Windows 7 - [ PREVIEW ]
Himitsu
SA BO NIM, KIUNHE!
2,755
1,160
Maricá, Rio de Janeiro
Acho que a galera tá muito afoita... Diretamente do Site do Wzor (quem não entender inglês... Ahm... Vá estudar...):
"so, what exactly happened at MS that night?
When the crowd was anticipating the results, MS was discussing the 3 builds
6.1.7260.0.win7_rtm.090612-2110 - RTM branch build
6.1.7261.0.win7_rtm.090615-1900 - RTM branch build
6.1.7262.0.win7_rtm.090617-1900 - RTM branch build
They were debating about which of these builds should be used to make the final RTM release,
the debate was long and in the end, none of the builds got enough votes, which means the quality
of the builds was below the set requirements.
Immediately after the voting, a new build was assembled: 6.1.7263.0.win7_rtm.090619-1900 - NEW RTM branch build.
We want to remind you about the initial source, that means about what we said on 10 june 2009, which was: Microsoft Windows 7 (Client / Server) build RTM - FINAL WILL leak after June 19, 2009
- which means, RTM should be expected after june 19th , not on june 19th .
Also:
“final RTM release will be built before the summer solstice, which means before june 21st !“
“from the moment the RTM build is finished, Microsoft will be internally testing this release followed by the sign-off, before these procedures are over, NO ONE can claim which build will become the official, final RTM of Windows 7”
“The upcoming RTM build assembly doesn't mean it will appear on CONNECT or MSDN immediately after it”
All of the above should be taken as is, and you shouldn't have made guesses and false claims about us or anyone else leaking the final RTM release exactly on june 19th !
We are sure that june 19th is a key date after which we will be able to tell that the assembly of the final RTM release happened and which build has become the final one.
Now you can see that not one of the 3 build has passed the voting, so there will be another one in 2 days, which can continue until july 13th!, but we are sure will we be able find out about the assembly of the final version before the end of june.
And should this build exists, then so does the possibility of it leaking, but it's not a fact, too few people have access to the RTM build before the end of it's testing period.
Even if such a build is going to be leaked, there won't be a 100% guarantee that this build will become the final one before the official sign-off
Besides, you have to consider that the assembly of all client and server versions in all languages will happen in one day, that's a huge amount of data and before this data doesn't get tested, no Microsoft partner will get it.
I wouldn't expect the final release to be available in the next two – three weeks on CONNECT or MSDN, the process of distributing (uploading?) also takes it's time.
(Isso quer dizer que pelas formas "oficiais" pode demorar um bom tempo, mas ainda temos a chance de vazarem, que são bem poucas, mas existem)
All candidate builds in the WIN7_RTM branch:
6.1.7260.0.win7_rtm.090612-2110 - RTM branch build - no sign-off!
6.1.7261.0.win7_rtm.090615-1900 - RTM branch build - no sign-off!
6.1.7262.0.win7_rtm.090617-1900 - RTM branch build - no sign-off!
6.1.7263.0.win7_rtm.090619-1900 - NEW candidate in RTM branch build.
and - WINMAIN branch build:
6.1.7233.0.winmain.090614-1655 - actual build in winmain branch
wmh
A verdade sempre triunfa
7,980
42,756
RJ+MG: Uai mermão!
A verdade é que ninguém sabe quando será. Vamos aguardar e ver o fim dessa novela e o início de outra. :thumbs_up
PS: Ainda estou no 7201. Parei de acompanhar esperando uma versão "final". hehehe
P3dRo h3nR1qUe
1,091
Brasília
Novidades do windows 8 MIDORI:
1. Kernel NT7 ou MinWin (MinWin está sendo desenvolvido no Microsoft Singularity)
2. Sem Regedit e Dll´s (como Linux e Apple)
3. Reconhecimento de Voz atualizado
4. Multi-Touch
5. User Interface avançada com Aero 3ª Geração
6. Aero Peek 2ª Geração
7. Cloud Computing - Pc das nuvens
8. Arquiteturas x86, x64 e ARM
9. Capaz de executar todas as Aplicações criadas para Windows, versões anteriores
10. Facilidade de mudar de utilizador, com a capacidade de ter várias contas abertas sem perder nada do seu trabalho
se for tudo isso, vamos ficar livres de muita coisa ruim dos sistemas anteriores
sergio, eu preciso falar que pegaram várias coisas do projeto Midori e várias outras coisas inventada e fizeram uma nova lista FAKE? :slap:
Windows 8 e Midori são projetos diferentes, distintos, um é o sucessor do Windows 7 (e ninguém sabe qual o code nome, se será realmente Win8) e o outro é um sistema operacional totalmente novo, experimental, que ainda está em incubação para ver se é viável ou não lançá-lo comercialmente.
Até que a MS divulgue que juntou os dois projetos, todas as listas que falam que o Windows 8 é o Midori, você pode ficar com um pé atrás pois é muito provável que seja FAKE.
Informações concretas sobre o sucessor do Windows 7 só devem começar a aparecer após o SP1 do 7, a não ser que a torneira da MS continue a vazar (continue a ter os amados leaks).
EDIT:
Só uma observação, o MinWin é o kernel do 7, não é um kernel novo que nem essa lista diz.
MinWin = Kernel do Windows (no caso do 7, o kernel do Vista) "limpo"
CCR
1995 Civic VTi Eg6
1,749
137
Floripa-SC
Quero ver um SO sem dll`s e que ainda dê suporte às outras versões.
arjcba
1,176
7
Cuiabá
Cara... Já estou vendo quando sair o RTM vai bater uma depressão geral na galera aqui da Área Windows :lol:
@Sergio39: Só uma sugestão, com a chegada do RTM já seria uma boa de criar o tópico oficial do Windows 7. Você é o cara mais ativo desse tópico e apesar de não ter um filtro nas notícias que você posta, você sempre tem coisa nova pra galera. Bem que você poderia se encarregar disso (criar o tópico oficial) né? :p
Himitsu
SA BO NIM, KIUNHE!
2,755
1,160
Ai vira Linux... Pra não ter DLL e ter retrocompatibilidade só emulando, o que tornaria algo inviável para aplicativos 3d (ou precário, como no Linux).
É fake esse troço ai...
Aliás, isso não tem nada a ver com o Seven né... Que, infelizmente, não tenho muitas esperanças de ver uma versão final tão breve.
FATO! Eu mesmo não terei mais o que fazer no pc... Sem expectativas, sem novidades, sem ter que acordar de madrugada quando uma nova Build acaba de ser baixada para já começar a formatação do pc... Acho que é melhor o suicídio do que esse tédio (modo habitante de países nórdicos ultra ON! hehehe)
phyton
3dfx Voodoo 3
1,702
69
Hellcife - PE
ahauhauha verdade... vai bater a morgação na galera :)
dica: vão brincar com o Hackintosh! Tenho aqui o torrent e o tutorial de install :)
CyriX
735
na Itália pq lá é toap
galera esperando mil maravilhas do Win7 -- o sistema é ótimo, mas galera deseja de mais.
vai ter nego reclamando e xingando tudo o que pode na versão RTM
isso porque tem pião que reclama e nem ao menos vai comprar a cópia original :D
Himitsu
SA BO NIM, KIUNHE!
2,755
1,160
Ja tem o Language Pack PT_BR do 7 7232 x64?
Não e nem vai ter.
Normal... Não pago luz mas reclamo quando falta! :)
Não da pra agradar todo mundo, mas mesmo que não agrade, a esmagadora maioria usa, então, não tem muito problema pra M$.
AlienWare2006
1,166
Maringá
a 2 dias atrás, instalei o Leopard na maquina da assinatura, estou adorando, configurei a SB Live, rede e video, reconheceu meus outros hds e ainda funfo o boot uma beleza, só preciso passar pra 1.0.5.7, o meu é 1.0.5.2.
GaRoTo PicPá
142
Concerteza naum comprarei original, o país onde vivo "não permiti", muitos menos as condições, pagar 800 conto em um software no Brasil eh só pra quem pode. :thumbs_up
skullTrail
Atitude Certa
1,065
O Sete em si é um otimo sistema. PQ? Pq ele corrigiu todas as areas em que o vista pecava(leia-se desempenho). No mais, ele tem tudo de bom que o vista tem, uma firulas visuais a mais....Mas de novo, novo mesmo, ele nao trouxe exatalmente NADA.:huh:
Billy Gun
2,123
13
Eu tambem acredito que RTM só mes que vem.. data eu não sei, mas este mes não sai mesmo.
raios
647
Poá-SP
aqui parei na build 7127 esperando agora sair a rtm
phyton
3dfx Voodoo 3
1,702
69
Hellcife - PE
@OFF
ae AlienWare, bem vindo ao mini-clube dos Hackintosh users do Adrena :)
aparece lá na sessão mac!
entao o update para 10.5.7 é mais correções de alguns bugs, visualmente nao tem nada de novo, praticamente vc nao vai notar nenhuma diferença. Mas é sempre bom ter o sistema updated :)
:thumbs_up
sergio39
1,526
minas
vou pensar com carinho.
esta fora do ar porque perdi 120gb de dados no hd de 750gb.
incrivelmente recuperei praticamente tudo com EasyRecovery Professional.
tive que reformatar os 2 hds de 320 em raid 0 e colocar o windows xp 64 basico ja que o EasyRecovery Professional e incompativel com o windows 7.
agora que recuperei os dados,gostaria de formatar o hd de 750gb de uma forma a ficar totalmente limpo.existe algum programa que formata e apaga todo lixo que esta escondido?
queria tipo uma formatação fisica.
mais se existir algum programa que apaga tudo,ficaria grato.
alguem poderia ajudar?
Após informações de liberação do RTM via
connect,MSDN,TechNet, dia 19.
Vamos entender porque isso não aconteceu
após testes efetuados sobre as builds 7260,61 e 62
não teve os votos necessários para tanto
com isso foi compilada a build 63 no dia 19
será votado novamente para uma possível RTM em 3 dias
com isso a build RTM final devera ser liberada até 13 julho
mais a Microsoft está confiante de ter o
resultado positivo da RTM ANTES
RaphaelSantos
Paz de Jesus para todos!
6,927
623
Brasília, DF
Amigos,
Qual a ultima build 32bits com MUI em PT-BR???
eh possivel me mandar o link da mui pt-br junto com o nome da build a que ela se destina???
obrigado a todos.
Himitsu
SA BO NIM, KIUNHE!
2,755
1,160
Amigos,
obrigado a todos.
Com LP é a 7229, sem é a 7260.
Links não tenho.
Bom, passam de 20h... Alguma notícia do Connect ou MSDN?
LurtZ
19,610
770
SBC - SP
adrenaline.com.br
Aguardando a RTM para sair da build 7068 :p
RaphaelSantos
6,927
623
Brasília, DF
Nussa. 7068 ainda ? Já saiu muitas builds melhores que essa, mas agora nem compensa mesmo baixar já que o RTM está quase pronto...
hendrix, vc tem o link do mui pt-br pra build 7229??? tou feito doido procurando no google e nao acho :(
ja baixei a iso 64 bits e to baixando a 32 bits, so falta o mui pt-br :(
