E colocaram uns items beeeeem P2W:Nao entendi, o que aconteceu? a bsg tirou alguma coisa que era de graca da EOD?
Update on current situation
Discussion
Hello again!
Let me clarify the situation in a little more detail regarding owners of the EoD version and access to the cooperative mode, and also other issues.
First of all, PvE gamemode this is not DLC. DLC in our understanding is the major additions to the game, including various functionality and content that are released after the official release of the game as a themed DLC pack (Scav Life DLC for example, which will add a lot of new mechanics and content for Scav gameplay and leveling).
Secondly, this specific functionality of the PvE mode is necessarily located entirely on a separate network infrastructure, because, essentially, you play on our servers, only in closed mode. At this stage, it is not possible to launch all players who are EoD holders - right now we simply do not have the required amount of resources for this.
We observe your dissatisfaction and have decided that the functionality of the PvE mode will be available for free to all owners of the EoD version at the release of the game, when the server infrastructure will be improved to the required capacity.
Now you have the opportunity to test this mode by purchasing the Unheard edition of the game, or upgrade to this version. We also decided to give a 50% discount when upgrading to the Unheard version from the EoD version.
We plan to send one free Left Behind Edition key to everyone who has already upgraded to Unheard Edition at the old price from the EoD version.
Moreover, so that any player of any version of the EFT can have the opportunity to test the PvE mode, we want to add the ability to purchase a separate early access to this mode. For EoD owners there will be a 70% discount on the purchase of early access to PvE. It would be interesting to hear your thoughts on this idea.
Next, regarding special items for the Unheard version, we plan to make restrictive or balancing changes for these items.
This is it for now, please share your thoughts. Thank you!
Discussion
Hello again!
O que é SP Tarkov?Eu já desisti desse jogo.
Ainda mais que eu tenho a versão Standard. É pedir pra tomar no cu
Larguei a mão e to jogando SPTarkov
Mod para jogá-lo no modo single player.O que é SP Tarkov?
Nossa..E colocaram uns items beeeeem P2W:
Unique radio-electronic item "Mark of The Unheard":
Unique item "Distress signal device":
- The item is equipped in the special slot
- The item gives a 50% discount when using cash services in raids
- Insured equipment returns 30% faster;
- With 6+ Fence reputation, Scavs won’t shoot first at ranges over 60 meters away.
- When the item is activated, it produces a bright flash as well as a loud sound signal;
- Once activated, all players on your friends list will receive a notification that they can join your raid to help you.
Cara tem como explicar esse q deixou o PVE exclusivo pra ela??Não, um tempo atrás pararam de vender EOD, agora lançaram outra versão top, que custa uma fortuna pra tu upar se for EOD, e deixou o modo PvE exclusivo pra ela
O que é SP Tarkov?
Safe instalar ele? Precisa da versão normal?
Pensei em instalar pra praticar mapa e recuo da arma e etc..
É safe, só nao pode rodar os 2 ao mesmo tempo.Precisa ter o jogo normal instalado sim.
Agora se é safe de usar, não sei dizer. Nunca me interessei o suficiente para ir atrás de informações.
Prefiro aprender jogando (ou seja, morrendo e sofrendo).
Qual foi o final feliz?A verdade é que o modo pve é muito bom, agradeçam ao SPT (o trabalho dos caras é fantástico) pq graças a ele a BSG resolveu se mexer (apesar das merdas que fizeram ao cobrar pelo conteudo). No final quem ganhou foi a comunidade do tarkov, agora temos um modo PVE da hora e futuramente teremos o suporte aos mods! O que o nikita fez e se arrependeu resume bem o que a industria gamer faz com nós jogadores, fico feliz que desta vez o final foi feliz pra nós!
Edit: os IA´s bots do modo PVE tao bem desafiadores!
Qual foi o final feliz?Qual foi o final feliz?
se tu quer fazer barulho na moita, pode fazer uai.Galerinha do Tarkov Single-player, não que eu seja o pika do Tarkas (aliás, é bem o contrário) mas o jogo só com Bot / SCAV não fica muito sem graça não? Eu ia ficar correndo pelo mapa que nem uma gazela, fazendo todos os barulhos possíveis.
Nope.Galerinha do Tarkov Single-player, não que eu seja o pika do Tarkas (aliás, é bem o contrário) mas o jogo só com Bot / SCAV não fica muito sem graça não? Eu ia ficar correndo pelo mapa que nem uma gazela, fazendo todos os barulhos possíveis.
Legal, não sabia. Deve até melhor pra treinar do que as partidas offline do Vanilla. Sabendo que não tem PMC, exploitar o comportamento dos SCAVs é muito fácil.Nope.
Existem mods que mudam o comportamento dos bots e fica beeeeeeeeeeeeeeeeeeem dificil e bem parecido com alguem controlando um PMC.
Na verdade o SPT tem PMC Bot com comportamentos diferentes, eles são programados pra agir que nem players mesmo, são mais agressivos, agem diferente dos scavs, tem equipamentos diferentes e td mais.Legal, não sabia. Deve até melhor pra treinar do que as partidas offline do Vanilla. Sabendo que não tem PMC, exploitar o comportamento dos SCAVs é muito fácil.
