X1950 XTX e X1950 CF com mesmo clock 650/2Ghz
Cyrx
Adrena Old School
FOR the first time, ATI plans to make Crossfire and the XTX cards clock at the same speed. Both the upcoming Radeon X1950 XTX and Radeon X1950 Crossfire Edition will end up clocked at 650MHz core and 2.0GHz DDR4 512MB memory.
If everything goes well for ATI, this will be the last high end Crossfire edition card as the R600 has everything it needs to pair two cards without any necessity for a Crossfire card.
The card will retail for $449 in the US and will be sold for some €409 in European retail, but will display a tendency to fall below €400.
We can now confirm that the cards will be ready for the 23rd of August but as the clock speed stays the same, don’t expect any miraculous performance increase. We've already written about it here.
And here is a small summary or our R580+ articles, below. µ
Que monstro!
Eu nem consigo imaginar esse todo esse poder de fogo :p
ATI sempre sai na frente quando o assunto é clocks altos.
sem contar que essas memos consomem menos que as GDDR3 atuais :D
Por acaso ela vai ser 512bits ???
Outra coisa...com esses novos cpus Intel CPU bound n existe mais, dai uma placa Tipo GX2 faz muita diferença pois o GPU bound com ela é muito menor mesmo.
