Windows 7 - [ PREVIEW ]
raphahxb
15,274
1,046
73
Alguem confirma?
se for isso eu vo ter que baixar outra build antes de instalar. to usando a 7068 e nao to pretendendo formatar por enquanto pra fazer uma instalaçao limpa.
se for o caso vo baixar a 7077 pra fazer upgrade e depois faço upgrade novamente pro RC
megazz
Freeman
4,589
2,140
Araucária - PR
Será que vai dar para fazer upgrade normalmente do beta para o RC?
EDIT: A microsoft não recomenda, e parece que tem q fazer uma gambi :lol:
Microsoft recommends users to do a clean install rather than upgrading from Windows 7 Beta (or any other builds) to Windows 7 RC build. It is not possible to upgrade your Windows 7 Beta to RC unless you bypass the check for the pre-release upgrade. Even though this is not recommended by Microsoft, below are the steps to bypass this check (from the E7 blog):
Download the ISO as you did previously and burn the ISO to a DVD
Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build)
Browse to the sources directory
Open the file cversion.ini in a text editor like Notepad
Modify the MinClient build number to a value lower than the down-level build. For example, change 7100 to 7000
Save the file in place with the same name
Run setup like you would normally from this modified copy of the image and the version check will be bypassed
Hendrix
Purple Haze
3,539
BH - MG
Daemon Tools Lite 4.30.4
What's new:
- Windows 7 beta supporting (SPTD 1.58);
- Protected images creation: Password field on Disc Imaging dialog;
- Compressed images creation: Compress option on Disc Imaging dialog;
- Image Catalog item was moved to the first level of Main Menu;
- mdf-file type association option;
- Languages updates.
Bugs fixed:
- Devices speeds detection;
- Lite-ON DHXXXXX drives supporting;
- Large RAID volumes issue;
- Mounting/converting B6T DVD images;
- Setup improving: Unicode supporting;
- Some minor GUI bugs.
Download
raphahxb
15,274
1,046
73
takechi
391
5
aqui provavelmente só amanha eu instalo...
falta 20h +- vindo a 40k
ta variando muito
Oráculo®
776
Unaí-MG
por favor alguem ai pode me mandar o link pra baixar... eh q minha net aqui eh de 600k e naum posso tem o luxo de baixar um fake... quem tiver o link ai de um x64 real 7100build pode me mandar?
livemusic
Quem é John Galt?
1,400
Blumenau, SC
Opa, vou botar pra baixar hoje à noite. :D
Pena que só dá pra fazer instalação limpa, vou ter que fazer backup dos meus savegames antes...
megazz
Freeman
4,589
2,140
Araucária - PR
Uma pergunta:
Como está o 64 bits? Eu tenho medo de ser tipo o Vista 64 bits, lerdo, trava tudo, swaps sem parar. O vista 64 bits com 2GB de memória nem rola.
Mas e o 7?
Hendrix
Purple Haze
3,539
BH - MG
Uma pergunta:
Mas e o 7?
Já usei aqui a build 7068 x64 e tenho apenas 2GB de ram. O desemprenho fica bem melhor que o Vista, mas eu ainda prefiro a x86, pois nos jogos sempre davam umas engasgadas por causa do Swap na x64.
.Braga.
4,901
166
Quaraí - RS
Vou aguardar dia 5 mesmo, vou testar os games.. A ultima build que testei foi a 7000, de la pra cá houve mudanças de perfomance e estabilidade?
arjcba
1,176
7
Cuiabá
Houveram sim, de performace principalmente. Olha que nem testei a 7077 e a 7106, fiquei com a 7068.
Finalmente. Até o fim da tarde estarei com ele completo :D
    105.4 KB · Visitas: 129
megazz
Freeman
4,589
2,140
Araucária - PR
É... bem isso que eu odeio... SUAuHSAuhSA vo ficar na x86
.Braga.
4,901
166
Quaraí - RS
Opa valeu.. acho que irei testar mesmo :D
arjcba: Que programinha é esse de baixar do RS, funciona?
fonsecajipa
Suporte
67
Pra quem ainda esta com duvida, uso a versão 7068 x64, e esta absolutamente perfeita, e não sou um usuario básico. As builds mais recentes só tem de a melhorar.
.Braga.
4,901
166
Quaraí - RS
Boa, valeu mano.. Nem sabia da existencia desse ai
megazz
Freeman
4,589
2,140
Araucária - PR
Com 4GB deve ficar legal mesmo. Nunca tive a oportunidade de testar.
Mas pra quem tem 2GB de memória, eu não recomendo 64 bits não...
Lost4Ever
2,202
2,604
O chato da versão 64bits, é que um quase nenhum aplicativo que você usa, vai ser 64bits e no sistema fica tudo duplicado, dois Internet Explorers, dois Windows Media Players.
No dia que for possível ser 100% 64bits eu migro. Também não vejo necessidade de 4 Gigas de memória ou mais, tirando quem mexe com design3D. Para jogos ainda duvido que 2Gigas não sejam suficientes. :)
Mas claro se tivesse 4 Gigas instalaria o 64bits só para não ficar 1Giga sobrando, este fator é mais forte que o resto para não usar. :said:
Notem os 3 primeiros estão usando o Linux, mas aparentemente o upload deles é zero (pelo menos para mim), mas baixam como loucos.
Queria saber um meio de me desconectar de gente assim. :ranting3:
megazz
Freeman
4,589
2,140
Araucária - PR
Não que os 32 bits deixem esses 800mb~1gb sem usar. É usado sim, para endereçamento dos dispositivos do PC (placa de vídeo, placa de som, portas USB, etc). Assim quanto mais dispositivos você tiver, menor vai ser a quantidade que os sitemas 32 bits vão usar seus 4GB de RAM.
Hendrix
Purple Haze
3,539
BH - MG
http://g.imagehost.org/0914/droga.jpg[/IMG]
É uma [email protected] mesmo. Os caras só sugam e não upam nada, por isso que a velocidade tá horrível desse jeito. Acho que vou pegar pelo Rapidshare mesmo.
sergio39
1,526
minas
não seria mais vantagem pegar a linha de build que se direciona para RTM?
exemplo:7106,7107.............
aqui a 7106 esta melhor que a 7077.
sera que esta 7100 vai ficar melhor que a 7106?
raphahxb
15,274
1,046
73
terminei de baixar, vo deixar fazendo upload pra ajudar quem ta baixando
