[TÓPICO OFICIAL] Windows 10
lol2005
283
63
Galera estou com um problema no meu windows 10 pro, fiz a formatação para o pc novo build 1803, porem toda aqueles programas "lixos" que vem com o windows 10 não estão desinstalando, por exemplo se eu tiro o candy crush o ícone "some" porem se eu desinstalo o "sketchup" o icone do candy crush volta, alguém sabe a solução deste problema?
Simples, primeiro, abra o cmd como administrador, em seguida aplique esses comandos:
Código:
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "ContentDeliveryAllowed" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "FeatureManagementEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "OemPreInstalledAppsEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "PreInstalledAppsEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "PreInstalledAppsEverEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "RotatingLockScreenEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "RotatingLockScreenOverlayEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "SilentInstalledAppsEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "SoftLandingEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "SubscribedContentEnabled" /t REG_DWORD /d "0" /f
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager" /v "SystemPaneSuggestionsEnabled" /t REG_DWORD /d "0" /f
reg delete "HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager\SuggestedApps" /f
reg add "HKLM\Software\Microsoft\Windows\CurrentVersion\WindowsStore\WindowsUpdate" /v "AutoDownload" /t REG_DWORD /d "2" /f
schtasks /Change /TN "Microsoft\Windows\WindowsUpdate\Automatic App Update" /Disable
Depois de aplicados esses linhas no registro, vc pode usar o ccleaner pra remover toda a lixarada restante dos apps inúteis do windows 10. Eu gosto de usar o dism++ pra remover o lixo, mas o ccleaner é melhor, pois é mais claro para o usuário comum.
Um conselho: não remova o ms store e o outro app dela, vc pode precisar dela no futuro. Depois de aplicar essas linhas no registro, bye bye essa função escrota do win10 de instalar apps sem a permissão do usuário.
Obrigado chegando em casa tentarei essas dicas! =D
Ebin
:-DDDD
3,273
7,520
João Pessoa - PB
Caramba, quase todo update o Windows aqui buga o controle de som. Fica em 100% e não diminui nem a pau!
maur0
9,939
3,428
Curitiba PR
ta feio a coisa, vai volta a usa server 2016? ou arriscar o 2019 insider?
davidgo
289
_TriHard_
57
9
Tenta fazer o que ensinei alguns posts para atrás e desinstala/desabilita tudo que não é necessário para você, por final desabilita o windows update e gg.
blz valeu acho que achei aqui
-desativando o windows defender
-desativando por definitivo a cortana
-desativando windows search e sobreposição do xbox
-remoção do da telemetria do windows e o windows update no services.msc
- remoção da loja do windows e colocou o menu classico
blz
ScrooW
Mestre dos ajustes.
5,771
4,094
Campina Grande - PB
blz
O caminho é esse, principalmente se você tem só 8gb de ram assim como eu.
Urah
1,266
379
Campo Grande - MS
A quase um ano atrás eu tinha exatamente o mesmo problema e era a bateria da placa mãe, e acontecia igual acontece contigo o w10 mostrava a hora errada mais o Ubuntu mostrava certo, deduzo eu que o Ubuntu utiliza melhor a questão da hora certa via internet, o servidor do Windows nesse sentido pode ser ruim ou falho.
Mas tipo, a quanto tempo vc tinha a placa mãe ? To com esse problema em um note que tem 6 meses
sinho_robo
Whatever :)
692
Código:
Deu erro aqui
C:\Windows\system32>schtasks /Change /TN "Microsoft\Windows\WindowsUpdate\Automatic App Update" /Disable
ERRO: o nome de tarefa especificado, "Microsoft\Windows\WindowsUpdate\Automatic App Update", não existe no sistema.
Dalai Brahma
os astros q regem os sabidos tbm regem os otários
6,483
2,541
J Pessoa-PB (Saudades, Recife!)
Mesma mensagem aqui.
Judit: Ok! achei um tuto ue explica que é normal não achar uma tarefa. "Some of these may not exist, it's fine."
marcelogon
1,220
89
PIABETÁ-RJ
Meu windows 10 tá desde ontem tentando instalar uma atualização, mas da erro e reverte tudo.
Dr. Strangelove
820
302
Belo Horizonte
Estou tentando o Windows 10 LTSB e para mim é o windows como deveria ser. Quero ver como vai ser na questão das atualizações se encher o saco arrisco uma dessas versões modificadas mesmo que nem atualizam, quero Windows só pra jogar mesmo o resto vou fazer no Ubuntu.
Como é a questão da telemetria nessa versão LTSB?
leandrinhoflash
178
Bastante mínima. Apesar disto, recomendo você baixar uma versão modificada mesmo.
Recomendo esse grupo: https://plus.google.com/communities/101952101490904004054
LTSB é bacana.
Reações: Dr. Strangelove
XxDarkshotxX
xxdarkshotxx
11,739
921
Pessoal estou na busca de descobrir a causa dos sttuterings que tenho nos jogos e o alvo da vez é o HD, queria saber qual melhor forma de configurar a memoria virtual. Estou com um SSD Samsung 860 EVO de 250GB para onde está o sistema, um ssd Samsung 840 EVO de 128GB para jogos, um HD de 2TB para jogos e um SSD corsair sata 2 para jogos.
ChrisNowa
648
51
São Mateus do Sul - PR
Quanto a memoria virtual, acredito que a melhor configuração é setar em manual, e no ssd a quantia inicial e máxima iguais, pois se faltar memoria o sistema não precisa expandir mais para alocar, e nessa hora que pode afetar desempenho. Eu por ex uso 4096 inicia e 4096 máximo no ssd.
unBond
Chimpa
2,575
8,299
Capital do HUE BR
Galera alguém tem um guia, de como otimizar o windows 10 para computadores com 4gb? O que desativar, cortana realmente pesa mesmo?
Reações: Rodrigo Buscapé
Guifalcon
10
Pessoal seguinte, tenho uma atualização agendada para o dia 22/07, seria possível eu desativar ela e bloquear as atualizações do windows 10? eu não consigo por nada desativar essa desgraça..
aLLeyesOnMe!
PaulPatempo
1,095
106
Vila da Penha - Rio de Janeiro
Boa tarde povo!
Depois de muita dor de cabeça e até gasto comprando uma fonte nova, descobri o que estava causando o reboot da minha máquina. Um maldito patch ou pack de segurança, não lembro.
Eu desinstalo o patch e o problema para mas a partir do momento que eu ligo o PC novamente, ele reinstala as atualizações... aí sou obrigado a desinstalar novamente.
Já desabilitei as atualizações automáticas naquele services.msc mas ele continua instalando a atualização... :eek: Tem alguma forma de desabilitar de vez ou bloquear somente o patch específico?
0d14r3
AM User
1,016
113
Manaus - AM
Boa tarde povo!
Já tinha postado isso antes, vê serve no seu caso:
Este remendo da MS para atualizações problemáticas parece interessante: support.microsoft.com/pt-br/help/4026726/windows-hide-windows-updates-or-driver-updates.
Vi isso neste artigo da TECHTUDO: https://www.techtudo.com.br/dicas-e...os-atualizacao-kb4103721-saiba-resolver.ghtml.
Reações: aLLeyesOnMe!
ScrooW
Mestre dos ajustes.
5,771
4,094
Campina Grande - PB
Não tem um guia definitivo, mas se tu desabilitar tudo que não usa vai da uma boa melhorada, meu cold boot aqui consome 0,9gb(ram).
Reações: ChrisNowa e unBond
BuFF
922
412
Usa o LTSB, não vem quase nada instalado nele
Reações: unBond
foxp2
Membro
79
Paraná
Ola pessoal, tudo certo​
Mais uma vez estou aqui pedindo o auxílio de vocês. Gostaria de saber se conhecem ou aprovam esses métodos p/ baixar versões do Win, seja o 7, 8 ou 10. O contexto é que a atual versão(1803), está muito ruim aqui pra mim, sério, não da mais. Daí eu estou atrás de baixar alguma versão mais antiga, talvez a 1709 por ex, ou mesmo em caso extremo o Win 7.
Agradeço desde já
SamSS
651
77
Bombinhas -SC
Reparei que de uns 10 dias para cá, o Windows algumas vezes depois do login, abre a área de trabalho e carrega todos aplicativos quase que instantaneamente. Outras vezes, após inserir a senha e dar enter, demora muito a carregar a área de trabalho e aplicativos da inicialização.
Estou usando Windows 10 pro original e totalmente atualizado (1803). Desconfio que esse problema começou após alguma atualização.
Alguém mais está tendo esse problema?
