Não é ai não amigo, clica em cima do alto falante na barra de tarefas com o botão direito, abre os dispositivos de reprodução e lá voce desabilita o som do seu monitor
Isso resolve parte do problema (mesmo eu com caminho e processo diferente, no fim o botão direito não funciona e não conseguia fazer isso - resolvia só parte da coisa pois voltava ao estado anterior no reboot).
Neste link achei algo: https://answers.microsoft.com/en-us...t-window/c47b5fca-cc6d-405e-b563-5ba0a4c82892
I ran into this issue after updating to the Fall Update (1709) for both my Personal Desktop and my Work Dell Laptop. The only work around I found was to restart Windows Explorer in Task Manager or signing out and back in. When I signed out I would get
the "Task Host Window: microsoft\windows\plug and play\device install reboot required". After searching this I found a dutch (?) website (https://www.deskmodder.de/blog/2017...ate-oder-neustart-automatisch-abzuschliessen/).
Apparently Microsoft added a new option in the Accounts section in 1703 (Settings -> Accounts -> Sign-In Options) called "Use my sign-in info to automatically finish setting up my device after an update or restart.". The dutch website says (according the google
translate) the option doesn't really work and to turn this option off and it should fix the task bar/start menu issue. I am testing this on my desktop at the moment, shutting off/restarting my Desktop, and haven't ran into the task bar/start menu issue yet.
