação para o único SSD da Sandisk que eu utilizava antes, mais o SATA na placa mãe, as extensões que eu era obrigado a usar nos Noctua por não ter como me organizar na bagunça de antes, com o SSD no lado da fonte e tudo mais.
Aqui o M. 2 totalmente minúsculo que comprei, optei pelo menor tamanho possível e confesso que até instalar achava que aquilo seria um memory stick antigo da Sony que o chinês tinha me mandado pra me enganar. Pra quem pegou a evolução dos HDD 3.5 e se impressionou com os 2.5, depois achou inacreditável o peso dos SSD o M. 2 é algo surreal de tão minúsculo, além de simples de ser instalado.
Agora o resultado dos cabos na mesma situação da foto anterior, apenas com os fans removidos. Aproveitei para tirar a espuma frontal e ver se ajuda no fluxo de alguma maneira, organizei muito mais até do que parece, os pequenos detalhes que dão a esvaziada geral que se nota depois, usei pedaços de dupla face para fixar alguns cabos e não deixar nada solto. Instalei o cabo redutor de ruído no Noctua da traseira, isso diminuiu absurdamente o barulho que já não era alto. Impressionante como o gabinete todo agora está absurdamente silencioso, computador fica cerca de um metro à minha direita, só consigo escutar alguma coisa se desligar o ar condicionado e não tiver nenhum barulho na rua.
Infelizmente não tem muito como deixar a vista mais limpa com dois fans no topo e o radiador com suas mangueiras torcidas lá dentro, mas já tem espaço livre suficiente e posso dizer que fiquei bem contente com o resultado, tudo funcionando perfeitamente e agora posso dizer que estou plenamente contente. O cable mod eu adiei novamente, vou acabar comprando os crimps e o alicate crimpador correto pelo ali e esperar, não estou com a mínima pressa agora.
aderbalnunes
3,418
1,509
João Pessoa
aderbalnunes.com
Os preços de peças estão altíssimos mas é desesperador ver o preço de placa mãe ITX :bua:
HRO
308
1,440
O problema desses Stick é que é tanta porcaria no Windows 10 que não sobra espaço nem pra atualizar ( da uns Linux compatíveis, mas nunca testei ). Tenho um desses e no começo era uma maravilha, mas fica limitado com o tempo, uso até hoje, mas poderia ter um com mais espaço e principalmente mais ram.
NeoConker
Unregistered User
5,441
7,094
Sampa
Bom dia, pessoal
Belo upgrade!
Tambem sou fan do SSD m.2, é pura tranquilidade, sem cabos e praticamente sem ocupar espaço.
As coisas foram evoluindo, mas o SATA não passa da 3.0 com 500mb/s, então os PCIeX dominaram.
Alias, a Toshiba lançou o menor m.2 possivel de até 1 TB, é single chip (controladora + NAND)
Celso_Aoryu
313
275
Bom dia, pessoal
Impressionante como tirar 2 cabos do "meio da avenida" já da aquela limpada na paisagem. Tinha pretensão dessas mudanças, mas vou aguardar o MITO dar aquele help na economia primeiro.
Tava louco pra montar uma maquininha assim pro meu filho, to arrumando o quarto dele e quero otimizar os espaços e isso incluir tirar o "anão vermelho" do chão (PCYES DWARF Vermelho).
Pra quem o link das fotos bugou, segue um mini algbum do google photos.
https://photos.app.goo.gl/5y5CVpNXFXWFBY1j6
Agora sim... ficou maneiro o bichinho.
