Yeah!!!!!!!!!! Patch para jogar Wolfsntein ONLINE!
VultU
É só um jogo...
Ae,
Acabei de pegar essa dica, não testei porque to no trampo. :(
Saiu tb um patch para montar um SERVER para o Wolf que não pede Ident Key
Se alguém tiver um FTP com 1MB livre eu envio o arquivo para vcs. ;)
cya all!
This is how to play Return to Castle Wolfenstein (Razor ISO) with other people on the internet:
a) Edit the file %windir%\system32\drivers\etc\hosts (NT,Win2k,XP)
or %windir%\hosts.sam (Win9x) and add the following entries
(syntax is strange, but needed for lame VLAN implementations):
127.0.0.1 wolf.idsoftware.com
127.0.0.1 wolfauthorize.idsoftware.com
wolf.idsoftware.com 127.0.0.1
wolfauthorize.idsoftware.com 127.0.0.1
b) Connect your local machine/LAN to your friends' machine(s) using VPN
(a feature built-in win2k/XP and available for other win32 versions also)
NOTE: This will help you play with other people on the internet. You can connect with
your friend to kick his arse. Also, you can set up your local LAN with one wolfenstein
server, invite your grandma and grandpa (so you already have three players) and then
connect your LAN to another LAN on the internet through VPN. This way, you can get
a similar feeling to what you would get if you'd play multiplayer through the
idSoftware hub server.
If you are some kind of a freak, you could now set up a website proclamating open
VLANs with a running Wolfenstein server or even write a patch that will redirect
traffic (you figure out yourself). I'm neither gonna write that patch nor am I gonna
help anyone trying to set this up - you do want to buy the original if this is not
enough for you, don't be a lame leech.
Also, if you don't know how to set up VPN or similar tunneling methods, then I'll
repeat once again: buy the fucking original! it's worth it!
Regards
cho/f4cg
bernard0
keria mto ter o rtcw aki no meu pc :(
onde eu posso arregar ?
Nicodemus
Click here to win prizes!
É, achei em 2 lugares até agora, mas MUITO lento... uns FTP na Nigéria conectado na internet por um cabo de telefone quebrado, com um carinha usando um garfo pra fazer a conexao...
se tu tem os links ainda, passa aí pra galera!
Broda
eu tenho ele
Comprei original nos EUA
Faco a copia dele por 10 pila apenas e ainda ja gravo esse patch que o vultu falou dele no CD
Falo
Broda
Eu nao testei ainda, mas pelo que o Vultu falou ele ja testou e funciona, alias os caras nao iam lancar uma coisa dizendo que funciona e na verdade nao funciona porra nenhuma.
Entao acredito eu que funciona 100%
Falo
