You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Super MIDI Pak - Cartucho que transforma o Super Nintendo em um sintetizador MIDI
Jogador de Videogame das décadas 1980/1990
Features
- Compatible with Super Famicom, NTSC/PAL Super Nintendo, and Super NT
- 16 polyphonic midi channels with independent settings multiplexing over 8 voices
- Standard MIDI sustain, sostenuto, legato switch, portamento (glide), pitch bend, vibrato, pan, volume
- MIDI mono mode (mode 4) with legato operation
- All SPC700 DSP registers are directly writable via CC messages, including echo registers
- Comes with Square Wave, Sine Wave, Triangle Wave, and Sawtooth samples.
- New samples can be uploaded via WebMidi application (Windows/Mac/Linux), automatically converts from SPC/WAV/SF2 formats.
- USB Micro-B and 3.5" TRS Type A MIDI interfaces, cables not included
- USB interface is galvanically isolated to prevent ground loop noise
- Save / restore device state across power off and reset
- Play existing SPC files
- Firmware upgradable
