A RESPOSTA É OBVIA, PORQUE OS APLICATIVOS PARAM DE SER ATUALIZADOS HUEAHEUAHHUEAHUAE
E ISSO NUNCA GARANTIU QUE ALGO REALMENTE FUNCIONE, TEM APLICATIVOS QUE JAMAIS FUNCIONARAM COM ISSO... PROCURA OQUE ELES MESMO AFIRMAM SOBRE, JUVENA.
ISSO NAO MUDA O FATO QUE QUEM QUE SE ADEQUAR O WINDOWS SÃO OS APPS E NÃO O WINDOWS, TÁ DIFICIL ENTENDER OU QUER QUE EU DESENHO NO PAINT!? KASRASKRASKRASKKRASK
"Any application that only worked on Windows XP and broke in the upgrade to Windows 7 also won’t work on Windows 10 — don’t expect it to. The Professional versions of Windows 10 don’t offer the “XP Mode” feature Microsoft offered in Windows 7. If you absolutely do depend on Windows XP software that doesn’t run properly on Windows 7 or newer versions of Windows, you can set up your own Windows XP virtual machine."
Will my existing programs, hardware and drivers work on Windows 10?
Most applications and hardware drivers designed for Windows 7 or later should work with Windows 10. Of course, with significant changes expected in Windows 10, it is best you contact the software developer and hardware vendor to find out about support for Windows 10. Windows 10 setup will keep, upgrade, replace and might require that you install new drivers through Windows Update or from the manufacturers website. "
APPS DO WIN7 PODERÃO FUNCIONAR NO W10, MAS O MELHOR A FAZER É CONTATAR O DESENVOLVEDOR DO SOFTWARE OU HARDWARE E SOLICITAR O SUPORTE PARA O WINDOWS 10, SE O MESMO NAO FORNECE NÃO É A MS QUE VAI FAZER ELE FUNCIONAR SENDO QUE NO PRIMEIRO TEXTO ATÉ FALAM PRA VC USAR SEUS APPS ANTIGOS EM UMA MAQUINA VIRTUAL COM O WINDOWS XP!
KKKKKKKKKKKKKKKKKKKKKKKKKKKKK
100+
ENTÃO VC MESMO DISSE QUE ELA ESTÁ PORQUE OS APLICATIVOS RARAM DE SER ATUALIZADOS ... SE NÃO FOSSE IMPORTANTE A M$ JÁ TERIA RETIRADO FAZ TEMPO... ... ... ...... Lá em um dos PRIMEIROS POSTS eu disse que muitas dos problemas causados SÃO DEVIDAS A MUDANÇAS QUE A PRÓPRIA M$ FAZ NO S.O. CAUSANDO OS BUGS EM DETERMINADOS APLICATIVOS DEVIDO A QUEBRA DA COMPATIBILIDADE QUE TINHA E QUE O DESENVOLVEDOR PRECISAVA SE VIRAR PARA ARRUMAR..ISSO ACONTECE PORQUE A M$ NÃO VAI QUERER E NÃO VAI REVERTER AS MUDANÇAS QUE ELA FEZ NO S.O. SE O WINDOWS 10 FOSSE TODA A MARAVILHA QUE PROMETERAM, NINGUÉM ESTARIA RECLAMANDO E TODO MUNDO JÁ TERIA ABANDONADO AS VERSÕES ANTERIORES AINDA MAIS COM O UPDATE SENDO DE GRAÇA PARA QUEM TEM AS LICENÇAS ORIGINAIS!!!! SE MESMO ASSIM AINDA NÃO ENTENDER... NEM DESENHANDO VAI ENTENDER.......
