[TÓPICO OFICIAL] Windows 10
zex
2,666
970
instale tema classico no windows pra deixar mais leve, ficando assim
http://bertrand.deo.free.fr/TEMP/w8classic.zip
Eu nunca notei nenhum ganho de desempenho, principalmente ganhos de FPS nos games ao usar temas simples assim, isso desde a época do Xp..... Talvez desse diferença de o PC fosse muito , mas muito ruim..... Mas no geral eu nunca percebi ganho não...
marcostutu
600
101
esse ganho de desempenho foi mais pro w7 do que pro 10...
dan70s
1,328
743
47
Windows 10 Insider Preview 14367 disponível no fast ring.
http://changewindows.org/build/14367/desktop
Start and Action Center
  • If a Quick Action turns a certain functionality in your device on or off (Bluetooth, Flashlight, etc.) it will now show On/Off for a short period
Cortana and search
  • Cross-device notifications should now be more reliable and faster
User Interface
  • The width for the Japanse 12 key keyboard is now wider on small screens in portrait mode
Settings
  • Visual updates and others
    • The icons under Update & Security have been updated to be more reflective of their meaning
System
  • Handwriting Recognition support for 23 additional languages
  • Ctrl + Shift + P can now be used to turn of Private mode when Japanese Input Method Editor is used
Apps
  • You can now make a screenshot and open Feedback Hub directly with Win + F
Fixed issues
  • Fixes an issue where notifcations from other devices would display emojis as square boxes
  • Fixes an issue where some emojis would appear as square boxes in apps like Notepad
  • Fixes an issue with the Destkop App Converter Preview
  • Fixes an issue resulting in the dialog when joining the PC to an Azure AD appearing large on certain devices
  • Fixes an issue where the Win + A wouldn't work if the Action Center icon was turned off
  • Fixes an issue where notification would keep the Action Center from launching when their toast was still visible
  • Fixes an issue where Cortana would not show some system settings for some terms
  • Fixes an issue where the network flyout could change color from white to black when dark mode is used
  • Fixes an issue where PowerShell shortcuts on the taskbar could only open one functional window, while other windows would not accept input
  • Fixes an issue that caused Sticky Notes to flash black and white when a certain number of notes was already created
  • Fixes an issue that caused Office apps to not show up in Most used in start
  • Fixes an issue where Cortana would launch behind the Ink Workspade when activated with "Hey Cortana"
  • Fixes an issue that caused explorer.exe to crash when selecting "Open Command window here" from File Explorer's context menu
Known issues
  • Narrator won't launch when toggling the switch to on in the Settings app
  • Using quick-reply in notifications from your phone will only work when the phone's screen is turned on
vinga
982
380
abaxei a ISO do windows 10 inside preview alguem saber informar se da pra instalar sem perder os arquivos???
liloperretti
791
82
Cortana and search
User Interface
Settings
System
Apps
Fixed issues
Known issues
Acabei de fazer uma instalação limpa da Build 14366 ja saiu a 14367 hauhauhauhau, la vou eu de novo.
sid_brain
Hey ho, Let's go!
14,149
4,059
Santo André-SP
Ta baixando de onde as ISOs? Peguei a 14342 no site da MS e instalei ontem, sei que já saiu duas depois dessa mas não encontro pra baixar
Na 14432 eu não condigo ativar pra receber as builds insider:poker:
liloperretti
791
82
Eu mesmo crio as isos com o arquivo install.esd.
blacklynx
3,638
894
Amigos, acho que vou voltar a usar o windows 10, consegui solucionar alguns dos problemas que tive na última instalação do SO.
Uma coisa que recomendo a todos: jamais instalem versões modificadas, pode ser que elas funcionem bem, mas as chances de vc ter problemas são enormes.
Na minha última tentativa com o windows 10 usei um programa chamado MSMG Toolkit, removi uma penca de coisa do sistema, tipo cortana, onedrive, telemetry entre outras.
Como resultado, apenas fodi o sistema como um todo, pra alguns essa ferramenta funciona que é uma beleza, mas pra mim só trouxe problemas.
Estava com um problema crítico de lentidão no sistema, instalei n drivers para tentar solucionar o problema e nada dava certo.
Testei o w10 em uma VM instalando ele normalmente e para minha surpresa funcionou tudo sem problemas, todas as opções ok, rodando liso :melior4:
Outra coisa que notei é: caso tenha algo que vc não goste no sistema, não o remova na marra, tipo deletar o mesmo, alterar sua presença no registro e tal. Veja se há alguma opção no próprio programa para desativá-lo, isso elimina muitos problemas, um exemplo disso é a cortana e onedrive. Um app que muitos odeiam: windows store, mas não removam isso, é pedir pra ter muitos, mas muitos problemas no sistema.
Muitos deletam esses dois logo de cara, modificam o registro para eliminá-los, mas no fim só traz mais problemas, principalmente a cortana, pois ela é necessária para várias funções do sistema, muitos serviços do W10 necessitam das dependências dela. O onedrive talvez nem tanto, mas ela é super prejudicial removê-la, então o melhor aqui é apenas desativá-la nas opções dela.
Algo que ferrou e muito a performance no meu sistema na última instalação foi o driver do chipset, os drivers da série intel rapid storage technology causam o terror aqui, até hoje não sei qual o motivo disso.
Ainda referente a esses drivers, sempre instalo apenas o driver, sem o software, seria esse a causa da performance ruim? No momento, qual versão do rapid storage technology é mais indicada para o windows 10? Um driver que se sai muito bem aqui e que uso constante é o intel chipset software 9.4.0.1027, sei que é antigo, mas funciona super bem aqui, meu sistema fica sempre liso com ele, coisa que não acontece com o rapid storage.
Até que o windows 10 melhorou bastante nesses últimos meses, muitos problemas irritantes foram corrigidos, apesar de alguns ainda continuarem, mas mesmo assim, o sistema está bem estável.
No mais é isso galera, acho que dessa vez irei me dar muito bem no 10, na VM ia de boa o sistema, então acho que vou conseguir ter bons resultados agora que consegui resolver vários problemas da instalação anterior. Agradeço de coração pelas todas as dicas que os amigos me passaram na instalação anterior, espero que agora eu tenha uma experiência bem legal no 10, na VM consegui, espero que na real seja ainda melhor.
Voltando pra deixar meu feedback sobre a instalação. Foi como eu tinha imaginado, bastou instalar o windows 10 normalmente, sem alterações e nada de problemas, tudo fluindo normalmente.
Então, volto a repetir a dica que falei no post anterior: jamais usem ISOS modificadas, pois as chances delas darem problemas são enormes. Não é porque funcionou com alguém que dará certo com vc, é muito mais provável que lhe cause problemas inimagináveis, então fica ai a dica, nada de ISO modificada.
Uma coisa boa na minha mobo é que o windows 10 não possui driver de rede pra ela, algo que acho bom, pois evita do windows update sair instalando driver loucamente. Aproveitei pra instalar todos os drivers, exceto o de rede, pois ainda precisava configurar o WU pra ficar apenas no modo de notificação, nada de atualizações automáticas.
Só depois de ter feito isso que instalei o driver de rede, o WU apenas atualizou o sistema, nada de mexer nos meus drivers tipo vídeo, áudio, monitor e etc. Também configurei o WU tanto pelo gpedit quanto regedit para não permitir atualizações automáticas, isso ajuda bastante. E pra finalizar, em propriedades do sistema/ configuração de instalação do dispositivo deixei selecionado "não", isso evita do WU instalar drivers sem minha permissão.
Pessoal, só fazendo isso meu W10 já estava funcionando perfeitamente, tudo liso e sem problema algum. Daí pra frente, depende do gosto do usuário configurá-lo da maneira que gostar. Eu mesmo desativei muita coisa que não uso, tipo cortana, onedrive e afins. E lembrando, apenas desativar não deletar, isso é algo que não dá certo no windows 10.
Percebi que no 10 os programas e serviços são muito dependentes uns dos outros, por isso que quando vc remove algo na força ferra o sistema, exemplo a cortana e onedrive. Seus arquivos são dependências para várias coisas no sistema, deletar um deles é pedir pra passar raiva e muita dor de cabeça, então fica a dica: caso não precise de algum app/serviço, desative o mesmo mas não o delete, isso é o suficiente.
Algo bom pra configurar e deixar o win10 liso é o gpedit e regedit, mas aqui é perigoso: só mexa nisso se vc souber o que está fazendo, não tente mexer por conta própria, pois é pedir pra detonar tudo, mas caso saiba operar os dois, garanto que a recompensa é maravilhosa.
No meu, alterei várias coisas nos dois e mesmo assim o sistema está lindo, sem falhas e rodando perfeitamente. Telemetria bloqueei tudo por eles, apps, segurança, internet e etc, passando 100% no sfc /scannow.
Então é isso galera, dessa vez está sendo super agradável usar o windows 10, já aprendi como resolver os principais pepinos dele, com isso fica super fácil utilizá-lo da pra frente. Estou super satisfeito com a performance dele, bem mais rápido e estável que o windows 7/8/8.1.
E algo interessante que achei no tenforuns foi a dica contida no 6º post desse tópico: http://www.tenforums.com/performance-maintenance/29947-sfc-some-corrupt-files-can-not-fixed.html, finalmente achei uma dica que funcione de verdade esse comando DISM. Usando como explicado por esse usuário funciona perfeitamente, resolvi meu problema de uma dll corrompida aqui com ele, foi só fazer isso e dll reparada.
Então que ainda está em dúvidas em instalar ou não o windows 10, recomendo que tentem, pois depois de configurado, ele fica perfeito. Vale a pena tentar pessoal, vlw!
Reações: rntbarbosa
dan70s
1,328
743
47
maur0
9,940
3,428
Curitiba PR
será que alguma hora a ms consegue melhorar desempenho/performance do win10, pq por enquanto ta muito mais devagar que 8.1, pelo menos em maquinas fracas com baixa memoria.
GomeZ
840
134
Estou trocando minha placa de video, no caso de eu formatar, a nova instalcao não vai ativar por causa disso? Eu tenho que usar o serial e fazer algum procedimento?
liloperretti
791
82
tbs
681
75
Bem provável que não. Dias atrás mesmo anunciaram que os requisitos mínimos do Windows 10 vai aumentar de 1 para 2GB de memória.
Fonte aleatória.
marcostutu
600
101
Foco do Windows10 foi pra computador né amigo.
Jpiltz
222
275
Nem precisa perder tempo formatando de novo, só desinstale os drivers antigos caso mude de AMD para Nvidia ou vice versa. Use o Ccleaner pra limpar os registros antigos do windows.
A treta de reconhecimento da licença com uma mudança de hardware, só se aplica as Motherboards.
Nunca tinha pego uma build tão bugada igual essa 14367, voltei pra versão antiga e larguei de mão o fast ring do windows, a partir de agora, quanto menos atualizações, melhor.
liloperretti
791
82
Reações: sid_brain
sid_brain
Hey ho, Let's go!
14,149
4,059
Santo André-SP
Inominável_42
Pimentorium in anus outrem refrescus est
3,461
35,073
Longe
Ainda estou com o Windows 10 Insider Preview 14925 instalado e ele vai bem nas tarefas banais, internet, video, música, mas não sei porque cargas dágua quando vou rodar um jogo, este jogo fica completamente lento, com fps baixíssimos.
Este problema começou de um dia para o outro faz mais de um mês, e já atualizei o driver da vga.
Como o W10 é 80% voltado pra jogos, me sinto prejudicado.
marcelogon
1,220
89
PIABETÁ-RJ
Tô desesperado, instalou a Build 14367, e a minha placa mãu F2 A85X-UP4 ficou sem som pelo HDMI, no gerenciador de dispositivo diz que o drive tá funcionando perfeitamente, mas no painel de controle som o HDMI aparece com a seta vermelha e o som não funciona, perto do relogio o icone de som tá com o x vermelho. Me ajudem se puderem.
dan70s
1,328
743
47
Já experimentou reinstalar os drivers?
Além disso, vale lembrar que compilações do Insider não são feitas pro usuário final.
Perseguido
604
88
Estou relutando de todas as formas pra voltar pro Windows 10, instalei o 7 e acho o visual dele muito superior ao do windows 10.. Não sei o que fazer kkkkk
Reações: torrentman
torrentman
40,340
7,466
Eu também prefiro o Windows 7 ao 10, porém o Dx12 me fez pensar sériamente no W10 já que tenho VGA da série 9xx.
Se tivesse Dx12 no Windows 7 nem migraria. Mas é necessário, e então estou aprendendo a conviver com o W10.
Foi a mesma coisa quando larguei o Windows XP para ir pro 7, porém na época foi mais fácil pois o Windows 7 é muito agradável de usar, assim como o XP.
